Old 06-29-2012, 03:57 PM   #449
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by R8 View Post
P0018 TOYOTA - Crankshaft Position Camshaft Position Correlation Bank 2 Sensor 'A'
Possible causes
- Dirty Oil
- Variable Valve Timing (VVT) sensor circuit is open or shorted
- Variable Valve Timing (VVT) sensor poor electrical connection
- Faulty Variable Valve Timing (VVT) sensor
- Damaged ECM
danthedirt said this is almost the same exact code that was pulled in his thread here (he had P0019):
http://www.ft86club.com/forums/showt...t=10069&page=5
Old 06-29-2012, 04:28 PM   #450
ahausheer
Re-member
Drives: Toyota camry
Just a thought: To put pressure on Toyota and Subaru we need to start looking at this issue as a ''Safety Issue'' and not simply an idle issue. If your car has the potential to crap out while driving I would say safety is involved. Its not like the radio isn't working, its an unpredictable drive-ability issue. Heres the headline, '' FR-S owner's engine crapped out while driving, the loss of power steering and power brakes lead to an accident''. This could be unintended acceleration round 2. They need to figure this out, which im sure they are. But for me at least I will follow this thread regarding the ''safety'' issue.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-29-2012, 05:38 PM   #451
TuxedoCartman
Drives: '13 86
Okay, whoa... everybody calm down! Just chill for a minute. All this talk of "putting pressure on Toyota/ Scion/ Subaru" to "do something about this problem!" or "make more of an effort to fix it!"...what are you expecting them to do?
Has anybody encountered any REAL resistance from corporate over the problems with this car? To date, I haven't heard of Toyota turning customers away at the door, saying "Cricket noises and rough idling are part of the soul of owning a sports car; it's a feature, not a defect." Rather, what stood out to me was that they're flying engineers over from Japan to look at cars having this problem, to try to get to the bottom of it.
I know unknown engine problems are scary, but you guys gotta remember one very important thing: this car has been on sale in America (to the general public) for less than a month. A MONTH!!! So if you're expecting them to diagnose a problem that's somehow slipped through the cracks in their thousands of hours of testing, device a fix, and have it distributed to dealerships across the country in that amount of time (to say nothing of the fact that this didn't show up immediately, or the communications delays between service centers and corporate)... you're in for a LOT of disappointment.
Patience, guys....
TuxedoCartman is offline   Reply With Quote
The Following 3 Users Say Thank You to TuxedoCartman For This Useful Post:
Chewie4299 (06-29-2012), eriktherod (06-29-2012), ZmZMWagon (06-29-2012)
Old 06-29-2012, 05:43 PM   #452
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
^ This.
Not to mention that a solution to the problem has to be tested and verified. After all, the problem didn't exist when they sent the car out for production (at least we assume). The whole testing and distribution of parts/service material will take at least another month to cover the large markets.
eriktherod is offline   Reply With Quote
Old 06-29-2012, 05:48 PM   #453
ahausheer
Re-member
^ you are right. I rescind my overreaction.
The Following User Says Thank You to ahausheer For This Useful Post:
TuxedoCartman (06-29-2012)
Old 06-29-2012, 06:04 PM   #454
V1B
V1B's Avatar
Drives: Scion FRS
Just curious what do u feel that u determine rough iddle?
V1B is offline   Reply With Quote
Old 06-29-2012, 06:15 PM   #455
KeepGuessing
Drives: e30 150 deville etc etc
Nissan had the SAME thing happen to the Maxima a few years back state side, and Toyota did a with the Celica when it's popularity flared up state side.
In the end, they did absolutely nothing to correct the issues, they swept it under the rug and eventually released a "replacement" model, ie the next one in the lineup...Chances are the same thing will happen here... A good 20-30% of customers will have problems...10-15% will actually vocalize their problems..... 5% will see results from Toyota/subaru.... Then the mk2/2.0/2nd gen will be released making 10 more horsepower and have the "unrecognized problem" corrected or at least an ATTEMPT at correcting...If they fail to fix it the 2nd time around, then you guys will have some legs to stand on to get it fixed au gratis.
If BMW managed to fix their High pressure fuel pumps the 2nd time they tried, no one would have gotten any kind of "free ecu update and replacement" on their 335i's....
Tis the way the world works.
KeepGuessing is offline   Reply With Quote
The Following User Says Thank You to KeepGuessing For This Useful Post:
csaba (06-29-2012)
Old 06-29-2012, 06:58 PM   #456
FRSCoupe
Drives: Toyota
I think you are wrong, it's still very early with few units sold, if the manufacturer can identify the problem whether is defective parts or design, they can fix it.
The engines that are already out there can still get recalled.
FRSCoupe is offline   Reply With Quote
Old 06-29-2012, 07:15 PM   #457
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Im just gonna get a prius. And save the earth.
driftartist is offline   Reply With Quote
The Following User Says Thank You to driftartist For This Useful Post:
adprokid (06-29-2012)
Old 06-29-2012, 07:35 PM   #458
dirk_diggler
Drives: 2011 BMW 328i Coupe M-Sport 6MT
It's like putting your balls in a jar just because you got married. Lol
Jokes aside, a slightly used 3 series is starting to look good.
dirk_diggler is offline   Reply With Quote
Old 06-29-2012, 09:02 PM   #459
Lonewolf
Lonewolf's Avatar
Drives: Moped
Only if you want more expensive problems...
Old 06-29-2012, 09:12 PM   #460
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Actually, while the Prius may save you money on gas it actually does more damage to the environment to produce them than it protects during its service life.
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline   Reply With Quote
Old 06-29-2012, 09:24 PM   #461
KeepGuessing
Prius battery packs = more terrible than a car burning a quart of oil a week over the span of ~10 years...
There would be no point in doing so unless there is a potential for financial loss due to it.
Like i said, it happened with nissan and toyota and i'm sure plenty of other companies...Recalling the engine/car would right out of the gate, hurt sales. Whether you understand it as a smart consumer or not..Attaching the word "Recall" to a new car will cause a drop in sales....Unless there is substantial enough reasoning to do a recall (as in it will hurt people&profits in the long run) the most you'll see is a "service bulletin" in a few months for something a dealership might give you a "deal" on.
Ponder this for a moment will you?
In this forum alone we've got a good strong share of owners who aren't blinded by their pockets or purchase..
We get to see first hand multiple owners takes on both the positives and negatives.. We have this idle issue being mentioned, we have noises being made from mechanical issues in the pulley system. Yet NONE of these issues will ever be brought up in a major publication, so they won't be addressed because the masses won't hear about it.
But the MOST interesting thing (to me at least) is the seat and it's support.
I was flabbergasted when i read the thread on lumbar supper/ not comfortable. Mainly because every article every report every opinion every comparison everything...The dozens upon dozens of write ups on this car... And Not a SINGLE person has mentioned that the seat can cause some severe back pain due to little to no support. There is NO way that among all the people who tried this out, not a single person left with this uncomfortable experience.
Had it NOT been for that SINGLE thread it will probably continually go absolutely un-noticed.
But that's a prime example that REAL clarity on the fit/function/fun of this car will NEVER be properly illustrated by test drivers/journalists...
I know that's somewhat of a tangent, but that illustrates my point that if it doesn't SELL cars or cause cars to NOT sell...It won't get mentioned
Old 06-29-2012, 09:26 PM   #462
dirk_diggler
I am thinking E92 NA, so no oil burning.
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-29-2012 12:38 AM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 02:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 01:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 01:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 01:58 AM
