Northwest AK, ID, OR, WA
Old 03-28-2017, 12:40 PM   #1
rtalich
Drives: 2015 BRZ Series.Blue
lowering spring install
This seems pretty outrageous and just had to share... I've always intended to do the install myself, I was just curious to see how much a certain shop would charge. No joke... $1098.13!! All labor... I always like getting quotes like this to remind me of why I do the work myself.
rtalich is offline   Reply With Quote
The Following 2 Users Say Thank You to rtalich For This Useful Post:
IgamaS (03-28-2017), Tcoat (11-13-2017)
Old 03-28-2017, 12:43 PM   #2
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Ask the same shop for a quote on swapping spark plugs
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 03-28-2017, 12:45 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Considering how easy it is on our cars that is highway robbery lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-28-2017, 05:18 PM   #4
IgamaS
Drives: 2015 Whiteout FRS
That's stupid, but hey if you need help I'm down to help out.
IgamaS is offline   Reply With Quote
Old 03-31-2017, 10:14 PM   #5
Jdex420
Drives: 2014 FR-S
Before I went down to darrendriven's house in Portland I went to Toyota for a quote. 10 hours. 2.5 a corner. When he told me that I laughed and walked out. Darren did it with jacks in 53 minutes!
Jdex420 is offline   Reply With Quote
The Following 3 Users Say Thank You to Jdex420 For This Useful Post:
Jmonty (11-14-2017), RobertPaulson (04-03-2017), Teseo (01-28-2018)
Old 10-06-2017, 12:29 PM   #6
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
(I'm not NW, just searched lowering springs and this was most recent post)
Similar experience. Just got back from the dealership for service boost work. I previously bought TRD springs from them for $235, which seemed decent. Asked them to install springs at the same time as oil change and whatnot. I guess they didn't want to do it. Gave a quote of $1175.15. I LOL'd and said no.
BigHugeFatGuy is offline   Reply With Quote
Old 10-06-2017, 12:40 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Damn, and I though it was expensive when I got quoted $550 for coilover install and alignment
Old 11-13-2017, 11:46 AM   #8
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
Trd springs
I'm a service advisor at Lexus and I checked the labor time on the install it is 7.5 hours but it really takes a master tech about 3 hours including the alignment. Don't know why it is so much labor but it is. The only part that is a pain in the ass is compressing the springs. I am going to do mine myself and save the money just wander if I should just do a coil over set instead?
Joeyb860 is offline   Reply With Quote
Old 11-13-2017, 11:57 AM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I do a lot of work for locals, and on these cars lowering springs or coilover install with a "string*" alignment is $400. If you bring me POS parts it's $500, if you buy the suspension through me it's $350. I've found the price variance helps a lot ensuring people run decent stuff, and ensures I don't have to make adjustments later on due to a junky component failure, or doing it again because people aren't happy with it.
I use one of these, and it saves SO MUCH time setting toe compared to actually using a string. It's paid for itself in times I've had to get out from under the car again and again and again: http://www.killertools.com/shop/shop...art903m-detail
Time for a lift next...
JazzleSAURUS is offline   Reply With Quote
Old 11-13-2017, 07:01 PM   #10
finch1750
finch1750's Avatar
Read the 2 DIYs, you can take the stock springs off and install the new springs using the cars weight instead of the compressors. Still safe and way less work.
Not bad, I mean for alignment and setting ride height it really does take a shop hours so not an overcharge. More so I just do my own work usually so $550 compared to diy install and a $80 custom alignment was a bit of a jump lol
I wish I had a garage to do custom alignments, but Im also not detail oriented enough to do it enough to warrant the tools anyway haha
Old 11-13-2017, 08:13 PM   #11
JazzleSAURUS
Not bad, I for alignment and setting ride height it really does take shop hours so not an overcharge. More just I do my own work usually so $550 compared to diy install and a $80 custom alignment was a bit of a jump lol
I wish I had angarage to do custom alignments, but Im also not detail oriented enough to do it enough to warrant the tools anyway haha
Totally understood, not a lot of people are, (I'm saying that based on the quality of work I see coming in on a *LOT* of jobs. It makes me rethink what I see on a lot of forum posts... "This job can be completed by even the most shadetree of mechanics in a few short hours" Well friends, I'm here to tell you I've seen TERRIBLY botched strut bar installs. It happens, we all have to start somewhere, and not everyone is cut out to turn a wrench. Heck, some days I have to sit back and close my eyes and contemplate fire saleing all my snap on stuff.
Old 01-28-2018, 03:00 PM   #12
Micmac
Drives: Fr-s snowflake white
Down in Eugene I got quotes ranging from $600 just for spring install, no alignment. Then I called the guy at the alignment shop, he quoted $340 with alignment. He said if I installed the springs he'd charge $85 for alignment. I think he will get the job.
Micmac is offline   Reply With Quote
Lowering Spring Install?!?! FNCrazy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-12-2016 03:32 PM
TireDiscounter Qoute for Lowering Spring Install raven1231 Scion FR-S / Toyota 86 GT86 General Forum 19 04-10-2015 10:00 AM
RS-R SUS lowering spring reviews? jvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-24-2014 01:44 PM
WTB Lowering Spring FRS_Jack Want-To-Buy Requests 0 02-27-2014 01:48 AM
North FL: Lowering Spring install BlueDubbinTDI Southeast 1 01-01-2014 08:12 PM
