Old 04-20-2017, 06:29 PM   #1
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
1987 GTS- FINAL EDITION
Do non FRS/BRZ/86 Builds have a home here?
Well I guess that my 8th AE86 was bound to be a special one.
I have been looking for a clean Hatch for a while. I have had 4 Coupes and 3 hatches, so why not get a hatch for number 8 and even things out. I searched far and wide, and eventually found the cleanest of them all right in my backyard!
Here are some pics. I may or may not type up the mod list, but I have 33 pages of receipts, so I may forgo all of that.
The car is still nameless, but here she is:
1987 GTS
White
Unknown miles, but probably a lot.
List of Upgrades:
Odyssey Battery PC 680
Quarter Master Clutch unit with Disc
Slip Yolk
U Joint 1310
Tube Yoke 2-28-277
Flywheel 407401-11
Quaife Sierra Sequential 5 Speed Gearbox
Tow Hook
Wheel Key
Diff Bearings M86649
Diff Bearings M86610
Diff Bearings M88649
Diff Bearings M88610
Diff Seal #14750
Drive Shaft Steady Bearing
Quaife Bellhousing Adapter
Circuit Sports Magnetic Drain Plug
Kumho V710 205/50/15 Race Tires
CS Fuel Pump
BE 131-2085 Water pump
Pertronix Flame Thrower 2 Coil
M1157, 1156 Bulbs, 89F
Mizu R AE86-83 Toyota Aluminum Rad
Mizu FS-AE86-83 Fan Shroud Assembly
Kumho V710 205/50/15 race tires
T3 Rear Traction Brackets
Whiteline BTF35Z Front Swaybar
Whiteline BTR25Z Rear Adjustable Swaybar
PDM Front and Rear Endlinks
BOSCH SBQ200 Headlights
Genesis Battery, Odyssey Terminals
Greddy Shift Knob 14510501
7 Rib Red Top 4AGE Engine
Tomei Cams
Tomei Cam Gears
Clear Cam Gear Cover
Not sure what else (No engine build receipts available)
PIAA 95040 Silicone Wiper
PIAA 95050 Silicone Wiper
PIAA 95045 Silicone Rear Wiper
CS Coolant Tank Reservoir
NTK 24105 02 Sensor
2.5" 304 Stainless 90 degree bend
Vibrant 2630 2.5-3" Transition
3.0 304 stainless 90 bend
3.0 304 Straight
K&N RE0930 Air Filter
Synthetic Power Steering Fluid
Open end Spline Lugnuts
T01B Fuel Tank
BE 173-7904 Ignition Rotor
Tire valves
Argon Filler Rod
BE 052-3001 Front Pinion Seal
Papco M12 x 1.5 52mm Extended wheel studs
M8 X25mm bolts
M6 X16 bolts
M8 Flat Washers
RCI Camlok Race Bolts
Techno Toy Tuning Front AGX Coilovers
Techno Toy Tuning Rear AGX Coilovers
Tecno Toy Tuning Front Camber Plates
Hawk HB203N550 Rear HP+ brake pads
Misc interior pieces
Moog K9320 Steering Rack Boots
Dayco 5050325 Belt
Dayco 5050360
BE 131-2011 Water Pump
BR1 Front Outer Bearings
BR8 Front Inner Bearings
16032 Front Wheel bearing Seals
88506BR Rear Wheel bearings
514000 Rear Wheel Bearings
1955 Rear Wheel Seals
BR35 Rear Diff Bearings
HM88649 Axle Pinion Seal
HM86649 Rear axle Pinion Seal
UEO STYLE Tension Rods
UEO STYLE Inner Tie Rods
UEO STYLE Front Control Arms
UEO STYLE Lateral Rods
UEO STYLE Outer Tie Rods
UEO STYLE Rear Traction Kit 4 Link
Cusco 1.5 Way LSD
CG Locks Nissan
Nagisa Seat Rails
Sparco Rev+ Seats
Paint and Body Work
Clutch Alignment Tool
Slave Cylinder
Clutch Master
Bearing and spacer work
Engine Insulator
Bolts and Nuts
C0TRC-17141-12 TRD
JIC ae86T1-S Bullet 505 Type 1k- Exhaust
Adjustable Aleternator Brackets
Redline Tails
KOUKI JDM Bumpers, brackets, lights, badging
XXR Wheels (I dont think anyone else makes these monstrosities)
Full Welded Cage
Harnesses
Sparco Monza Steering Wheel
And plenty of other stuff I am sure I am missing...
