Old 04-17-2017, 12:28 PM   #1
HemiGoesHam
Drives: 2013 Subaru Brz
How much will it cost to turbo my car?
Hello,
I am looking into buy a speed by design turbo kit, the SBD500X with the pre welded oil pan. My engine is stock.
https://spdbydesign.com/product/sbd5...-brzscion-frs/
What else do I need to have the car fully operational, no problem, turbo, and making around +100hp?
HemiGoesHam is offline   Reply With Quote
Old 04-17-2017, 12:38 PM   #2
StraightOuttaCanadaEh
Wes
If you want just 100 hp then you're okay with the 400X. The kit is plug and play. All the requirements are outlined when you purchase it. You need either an ecutek or OFT tune and there are certain recommended parts like crash bar and stage 2 clutch, but that's pretty much it.
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Boris_Petrov (08-30-2019), HemiGoesHam (04-17-2017)
Old 04-17-2017, 12:54 PM   #3
denso
Drives: 86
For +100hp (so 300hp at the Engine) you basicly need "just" a turbo kit. Supporting mods like an oil cooler are recomended.
+ an ECU reflash, ECUtek or OFT tune for your application.
denso is offline   Reply With Quote
The Following User Says Thank You to denso For This Useful Post:
Old 04-17-2017, 01:04 PM   #4
HemiGoesHam
So I don't need to wrap the headers? I'm fine with just the turbo kit and a ecutek?
Old 04-17-2017, 01:30 PM   #5
Are you able to do the work yourself? Are you proficient enough to be able to repair things if/when they go wrong? Can you have the car down for long periods? Why such a specific HP number goal?
Based upon you questions I am not sure that you understand the implications of turboing a car to 100hp above the engineered rating. Contrary to what has been said here kits are not actually "plug and play" and require some knowledge to install and maintain.
Cole (04-18-2017), guybo (04-17-2017), HemiGoesHam (04-17-2017), Sportsguy83 (04-18-2017), Ultramaroon (04-19-2017)
Old 04-17-2017, 01:50 PM   #6
Chronology
Drives: 13' Satin White Pearl BRZ
So far I have some budget numbers, I am around 12k for a full blown FI setup, this exceeds your request for +100 hp, but gives you an idea to run a FI setup that is LESS troublesome. (IMO)
*FI Package (Turbo or Supercharger)
*Oil Cooler
*FA20 internals
*Radiator upgrade
*Clutch + fork
*Flywheel
*Injectors
*Fuel pump
*All fluids replaced and or upgraded* This is a reoccurring cost
*Ecutek
*Custom Tune + E85
*E85 flexfuel
*Replacement brake system *Pads/Rotors are a reoccurring cost
*Upgraded tires/rims to support the power *tires are a reoccurring cost
*Monitoring - Basic will be done with a Nexus 7 + Torque app, detailed monitoring will be done via ECUTek
Low boost I was looking around 350-400, high boost around 600+ (This is at the ground not at the crank)
IF I plan on staying within high boost, I would look to upgrade the following:
*Axels
*Drive shaft
Mind you I have been piecing this together and prioritized safety before speed, and understanding when monitoring what to look.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
The Following 2 Users Say Thank You to Chronology For This Useful Post:
smg1138 (04-17-2017), Tcoat (04-17-2017)
Old 04-17-2017, 02:01 PM   #7
*Oil Cooler
*FA20 internals
*Radiator upgrade
*Clutch + fork
*Flywheel
*Injectors
*Fuel pump
*Ecutek
*Custom Tune + E85
*E85 flexfuel
*Axels
*Drive shaft
Now this ^ is thinking it through and understanding how everything works together.
Old 04-17-2017, 02:23 PM   #8
Chronology
I have personally made enough mistakes to buy another car (different platform) so this time around, its planned, researched and costs are factored in a 10-year plan. I keep my cars 10 years at minimum, so maintenance, and understanding has to be calculated and understood.
Old 04-17-2017, 04:10 PM   #9
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Understanding has to be understood?
Outstanding
Scrappydoo is offline   Reply With Quote
The Following 3 Users Say Thank You to Scrappydoo For This Useful Post:
Boris_Petrov (08-30-2019), olsonpg (04-18-2017), scottryan (04-24-2020)
Old 04-17-2017, 06:11 PM   #10
Chronology
Outstanding
It's been a long day!!! I just want to jump in the car and take a drive.
