Old 04-17-2017, 05:41 AM   #1
Chrismilicevic
Drives: Silver
Subwoofer Help
Hello!
Im currently trying to install a Kicker Subwoofer into my Toyota 86 at the moment.
My Sub is: kicker 40cwr124 4ohm Sub (In Sealed Box)
Even though the Kicker is a 4ohm sub it has a switch that makes it ether 2 or 8?
Like This: https://images.sonicelectronix.com/i...n/40cwr124.jpg
My question is can the sub run at 4ohms (since it is a 4ohm sub)? Or will I have to match it to 2ohms power when matching for an amplifier, since the switch states 2ohms?
Thanks Guys!
Chrismilicevic is offline   Reply With Quote
Old 04-17-2017, 06:02 AM   #2
gramicci101
Off Topic
It has dual 4 ohm voice coils. If the coils are wired in series it presents an 8 ohm load to the amp. If they're wired in parallel it presents a 2 ohm load. The button just stupid-proofs the wiring. You have to choose one or the other; you can't wire just one 4 ohm coil. Fortunately, 2 ohm stable amps are plentiful.
kicker, ohms help, subwoofer
Brz subwoofer in an Frs?? slyder Electronics | Audio | NAV | Infotainment 2 05-07-2016 11:56 PM
Subwoofer now available Opie Electronics | Audio | NAV | Infotainment 97 08-15-2015 08:23 PM
Subwoofer box Bhim NY / NJ / CT / PA 5 03-13-2015 03:21 PM
4 Subwoofer fit? Iceblazer Electronics | Audio | NAV | Infotainment 19 11-27-2013 08:17 PM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
