Old 03-17-2017, 12:13 PM   #1
StraightOuttaCanadaEh
Wes
Noisy a/c vent?
Noticed yesterday how annoying the din coming from the passenger footwell is when I have the A/C on. Doesn't matter where I direct the airflow to, that's where the sound comes from. Is the A/C pump or whatever located behind the dash there? If you ever had a very old TV that would produce this annoying constant tzzzzzzz sound, then you know what this sounds like. It's like white noise. I have to play music, otherwise it's drilling into my brain. Wonder why I never noticed it before. Anyone else have this?
Old 03-17-2017, 12:21 PM   #2
Sounds like a loose vent flap.
I suggest you wiggle things around there to see if you can make it stop.
Bubba says to push on things around there, then when you find what is buzzing, stuff a piece of dry sponge behind the housing that holds the vent.
Old 03-17-2017, 12:31 PM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I always assumed it was the blower motor bearings or fan making a noise.
I fixed it with a catback.
murdoc is offline   Reply With Quote
The Following 2 Users Say Thank You to murdoc For This Useful Post:
nos145 (03-18-2017), Tcoat (03-17-2017)
Old 03-17-2017, 01:26 PM   #4
huh!!!!
A turbo would have fixed it even better .......
Old 03-17-2017, 02:39 PM   #5
I believe it is the fan as well. I also use the catback/overly loud music correction method.
nos145 (03-18-2017)
Old 03-17-2017, 03:57 PM   #6
Wes
Well a catback is on its way so maybe that'll help lol
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Tcoat (03-17-2017)
Old 03-17-2017, 05:56 PM   #7
If it's strictly the A/C then you hear the refrigerant spraying into the evaporator. You should hear it start spraying when the compressor kicks in and then for a few seconds after it cuts out.
The compressor cycles to keep the evaporator from freezing.
Old 03-18-2017, 02:30 AM   #8
Wes
No this was just the non-A/C mode
Old 03-18-2017, 03:55 AM   #9
If it's just "ffffffffffffffffffffff....." then it's normal. If it's "zzzzzzzzzzzzzzz...." then maybe you have a leaf rubbing on the squirrel cage.
Old 03-18-2017, 01:27 PM   #10
Wes
It's a zzzzzzz for sure. Like the buzz of electrical equipment
Old 03-18-2017, 02:41 PM   #11
Yeah, the tiniest pine needle or whatever will act like the old playing-card-in-the-spokes trick. Annoying but meh. Sometimes it works itself free. ...sometimes.
Click the readme on my sig. Pick a manual and drill down.
Vehicle Interior > HEATING / AIR CONDITIONING > FRONT BLOWER MOTOR
Easy peezy.
Disclaimer: linked manuals are not mine and could go stale any time. Read it while you can.
Old 03-18-2017, 11:17 PM   #12
Does it change with fan speed?
Easy peezy.
Mine has had a slight ticking since day one. Sounds like the fam blades is just off kilter by a hair. I don't even notice it anymore unless I actively listen.
Ultramaroon (03-19-2017)
Old 03-19-2017, 01:43 AM   #13
On low speed I can hear a slight runout on the commutator. The brushes don't quite squeak but they make a little noise. DGAF. Perfectly ok.
Old 03-19-2017, 01:53 AM   #14
That could very well be it. I never worried enough to really pay that much attention.
Noisy MCS Shocks Kuro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-30-2018 10:28 AM
Noisy injectors (?) at 3500RPM MrDinkleman Issues | Warranty | Recalls / TSB 11 02-22-2017 06:28 PM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 05:45 AM
Anyone else got a noisy ECU? ft_sjo Issues | Warranty | Recalls / TSB 11 04-16-2013 10:03 AM
Engine is quite noisy Rob_g Issues | Warranty | Recalls / TSB 9 10-14-2012 09:41 AM