Boris_Petrov (08-30-2019), Scrappydoo (04-18-2017)
Old 04-17-2017, 10:38 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
$3.50
The Following 5 Users Say Thank You to mav1178 For This Useful Post:
Boris_Petrov (08-30-2019), Cole (04-18-2017), Flame9020 (05-06-2017), NickDC88 (04-18-2017), Tectoniic (04-20-2017)
Old 04-17-2017, 11:07 PM   #12
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Im about 14k here and thats not including the engine.
Dont forget engine, trans and diff mounts or the car will hate you. I also recommend an exhaust.
I dont think the factory drive shaft breaks but the axles sure as hell do with enough rubber.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-18-2017, 03:08 AM   #13
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I'm at about +100 whp with the Edelbrock Supercharger.
Technically this is the "cheaper" option as in the short run Superchargers require less maintenance from the get go and as a DD dont require as much. They also tend to be a bit more "bolt on".
But as a few of the other members here have said. It's not as simple as slapping on a kit, getting a tune and you are good to go. You have to think long term.
What kind of stress is it putting on my engine?
Or Clutch?
Transmission?
How do i drive the car already? Hard? Soft and slow?
Will i regret not buying something that could potentially be more powerful?
For me i spent 6000$ on my kit. That is including install, supporting mods and custom tune.
You have to remember there are costs outside of just the kit itself.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 3 Users Say Thank You to Xxyion For This Useful Post:
D_Thissen (04-18-2017), GsxrMe (04-18-2017), Tcoat (04-18-2017)
Old 04-18-2017, 10:08 AM   #14
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
If you choose a reputable kit, install it carefully, understand all of the pieces and how each functions, and spend a good amount of time reading the forums and recommendations from the manufacturer you should be OK. Your best bet is to buy a used kit in my opinion. I've seen SBD kits go for anywhere from 1.5k to 3.5k used. At ~100 increased wheel horsepower you may need an oil cooler, and potentially clutch. If you don't increase boost more than that you should be OK without additional supporting mods (although things like catch cans or a built engine will always increase engine longevity at any increased power level).
You don't need engine/diff/trans mounts or axles or drive-shafts at the power level you are looking at. You don't need a whole slew of track-ready upgrades (unless you are planning on doing more than daily driving). ~100 extra horsepower isn't going to beat this car up (although there is always risk of failure, even when stock). The problems occur when you get tired of the extra 100 horsepower and want to push the limits more. Then you need to consider Chronology's list of extras.
If you do it right, and are willing to wait for a deal, you can go FI with either a turbo or SC for under 3-4k. Personally, I'm happily boosted at ~100-125 extra wheel horsepower with a total investment of 3k. I was able to do this by selling my OFT (to offset the cost of the ecutek license), borrowing an ecutek cable, buying a used SC kit, installing myself, and making smart choices on aftermarket parts. You don't need to pour tons of money into this car if you try to work from the used market.
The only things I would add:
1. Make SURE you choose a reputable tuner. The tune is the MOST important part of a boosted setup. If the tune is no good, it doesn't matter what other supporting mods you have in place. A good tune can limit risk to the engine and make your experience much better.
2. If you go with a turbo setup, be prepared to add gauges/hard-ware fail-safes. Don't rely solely on software. It takes just a few seconds of overboost to ruin a good time.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
BRZach (04-19-2017)
Cost of Supercharger or Turbo and installation. Wishbone32 Forced Induction 11 04-15-2015 09:21 AM
FA20CLUB TURBO KIT GREAT POWER AFFORDABLE COST $3500 FA20Club.com Forced Induction 92 02-13-2014 11:50 PM
What does it cost you to race? (Cost of racing) rice_classic Tracking / Autocross / HPDE / Drifting 63 12-27-2013 10:54 AM
cl cost of frs Dragonist Scion FR-S / Toyota 86 GT86 General Forum 15 08-22-2012 05:45 PM
Would you buy ft-86 if it cost $28k? ryude Scion FR-S / Toyota 86 GT86 General Forum 31 12-28-2010 05:26 PM
