| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: '17 Toyota 86 6MT
Black badges for '17 86?
So apparently Toyota changed the badge size and the black badge kits don't fit the '17 86. I don't like chrome anywhere on the car, so it's a quest to find OEM-ish black badge set. Front is 4.5" wide, rear is 3.5" wide. Don't have part numbers for OEM badges yet - 2017s are not showing up in parts catalogs yet, so can't match it to other Toyotas to extend the search.
Anyone had any luck or am I the weirdo wanting to replace those?
'17 Halo 86 6MT
| The Following User Says Thank You to zoltiz For This Useful Post: | stevesnj (05-15-2017) |
#2 |
Drives: 2015 FR-S
You're definitely a weirdo.
#3 |
Drives: FRS
Spray paint them. It's easy
#4 |
Drives: '17 86
#5 |
Wes
I used the Loden 86 emblem
#6 |
Yeah, if the alternative is $70 or spraypaint, I might go for spraypaint.
'17 Halo 86 6MT
#7 |
Drives: 2017 86 GTS
Plastidip
#8 |
Drives: '17 86
#9 |
Drives: 2017 86 GTS
I did 3 coats, 15 mins between coats, 1 hour before peeling. Edges came away clean but I tried not to get a thick coat around the corners, mostly spraying top down with light coats from each side to make sure the chrome was covered.
I don't know if you care about the fender garnish but it required more coats, 5 I think, to get a nice coverage. The spray can was also getting pretty light so probably wasn't coating as thick. The edges pulled the first time (right side) but I lightly touched it up with a paint brush. The left side I removed the paper straight after the final coat while it was wet to prevent pulling. The inner parts (vents) I just shifted the paper inwards a bit so the edges moved away and then removed it completely once it was dry. I'll be doing it again after I get an opti-coat so I might do up a quick DIY next time.
| The Following User Says Thank You to Byza For This Useful Post: | cat94 (05-15-2017) |
#10 |
Very nice, I hate chrome on this car too and painted my badges on my '16
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#11 |
Drives: 2017 Toyota 86
Seems like FT86SpeedFactory has updated 2017 badges now.
http://www.ft86speedfactory.com/exte...6/emblems.html |
| Black badges from the Hyper-Blue BRZ | Kostamojen | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 06-23-2017 03:09 PM |
| OEM style badges, but black (not blue)? | ixobelle | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 05-16-2017 05:20 PM |
| SCION BLACK BADGES | odessitik | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-30-2015 03:41 AM |
| Black FR-S badges and emblems | godon2894 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 10-26-2014 10:18 AM |
| matte black toyota badges | Raven240 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 07-31-2014 12:20 AM |
