Old 04-29-2017, 08:00 PM   #1
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Tein Flex Z Help
Hey everyone, I recently installed my Tein Flex Z coilovers and noticed the rears were still pretty high up even when fully maxed out. I'm pretty sure these were supposed to drop 3 inches in the back and I don't think I'm near that. There is still a lot of thread left, but it wont lower anymore. I took the bottom cups out and threaded them as much as they went just to be sure. I've been searching for an answer but couldn't find anything. Has anyone else had this problem?
WRB BRZ
BRZSteve is offline   Reply With Quote
Old 04-30-2017, 04:20 AM   #2
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I don't have this problem. My setup before is drop 1.3 front and 1.3 rear, and i barely put one finger between my wheel gap. Even I use Tein recommended setup now is still smaller gap than yours. (0.8 front and 0.7 rear).
FR-Sky is offline   Reply With Quote
Old 04-30-2017, 11:31 AM   #3
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
That's weird. What's your wheel/tire setup?
WRB BRZ
Old 04-30-2017, 12:53 PM   #4
Mackizzle86
Mackizzle86's Avatar
Are you trying to lower it? Your perches are set higher up.
Mackizzle86 is offline   Reply With Quote
Old 04-30-2017, 12:59 PM   #5
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Yes I'm trying to lower it a lot more. I never touched the spring perches I just left it factory spec. Wouldn't altering the perches increase/decrease preload?
WRB BRZ
Old 04-30-2017, 01:10 PM   #6
Trust86
Drives: 2016 Halo FRS
If the threads are maxed out, next thing would be rear LCAs. The slight tire stretch makes the gap more noticeable as well.
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
BRZSteve (04-30-2017)
Old 04-30-2017, 01:26 PM   #7
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
So it's normal to be this high even when maxed out? I was under the impression that maxed out would be when all the perches were touching, since I have so much thread left.
WRB BRZ
Old 04-30-2017, 04:26 PM   #8
FR-Sky
FR-Sky's Avatar
Its a 255/40/17 with -3 camber, so it wouldn't matter much.
I can put 1 finger front, and about 2 fingers rear.
Old 04-30-2017, 04:59 PM   #9
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Yeah my rears are about a 2 finger as well. Just wondering, how much lower are you able to go?
WRB BRZ
Old 04-30-2017, 05:25 PM   #10
FR-Sky
FR-Sky's Avatar
I think I can still drop 1 inches more, but I didn't do that due to 255, it will rub.
The Following User Says Thank You to FR-Sky For This Useful Post:
Old 05-01-2017, 01:36 AM   #11
Kaotic Lazagna
Drives: GR Corolla
Maxed out the front (removed the locking rings), and maxed out the rear plus using some pre-load adjustment.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
BRZSteve (05-01-2017)
Old 05-01-2017, 03:43 PM   #12
sIowbrz
Drives: 2015 brz
Something is wrong my flex z didnt even max out on 18x9.5 +38 is only .5 inch gap i can tuck the tires my rear is -2.3
sIowbrz is offline   Reply With Quote
Old 05-01-2017, 06:25 PM   #13
BRZSteve
BRZSteve's Avatar
Drives: WRB BRZ
Yeah thats pretty much the same set up as me so idk what went wrong. Here's some more photo's because that angle and ground not being even might of made things look worse. Rears are completely maxed out and fronts are perfect because they have some more room to go lower. Only looking for another 1/2 for the rears.
WRB BRZ
Old 05-01-2017, 08:47 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Have you considered contacting Tein USA about this?
If the shock body is bottoming out in the lower bracket, they made a design change in production that has obviously impacted the advertised specs.
My Ohlins from 2013 were a similar situation, I suspect they used parts from another platform to reduce some manufacturing costs.
-alex
Tein Flex A DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 138 04-12-2018 06:23 AM
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 10:33 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
