Old 04-24-2017, 03:51 PM   #57
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Originally Posted by oppiee View Post
So what if this is not fixed. Will there be long term issues?
Yeah. If you don't fix this, it will get louder, abnoxiously loud every time you press the clutch, and you will feel it in the pedal. After some time, the bearing will fail, and you won't be able to go into gear, leaving you stranded wherever you are.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
The Following 2 Users Say Thank You to MurderousPandas For This Useful Post:
funwheeldrive (05-24-2017), psybre (05-25-2017)
Old 04-24-2017, 03:53 PM   #58
MurderousPandas
Originally Posted by stevesnj View Post
Hmm I never paid attention to any noise when I depress the clutch pedal. I will have to take a listen. I suggest if you hear the noise record it for backup if it doesn't make a noise when the dealer listens for it. Worked for me but my dealer is amazingly easy going.
You will hear this noise, it's as obnoxious as serpentine belt squeal. And it does not go away, the bearing is getting heated while not being lubricated anymore, it overheats and destroys itself.
funwheeldrive (05-10-2017), stevesnj (04-24-2017)
Old 04-24-2017, 07:18 PM   #59
stevesnj
stevesnj's Avatar
Well I don't hear anything when I depress the clutch pedal when the car is off or running, I do hear the Throw Out Bearing rotation.
My 2016 Build thread
Old 04-24-2017, 08:26 PM   #60
MurderousPandas
The throwout/release bearing should be pretty quiet if you can hear them. You'll know when it's going.
Old 04-25-2017, 10:53 AM   #61
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
LOL you sound like you're telling a camp fire horror story
At least that's the way i read it.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 04-25-2017, 12:29 PM   #62
MurderousPandas
Well it was pretty spooky when i had mine go lol
Old 04-27-2017, 11:50 AM   #63
Kicker18
Kicker18's Avatar
LMAO!
Kicker18 is offline   Reply With Quote
Old 04-27-2017, 07:23 PM   #64
michaelchatten
Drives: 2016 FR-S RS 2.0
So I do not have a squeak when the pedal is depressed just sitting not running. I have a a grunting noise that you hear and feel when shifting gears while driving. I took the car to the dealer almost a year ago at 2500 miles after buying it new. They drove it and told me there was nothing they could do even after I had told them the throw out bearing is a common issue.
Monday I called a different dealer and told them about the SB that had just come out. I asked if I could bring it in to be evaluated to see if I can have it replaced. They didn't even ask me to bring it in. They ordered that new bearing and I will drop the car off Monday.
I am happy. The clutch has been driving me nuts from the beginning. It's been my only real complaint other then my rims peeling since this is the RS 2.0.
michaelchatten is offline   Reply With Quote
The Following User Says Thank You to michaelchatten For This Useful Post:
Old 05-01-2017, 03:18 PM   #65
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
I am working with my local dealer to address the TOB issue. As we know, there is an updated part and I was able to get my hands on the TSB. Hope it helps others with getting the issue fixed.
Ethereal05 is offline   Reply With Quote
The Following 3 Users Say Thank You to Ethereal05 For This Useful Post:
funwheeldrive (05-10-2017), Sigh-on-Rice (05-02-2017), tato.valverde (05-02-2017)
Old 05-03-2017, 10:19 PM   #66
jtanka
Drives: FRS 10 series
I got mine fixed under power train at 55k but with the older part number.
jtanka is offline   Reply With Quote
Old 05-09-2017, 09:15 PM   #67
jeffsquared
Drives: 2013 FR-S 10 Series #1186
Had mine fixed under warranty at 28k after 3 years and a few weeks. So technically out of the 3 year warranty, but I took the car in before the 3 year mark was up. Took the service manager a few weeks back and forth to talk to his tech support, but later discovered the TSB came out right at about the time we were trying to diagnose the problem.
They found lots of gunk around the throwout bearing, and the bearing was not rotating smoothly. They cleaned and lubricated all pivots and shafts and installed new TOB. The service manager said they used a different lube than the original for the fix. Clutch action is buttery smooth now. Took about two business days to get the job done.
jeffsquared is offline   Reply With Quote
The Following User Says Thank You to jeffsquared For This Useful Post:
Old 05-11-2017, 03:58 PM   #68
Ethereal05
Ethereal05's Avatar
Just to update on my issue. Had a new TOB installed per the TSB and I can confirm that the sound is gone and the clutch is buttery smooth. Such a dramatic change that I would even go as far to say it feels like a completely different car now. Gear engagement improved and is not as rough as it was previously. Highly recommend replacing the factory TOB with this updated part.
Old 05-14-2017, 02:31 PM   #69
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Anyone know of any good dealers in Southern California to get this done?
I took it to cabe Toyota in long Beach and they pretty much said I have to bring it in during the week get confirmation from Toyota, and if Toyota says yes then they start doing the work if they find anythong wrong with the clutch other than the throwout bearing then none of it is covered and I have to pay for everything.
Seems kinda sketchy to me.
Sent from my SM-G900V using Tapatalk
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 05-24-2017, 12:23 PM   #70
funwheeldrive
How difficult would this be to perform at home?
Also, aside from being stranded when the part ultimately fails, is there any risk to the rest of the car by not replacing this piece?
Clutch pedal loud squeak Neekowahhhh Issues | Warranty | Recalls / TSB 617 09-18-2024 01:54 AM
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
