Old 04-23-2017, 10:20 PM   #239
pcporo
No Martians here?
pcporo's Avatar
Drives: FR-S Asphalt MT
Got 150ish on a very long slight downhill. only did it once, pretty sketchy
pcporo is offline   Reply With Quote
The Following User Says Thank You to pcporo For This Useful Post:
FRSapex (04-24-2017)
Old 04-23-2017, 11:10 PM   #240
-Willis-86touge
Drives: Stock
Well now, Willis-86touge, that basic "gear limited" program is just fine ...... but it doesn't factor in the air that the car has to push out of the way .....
Down here on earth, pushing air out of the way is a big factor, especially at higher speeds........
True! Theory and reality can be different tho! reality I hit 155 and now only 137 common sense just tells me there gearing change the power factor so much it actually brought top end down when it should of raised it. In theory I should of been able to hit a high top speed. Air and the car shouldn't have had a difference!
-Willis-86touge is offline   Reply With Quote
The Following User Says Thank You to -Willis-86touge For This Useful Post:
humfrz (04-24-2017)
Old 04-24-2017, 01:21 AM   #241
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Coming for a rock crawling back round. I saw the gearing was all wrong from the start with the 86. I had my old manual, mostly stock,on a 115F day up to 135. My auto car now with OTH and 4.67 rear end. Gets it to 130 fast, top end?
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Old 04-24-2017, 04:08 AM   #242
The gearing on my 2013 MT is just fine ...... for my type of driving.
However, I try to keep in under 130 MPH on the way to the grocery .....
Dadhawk (04-24-2017)
Old 04-24-2017, 07:45 AM   #243
new2subaru
Weight Weenie
Drives: 15 FR-S
And....This is what your car will look like if you hit anything at those speeds.
Old 04-24-2017, 09:25 AM   #244
The gearing is engineered for mileage and the acceleration required to drive like a normal human being in traffic also driving as normal human beings. That does not make it "all wrong".
Celica00 (04-24-2017), humfrz (04-24-2017)
Old 04-24-2017, 03:10 PM   #245
Uplink
Uplink's Avatar
Drives: anything you let me
That's what these cars will look like if you lean on them too hard.
Uplink is offline   Reply With Quote
The Following User Says Thank You to Uplink For This Useful Post:
new2subaru (04-24-2017)
Old 04-24-2017, 04:25 PM   #246
I have a plan, still in the testing phase, to beat that at least on the drag strip. Gonna test any day now...
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
Celica00 (04-24-2017), pcporo (05-03-2017), Tcoat (04-24-2017), Ultramaroon (04-24-2017), Uplink (04-24-2017)
Old 04-24-2017, 04:30 PM   #247
Old 04-24-2017, 04:32 PM   #248
Some canards on the front would fix that...
Old 04-24-2017, 04:35 PM   #249
Comment les canards aideront-ils?
Old 04-24-2017, 04:51 PM   #250
Uplink
Uplink's Avatar
I think that's Mallards.
Old 04-24-2017, 04:54 PM   #251
Oui, ils sont des canards Mallard
Old 04-24-2017, 04:56 PM   #252
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Gearing is fine imo. Pulls to 120 through all gears, no hesitation. 6th is an overdrive, doesn't do anything but mileage.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 07:56 PM
Need For Speed... Really? Texas BRZ Tracking / Autocross / HPDE / Drifting 61 01-12-2013 12:59 AM
Top Speed L3P47 Scion FR-S / Toyota 86 GT86 General Forum 6 12-18-2012 01:06 AM
top speed JLMtm Scion FR-S / Toyota 86 GT86 General Forum 56 10-30-2012 10:23 AM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 11:59 AM
