Old 03-27-2017, 05:54 PM   #15
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Agreed!
So here's my understanding of it....
The parts all go back to the wooden wheel.
Any wheel is defined as "a circular object that revolves on an axle and is fixed below a vehicle or other object to enable it to move easily over the ground."
In bygone days this consisted of a hub, spokes, rim (or hoop) and sometimes a protective banding (tire), all of which combined made a wheel.
On a car, there is a tire, rim, hub and the equivalent of spokes (everything inside the rim that connects it to the hub just like on a wooden wheel). All that together makes a wheel.
So, technically, neither rim nor wheel is correct when talking about what just the middle metal portion. The wheel is still the tire plus everything required to hold the tire on the axle, and a rim is the part where the tire is attached (like the banding on a wagon wheel).
On the bright side, no one calls them hoops (which is the same as a rim)
Now, all that said, I use the terms wheel, rims, mags interchangeably for the non-tire portion of the wheel. If I think about it I usually refer to something that needs a hubcap as a rim (steelies), something chrome, bright and shiny as "mags" and anything else as a wheel (basically non-chrome looking hubs).
I typically only refer to the actual tire as a tire, and I refer to the whole as a wheel.
For example, if I have a flat I'll say "I need to change my tire" because it is only the tire that is broken. But if that results in a need to replace the entire unit I'll say "Geez (*&@#*() I have to replace the whole @#(*&)#@$( wheel now".
It is all subjective anyway and everyone pretty much knows what everyone means.
It's tyre silly.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Dadhawk (03-27-2017)
Old 05-29-2017, 01:07 PM   #16
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Any more info on these wheels exactly the style im looking for. Mostly interested in the weight doesn't look like they are flow formed but have side knotches to reduce cast weight.
SuperTom is offline   Reply With Quote
FS: OEM tires and rims - Stock rims and tires Webster10 Wheels and Tires 14 11-16-2015 06:50 PM
Trade: BRZ stock rims + Michelin Pilot Super Sport for stock rims & tires + $600 Ferrari Canada Classifieds 7 05-12-2015 03:45 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 03:33 PM
Any one got black bbs rims for sale or any sexy black rims Anthony7515 BRZ First-Gen (2012+) — General Topics 6 11-21-2013 01:23 PM
