Drives: Subaru BRZ
Subaru BRZ premium fog lights
On the BRZ premium it does not come with fog lights, behind the trunk release button and dimmer there is a connector that has been taped off, is this the plug for the stock fogs on the limited model? I also looked in the cabin fuse box and I have the fuses installed for the fog lights, however the LED driver running lights on the premium do not have the pig tail connector that goes to the stock fogs. My question is to get a stock setup would you need the "limited" Driver running lights and a new turn signal stalk to get the fogs to work and have an indication on the instrument cluster that the fog lights are on?
#2 | |
Take a look here: http://www.ft86club.com/forums/showthread.php?t=40153
#3 | |
TRACKBREAD
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Tcoat (05-06-2017) |
#4 |
Well I would guess that the connection would be the same so a FRS button set up should work. Be a pile easier than redoing a stalk.
#5 |
Drives: Subaru BRZ
On the brz limited it is on the stalk, the premium has a different stalk and is missing the pigtail on the daytime running lights, ultimately I'm trying to figure out how to get the fog light indication light on the cluster to work without having to change the stalk. Anyone know what wire controls this indication?
#6 | |
#7 |
Drives: Subaru BRZ
Okay so I need that pigtail to the switch from the unused plug then
#8 |
Drives: '15 Subaru BRZ
#9 | |
Drives: 2016 Subaru BRZ
#10 |
How much was that kit? I keep thinking I need to do that. The last few days we've had some serious fog and they sure would have been handy to have.
#11 |
The fog lights on the BRZ (at least on my 2013 year) are useless.
My wife's 2005 Forester fog lights are far superior. |
#12 |
I paid around ~240?, I will have to check my email to give you the exact price. It was really easy to install, I didn't even have to remove the bumper or the wheels.
| The Following User Says Thank You to Trueweltall For This Useful Post: | gravitylover (05-07-2017) |
#13 |
Drives: 2014 ssm BRZ Limited 6M
Sadly true. Just decoration. I replaced the bulbs with much brighter yellow LEDs from Diode Dynamics and I get a little more useful light for fog, but replacing the entire setup with real fog equipment is the only way to get real performance.
It's only money.
There are worse things to worry over.
#14 |
Drives: 2015 Series.Blue
Yep, factory fogs are only 24w and not even visible that they're on from the drivers's seat. Only way you'd know they were on is the indicator on the dash.
TRS LED fog assembles fixed that for me... |
| BRZ fog lights on premium model | b rawr z | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 02-08-2016 12:20 PM |
| Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure | keioffice | Miscellaneous | 0 | 03-14-2014 08:10 AM |
| FT NJ: BRZ Limited OEM Fog Lights for Premium non-fog | wawawoowee | Exterior Parts (Aero, Lighting, Etc.) | 10 | 02-02-2014 08:53 PM |
| Premium w/ fog lights? | OakmanSmalls | BRZ First-Gen (2012+) — General Topics | 17 | 07-12-2013 10:14 PM |
| Fog Lights - Premium vs Limited | Dionysus | BRZ First-Gen (2012+) — General Topics | 44 | 03-17-2012 03:15 AM |
