| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#15 |
Drives: 2014 FR-S
Of course they won't, but hey... Battle scars are bad ass, right?
| The Following User Says Thank You to Yousend For This Useful Post: | Tcoat (05-27-2017) |
#16 |
Drives: 2014 FR-S
Next day horror.
I tried to clean it off and it's not going away. Any tips for this one? I have no idea what to look for. "Rust Converter Remover" is not really helpful.
#17 |
If it is just on the surface (which it seems) just get some light rubbing compound and see if it will buff off. If you clear coated over it then break out the sand paper and start again. You may be able to cut through the clear coat with a light wet sandpaper or better yet go to a craft or hobby shop and pick up a set of progressively finer sanding sticks. They would have the side benefit of levelling out your touch up a bit. Just take it slow and gentle.
| The Following User Says Thank You to Tcoat For This Useful Post: | Yousend (05-27-2017) |
#18 |
The front and sides of mine look like it took on a dragon. Or two.
#19 | |
Drives: 2014 FR-S
#20 |
It's gonna come back in time, the paint is contaminated with the rust oxide farther than the spot. you need to sand a wider swath, use rust neutralizer brush or spray, sandable primer,spray paint with paint match, then automotive clear. A lot of work and patience is needed but done right it won't come back.I use the match spray from here, been using it for years on my Landcruiser and 86 with amazing matching. Good luck!
http://www.automotivetouchup.com/tou.../scion/2014/fr[dash]s/ http://www.automotivetouchup.com/spr...clearcoat.aspx http://www.automotivetouchup.com/spr...nt_primer.aspx https://www.amazon.com/dp/B003HG48AC..._t1_B001DEL6J6
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| PSA: Beware this rust spot | headlikeahole | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-01-2015 07:36 PM |
| Can you spot the BRZ or GT86? | hanabie | BRZ First-Gen (2012+) — General Topics | 11 | 08-23-2013 08:08 PM |
| Small rust spot look a like stain? | Bach415 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 04-30-2013 02:35 PM |
| Rust? even with rust proofing? | Chinadian | Issues | Warranty | Recalls / TSB | 8 | 01-26-2013 05:15 PM |
| New Parking Spot | raul | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2012 01:42 AM |
