CANADA Canada
Old 05-03-2017, 10:21 AM   #1
Gforce
Drives: 2013 Subaru BRZ
Alternative to lowering
If you wish to maintain stock ground clearance but get most of the advantages of lowering springs fit a set of these:
https://mcasuspension.com/traction-mod
Then crash bolts front and rear to get the static camber settings you want.
Cheaper and as effective.
Lowering the CG by an inch really doesn't affect handling much.
Gforce is offline   Reply With Quote
Old 05-03-2017, 11:16 AM   #2
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
What about combining these with some moderate lowering springs (TRD, Eibach Pro-Kit, RCE Yellow) on stock shocks? Best of both worlds?
And I didn't know we could use crash bolts in the rear. Part number? I would like to reduce the negative camber in the rear.
ApexEight is offline   Reply With Quote
Old 05-03-2017, 11:32 AM   #3
dattran86
Driver
Drives: 2013 Whiteout FRS
Whiteline offer a camber bolt kit to adjust the rear camber.
OR go with RCE yellow, it only 20mm and I have never ever scrape on anything so far.
then camber bolt in the front.
and LCA arm in the rear.
dattran86 is offline   Reply With Quote
The Following User Says Thank You to dattran86 For This Useful Post:
D_Thissen (05-03-2017)
Old 05-03-2017, 11:38 AM   #4
D_Thissen
D_Thissen's Avatar
This. RCE yellows, camber bolts up front and SPC rear lower control arms.
Old 05-03-2017, 11:53 AM   #5
wparsons
wparsons's Avatar
That mod doesn't increase spring rate, which is the goal of lowering springs for some people...
Not knocking it, but it definitely isn't a replacement for most people.
flickr
Cole (05-04-2017)
Old 05-03-2017, 09:41 PM   #6
Gforce
You could increase the spring rate while maintaining stock ride height and using the MCA brackets. The BRZ has a pretty effective spring rate from the factory. The lowering springs have to increase the spring rate.
Old 05-03-2017, 09:43 PM   #7
Gforce
Why do you want to reduce rear camber? Factory camber is pretty good, just not always equal right to left, which is the main reason my mechanic fit crash bolts, to equalize rear camber. I asked him to also max it out so it's about 1.8 degrees each side now.
Old 05-03-2017, 09:45 PM   #8
ApexEight
Doesn't the rear gain negative camber upon compression? So to optimize the contact patch in a corner you would want to have little static negative camber to keep as much tire width on the ground as possible. Correct me if I'm wrong! I thought it'd be best to get a lot of front negative camber and close to zero rear negative camber.
Old 05-03-2017, 10:31 PM   #9
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I never knew people got lowering springs for anything other than lowering before this.
The Following 3 Users Say Thank You to PandaSPUR For This Useful Post:
Boomerang (05-04-2017), funwheeldrive (05-04-2017), krayzie (05-04-2017)
Old 05-03-2017, 11:17 PM   #10
Gforce
The chassis is Impreza which is awd. Removing the drive from the front axle means the engineers needed to dial in more understeer.
You want around 1.5 degrees rear camber and about zero front camber for normal street driving. Rear axle camber gain helps stabilize the chassis as you feed in more power. The front axle is limited somewhat by the strut design, although the Porsche Boxster/Cayman initially used four wheel struts and was a superb handler.
Old 05-03-2017, 11:18 PM   #11
Gforce
Lowering changes the static alignment. The reduction in roll moment from lowering the CG is pretty modest. You need higher rate springs when you lower the car to prevent bottoming out.
The MCA traction aids reduce anti squat almost exactly as lowering would do, though MCA recommends their brackets regardless of suspension height.
Old 05-03-2017, 11:58 PM   #12
PandaSPUR
PandaSPUR's Avatar
What the heck is anti squat?
Old 05-04-2017, 08:33 AM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I can see how the MCA suspension mod can maybe lower the rear end a little, but what do you do about lowering the front end?
I wouldn't go with lowering springs because 1) this car doesn't need higher spring rates 2) shorter springs means less suspension travel which negates anything good about a lower CG 3) blown dampers. But I could see moving the pickup down to lower the car and maintaining the stock suspension travel being a good thing if you can lower the front too.
guybo is offline   Reply With Quote
Old 05-04-2017, 10:36 AM   #14
Gforce
It is the force applied to the chassis by the alignment of the suspension arms in a longitudinal direction. It is essentially the same as roll resistance provided by the roll centres but that is across the car.
A quick google will get you a diagram.
Weight transfer is carried into the body by springs acting on the suspension arms. Those suspension arms generate leverage. If the leverage is angled up into the body (as the rear trailing arms on the BRZ are) then weight transfer under acceleration is resisted by the springs but that resistance is partly direct by the spring acting on the spring perch and partly apportioned to the body by the angle of the trailing arm.
Fitting MCA traction aids reduces this leverage effect.
The benefit is gained in transitions, such as accelerating harder out of the corner. More of the weight transfer goes directly through spring compression and less through the trailing arm. The ride is softened, the contact patch is stressed at a slower rate and, if the geometry change is correct, more grip is available to accelerate and corner the car.
MCA did a lot of work testing their brackets to ensure the desired effects actually occur. They do. These brackets make the BRZ easier to accelerate out of the corner. You get more power down to the road earlier. Lowering the suspension has a similar effect.
The drawback is more suspension movement for a given weight transfer. Fitting higher rate dampers to the rear reduces this negative. Lowering springs are stiffer so achieving this effect by lowering springs automatically reduces spring compression effects.
I use my BRZ year round for daily driving. I like the softer ride to the point that I also fitted rear springs from the 2017 model year. That helps traction also. The Edelbrock Supercharger can develop enough torque that reducing anti squat can deliver more grip allowing more throttle to be used earlier.
Another benefit of the MCA brackets whether lowered or not is the transitions effects on the springs are slowed down a bit which, depending on how you like to drive, can make you faster. Some may find this makes the chassis less responsive for the same reason.
There is no perfect setup, just a perfect setup for a particular driver.
A tip on coolant alternative Nessal Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-03-2016 03:34 PM
K4R Alternative? BobBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-10-2015 09:21 PM
CAI alternative question Apyung Engine, Exhaust, Transmission 10 08-09-2014 09:06 PM
BBS LM alternative hanabie Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 10-04-2013 09:40 PM
Alternative key fobs? post_break Scion FR-S / Toyota 86 GT86 General Forum 3 03-20-2013 01:20 PM