Tanuki is offline   Reply With Quote
The Following 13 Users Say Thank You to Tanuki For This Useful Post:
Atropine (04-20-2017), bcj (04-21-2017), Dimman (04-23-2017), JD001 (04-22-2017), jlugo711 (05-10-2017), NyC Zn6 (05-08-2017), rcm47 (04-21-2017), sato (04-20-2017), slow86 (04-20-2017), swarb (04-20-2017), Takumi788 (05-08-2017), Tcoat (04-20-2017), whataboutbob (04-20-2017)
Old 04-20-2017, 08:44 PM   #2
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Sweeeeet - could probably move it to "Member's Car Journal" sub-forum.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following User Says Thank You to Phantobe For This Useful Post:
Tanuki (04-21-2017)
Old 04-21-2017, 05:08 PM   #3
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
Yeah I couldn't find where the off brand cars go lol.
If a mod can move it I d appreciate it!
Old 04-21-2017, 05:11 PM   #4
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
Story time:
This reminds me of when I found a 78k mile AW-11 (1989 N/A)about 10 miles from my house.
White with blue interior, manual with a hard top.
I loved that car, and I eventually sold it...and I still regret selling it.
Moral of the story: Don't sell this car...you will never find one this good again.
Great find!
Atropine is offline   Reply With Quote
Old 04-22-2017, 01:59 AM   #5
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
Originally Posted by Atropine View Post
Story time:
Great find!
lol exactly what I said the last time I sold one this clean. They come up every now and then, but yeah, I totally hear ya!
Here is my last one I sold:
Old 04-22-2017, 02:18 AM   #6
Kaotic Lazagna
Drives: GR Corolla
Very nice, clean unit. Was it stock when you got it?
Old 04-22-2017, 02:38 AM   #7
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
No sir, but it also wasnt this far either. Cars this old are hard to find without some tinkering done. Well especially not a clean one.
The Following User Says Thank You to Tanuki For This Useful Post:
Kaotic Lazagna (04-22-2017)
Old 04-22-2017, 10:20 AM   #8
Teseo
Drives: frs
Any future plans for it?
Old 04-23-2017, 04:41 PM   #9
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
Yes I need to make it mine, but nothing too drastic.
Old 05-08-2017, 01:00 PM   #10
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
The Following 2 Users Say Thank You to Tanuki For This Useful Post:
daiheadjai (05-10-2017), Tcoat (05-08-2017)
Old 05-08-2017, 01:15 PM   #11
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
Beautiful! I'd still love to pick one of these up.
djwishbone is offline   Reply With Quote
Old 05-08-2017, 07:13 PM   #12
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
They are starting to get really expensive! I am wanting another FRS/86/ BRZ now to go with it!
Old 05-08-2017, 07:14 PM   #13
djwishbone
Last Starfighter
I've noticed! I hardly ever see them for sale here anymore. Might as well buy an imported R32!
Old 05-08-2017, 07:21 PM   #14
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
I paid as much as an imported R32. These are more of my heritage so I went this route. With cars you just have to get what you like
1987 E30 BMW 325is, full suspension refresh, GC coilovers, much more PR138 Cars for Sale/Trade 2 11-26-2016 09:22 PM
Help please.. Looking to get Nameless ... Mikem53 Engine, Exhaust, Transmission 15 11-28-2013 02:06 PM
Nameless Admired Engine, Exhaust, Transmission 40 07-20-2013 03:31 PM
AE86 vs AE82: 1987 BTCC OldSkoolToys Other Vehicles & General Automotive Discussions 8 05-10-2011 04:26 AM
