Old 10-29-2016, 01:52 PM   #57
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
No luck with the playlist. I'm going to read the manual one more time. FOAD, Pioneer.
PetrolioBenzina is offline   Reply With Quote
Old 10-29-2016, 02:01 PM   #58
PetrolioBenzina
Drives: 17 86
Originally Posted by Mr. Kurtz View Post
The manual for the 2017 headunit is available on Toyota's site.
http://www.toyota.com/t3Portal/docum...f/OM1786da.pdf
http://www.toyota.com/t3Portal/docum...f/OM17daQG.pdf
I can't help with your question, I use Bluetooth and streaming music services exclusively.
It really looks like this junk is incapable of jumping to the next album in the list, either manually or on its own. What f-ing moron came up with that idea?
Old 10-30-2016, 12:55 AM   #59
Cosmo Kramer
Cosmo Kramer's Avatar
Drives: 2017 toyota 86 oceanic
2017 toyota 86 purchased tuesday this past week. ive been having issues with my ipod freezing completely and having to restart the ipod or then the screen restarts constantly it did two times before i decided to record it. anyone know what may be the problem? thanks
[ame="http://youtu.be/zestURlbypw"]http://youtu.be/zestURlbypw[/ame]
Cosmo Kramer is offline   Reply With Quote
Old 10-30-2016, 07:29 PM   #60
PetrolioBenzina
Drives: 17 86
I believe the issue is that this head unit is a piece of shit. I'm a single-issue hater, though. It's OK otherwise for me.
Old 03-22-2017, 08:00 PM   #61
Scourge
Agent 86
Drives: 2017 Toyota 86
So, if anyone cares, the model number for the MY17 Toyota 86 head unit is PT546-00170. Never pulled it out but from the front, looks just like the PT546-00160 minus the Scion branding.
Scourge is offline   Reply With Quote
The Following User Says Thank You to Scourge For This Useful Post:
Tcoat (03-23-2017)
Old 03-23-2017, 01:28 PM   #62
PetrolioBenzina
Drives: 17 86
It still sucks.
Old 03-24-2017, 02:09 PM   #63
rkaywhodat
Drives: 2017 Toyota 86 Halo
Yeah I have it, I don't like the touch screen on it. I won't replace it since Bluetooth works fine and that's all I care about.
Sent from my Nexus 6P using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 04-05-2017, 12:06 PM   #64
Scourge
Agent 86
I'm not an audiophile. I didn't buy this car to listen to music. However, I'm not so opposed to throwing on a navigation module for additional functionality. One reason is because the mic (for Bluetooth calls) and the rear view camera (not that I use it) are already integrated into the car. Another is I've seen so many hack jobs on the used cars I've bought... Seriously bad hack jobs... For example, they'll wire things directly into the new head unit despite readily available adapter connectors/pigtails for that car. I don't see myself selling this car any time soon but if I do, I'd like the new owner to have some peace of mind that the head unit install wasn't a hack.
Old 04-24-2017, 03:02 AM   #65
ir1064
Drives: 6MT, C7P
[QUOTE=Scourge;2877554]So, if anyone cares, the model number for the MY17 Toyota 86 head unit is PT546-00170. Never pulled it out but from the front, looks just like the PT546-00160 minus the Scion branding.
Hi Scourge, i recently brought the same PT546-00170 off eBay, but i couldn't get the backup camera working, can you tell me once you press the Setting->Display, do you see both "General" AND "Camera" option just like page 131, cause i only have "General" on my screen, even i have reverse signal go connect to pin 2 and RCA on 24 pin connector, it's driving me nuts
ir1064 is offline   Reply With Quote
Old 04-26-2017, 01:14 AM   #66
rkaywhodat
I was looking into that and found it was $1300 for nav add on and they wanted $300 for map updates. Then I went to eBay and bought a Schose Magic Mount and attached to my vent on the driver's side and use Google maps on my phone as a $40 solution.
Old 04-26-2017, 02:01 PM   #67
willimusk
willimusk's Avatar
Drives: 2017 BRZ PP CWP
Have you tried using a different cable? It's a cheap and easy way to eliminate one possible cause of the problem.
willimusk is offline   Reply With Quote
Old 09-20-2017, 03:49 PM   #68
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
See my Kenwood update
Originally Posted by PetrolioBenzina View Post
All I really want it to do is play the next album in directory order without intervention. That's all I want, even for Christmas. If I can get the stock unit to do that I'll be happy. What moron would design a head unit that requires you to actually look at it while driving?
000BRZ
In my Previous posts I replaced The 2017 BRZ Headset with a Kenwood DNX893S (there is a newer one coming out).
If you use this unit Update the operating system to the latest 2017 version with at least a 8GB SDX SD card. and also the maps...IT'S FREE!!!
With idatalink & Maestro 99% works.
Uses Sirius Antenna(DON'T BUY ONE)
Steering Wheel control work (now) old BRZ\FRS there is a control kit
Appleplay and Andriod Play work
OEM rear camera works, Kenwood Front Camera works(use to front park so I don't hit my lip)
HAVE TO USE KENWOOD MICROPHONE (OEM WILL NOT WORK)
Garmin MAPS is heaven sent. With the 2017 Operating System update the graphics are greatly improved too.
Spacers for the sides come from Crutchfield
Getting most car data, gauges system info, tire Pressure and TEMPERATURE
Has every option for controlling music quality, crossover, special settings
(I added a 75 WATT Kenwood AMP and all new Alpine speakers
I used a 2015 dash trim to replace the trapezoidal trim (the right side panel is shorter than the 2017 (so you HAVE to replace both, AND if your stupid enough to install a 2017 headset in a 2013-2016 YOU NEED BOTH THE 2017 HS TRIM AND SIDE PANELS)
The leather peels off the 2017 right panel and you can wrap it on the older panel by removing 1/32" off the straight side (see my photo) You cad also buy any color and stitching leather for $95 on Amazon to wrap both.
You can play DVD's, CD's run music off the SD card, also use a USB memory clip to Program update and music
The updating is as simple as apple pie if you follow the instructions
Hope you enjoy my experience
(I highly recommend you use a Kenwood/idatalink/Maestro experienced installer unless you are an MIT Post Doctorate Nuclear Physicist.
007BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 007BRZ For This Useful Post:
chaoskaze (09-20-2017), mrderp (09-20-2017)
Old 01-26-2018, 12:57 AM   #69
2017Halo860
Drives: 2017 Toyota 860
Does the stock radio (AXLP-Q17U) on ‘17 Toyota 860 have a USB port in the rear (in addition to the front) to hook up a SiriusXM SXV300 sat tuner?
2017Halo860 is offline   Reply With Quote
Old 01-31-2018, 01:11 AM   #70
Zentec
I understood about 3 words of all that! I like CDs because they are easy to slap in and they remind me of little albums.
Our taste in music could not be more different if we planned it that way.
I like physical too but there is no way my vinyl records would not fit in the car.
Zentec is offline   Reply With Quote
Joying Android 4.4.4 Kitkat Toyota Head Unit Griffon Electronics | Audio | NAV | Infotainment 542 09-12-2017 11:49 PM
2017 Toyota 86 head unit help..... PetrolioBenzina Electronics | Audio | NAV | Infotainment 0 10-16-2016 10:01 PM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 04:37 PM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 12:57 PM
Toyota 86 GTS stock head unit won't turn on. ZN6_88 AUSTRALIA 3 04-23-2014 09:50 AM
