Old 06-30-2012, 12:38 AM   #29
xcelir8brz
Drives: 2013 BRZ Limited
I just finished my dual red 1157 bulb LED Filament rear fog light mod. It looks wicked!
And no worry for the heat, since it is LED!
Check it out:
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
Dadhawk (06-30-2012)
Old 07-01-2012, 04:41 AM   #30
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
looks good but we didn't have to do all that wiring....we just did two wires to the license plate lights and bam done...and there' no wires showing when the trunk is open..
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 07-01-2012, 01:30 PM   #31
xcelir8brz
That's all I did too! 2 Wires. Through the grommet and tapped on the drivers side behind the interior panel the parking light wires (red and black). And when looking from the bottom of the car and up, it looks factory.
Old 07-01-2012, 06:33 PM   #32
percyng
Drives: White BRZ 6MT
Check it out:
Did you hook up the rear fog light with the front fog light switch since BRZ has stock front switch?
percyng is offline   Reply With Quote
Old 07-01-2012, 06:43 PM   #33
xcelir8brz
Just hooked it up to the license plate wire harness.
Sent from my Galaxy Nexus using Tapatalk 2
Old 07-01-2012, 09:33 PM   #34
Razz
Razz's Avatar
Drives: Fast
Good DIY.
Nice to see the Mazda Triangle rotor still alive.
Razz is offline   Reply With Quote
Old 07-02-2012, 02:10 AM   #35
Heero
Heero's Avatar
Drives: 2-door
Check it out:
WOW! That looks beautiful!
How did you get the tail lights like that :/?
Heero is offline   Reply With Quote
Old 07-02-2012, 10:25 AM   #36
xpicer
xpicer's Avatar
Drives: 2013 frs white out
Looks good.
Last night I picked up a socket that allows the 1157 bulb (dual fillament). I also picked up two RED LED bulbs that accept dual fillament wiring and have tested it out on the bench with both fillaments 12v+ activated at the same time. I plan on doing the install tonight/tomorrow and will post pix when complete. This will guarantee the housing will be super bright!
This type:
part number? were did you get it?
xpicer is offline   Reply With Quote
Old 07-02-2012, 02:57 PM   #37
ZILLA
BRZ #575
ZILLA's Avatar
Drives: 2013 BRZ #575
You dont want to use that if you plan on having both filaments on. On a halogen bulb, it WILL get too hot for that little space and can warm/melt your housing. Use LED if you want both filaments powered on at all times.
ZILLA
BRZ #575 SWP Limited
18x8" Drag DR-31 +48 | 235/40/18 | 6000K HID Low/High | Wrapped All Red Tail Lights | Rear Fog + Brake Light Combo Mod [Video]
ZILLA is offline   Reply With Quote
Old 07-02-2012, 03:33 PM   #38
Swancoat
Drives: E92 M3
Originally Posted by FRSpdDmn View Post
I really wish that more cars in the US were equipped with them.
They don't include them as often because European Automakers don't trust Americans to use them properly.
This thread proves them right.
SUPER annoying to see people using these things when it's not foggy. They are incredibly bright and distracting.
If you use 'stance' as a verb, please do not talk to me.
Swancoat is offline   Reply With Quote
Old 07-02-2012, 10:04 PM   #39
LSV8
Drives: Very fast
Nice DIY.. I would use it only when the fog lights are on.
LSV8 is offline   Reply With Quote
The Following User Says Thank You to LSV8 For This Useful Post:
robotvoice (07-08-2012)
Old 07-02-2012, 11:15 PM   #40
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Well if this distracts you when driving, i hope you put your wife in the trunk!
Silverdub is offline   Reply With Quote
Old 07-03-2012, 12:04 AM   #41
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
I agree that in US these rear fog lights are going to cause people behind you to slow down, thinking its a brake light.
I actually want to do just that - pair it with brake lights. F1 style
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
Old 07-03-2012, 04:27 PM   #42
xcelir8brz
FYI - I did use a dual fillament LED (red one 1157) from Autozone.
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
rear seats? EJ20 BRZ First-Gen (2012+) — General Topics 67 11-12-2012 08:15 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 01:47 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 03:08 PM
