| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Kuruma Otaku
As pointed out by others, that has never been said. The dyno measures engine torque that fights through the drivetrain's inertial and frictional losses. So reducing the mass of the wheels makes the path easier, in a manner of speaking. This is why there is a difference between the number a chassis dyno spits out and the number a factory tells us which comes from an engine dyno.
Because titanium. |
#16 |
Drives: Nevermorange FRS
Mr. Snooze. Who is it exactly that is claiming that lighter wheels makes more power? I re-read the thread and people are talking about how a reduction in rotational mass changes the readings on a dyno. Nobody is claiming the engine itself is making more power.
#17 |
Because compromise ®
Drives: Red Herring
When I see dyno graphs they usually display power and/or torque. The OP posted a dyno graph. It shows before and after. To me the implication was that if the "numbers" had changed the power had changed. If "a reduction in rotational mass changes the readings on a dyno" what readings are you referring to?
#18 |
Drives: Red Herring
#19 | |
Kuruma Otaku
These are chassis dyno figures. They calculate the net torque as measured at the vehicle's drive wheels. This is NOT a representation of power/torque at the flywheel.
Because titanium. |
#20 | |
Walkin' on sunshine
Drives: Ford BA MKII XR6 ute
Take 2 cars Car 1 stock produces 200hp from the engine produces 160 hp at the wheels Car 2 stock except wheels produces 200hp from the engine produces 162 hp at the wheels You aren't making any more power just increasing the efficiency of the drivetrain.
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
#21 |
Drives: Red Herring
OK! I have just been reading about inertia type dynos. Sorry, it has been about 25 years since I have been in a dyno workshop. I was not familiar with such devices.
#22 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
The difference is probably due to the air filter...
#23 |
Walkin' on sunshine
Or random variation between runs.
#24 |
Drives: Lexus IS-F
#25 |
Drives: 86GTS 6M
So what are the weights of the stock 17" wheels on the fr-s/86?
#26 |
form follows function
Drives: RIP '13 BRZ
#27 |
Drives: 86GTS 6M
Yeah, I found another thread that outlines the weight of all components on the vehicles. The OEM 17" wheels come in at approx 21.4lbs = 9.706 kgs.
Should be very easy to shed some weight there. |
| Few things I found out on the BRZ - extra cigarette lighter outlet | 86design | BRZ First-Gen (2012+) — General Topics | 42 | 04-14-2023 11:56 PM |
| Which 18" wheels will weigh the same or less than the stock wheels? | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 05-16-2013 03:07 PM |
| Forgestar wheels, great wheels at great prices!!!! | IslandImportPerformance | Wheels and Tires | 0 | 06-15-2012 05:03 PM |
| What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 09:35 AM |
| Increased media chatter can only mean one thing... | sieeegel | BRZ First-Gen (2012+) — General Topics | 138 | 03-16-2012 10:19 AM |
