Old 03-16-2017, 11:31 PM   #365
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
We ran 450 lbs/in 7 inch Hyperco springs all around without issue. Loved the Ohlins with that set-up.
- Andy
What was on the rest of the car when you ran this setup?
Bars? Tires? Alignment?
RavioliG is offline   Reply With Quote
Old 05-18-2017, 04:24 PM   #366
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
FWIW, and I'm sure I've posted this before, but we liked our Ohlins on our car. We ran them with the off the shelf springs and then with firmer 450 lbs/in springs. Fairly comfortable most of the time and excellent all-around handling. There are some things we would have changed though.
It was difficult to lower the car much, especially with the firmer springs. Travel was overall a little bit lacking. We would have preferred that they came without camber plates which has been something we've always thought with Ohlins standard plates. Running with stock top mounts would have been nice or subbing in a higher quality camber plate with caster adjustment.
Overall, very good coilovers that with a few changes would be great coilovers. Softer springs and valving is not a change we would have made and I'm surprised that's the direction they went.
- Andrew
Hi Andrew, I'm itching to try stiffer rates on my MI20 kit before committing to a revalve in the future and was wondering if you would recommend the 8K setup you had as a square setup or perhaps a 7F/8R? My car currently has an understeer bias from aero (wing, diffuser out back with splitter up front). Thanks!
1Cor10:23 is offline   Reply With Quote
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Sleepypistonracing (05-18-2017)
Old 05-18-2017, 05:18 PM   #367
I think 7 kg/mm front and 8 rear would be a great set up for you. We can set you up if want, send me a PM. Just put together an Ohlins spring package for someone else.
- Andrew
1Cor10:23 (05-18-2017), Sleepless (06-01-2017)
Old 06-01-2017, 02:36 AM   #368
choi0706
Drives: t
what about a street car I feel the car is a bit soft.
choi0706 is offline   Reply With Quote
Old 06-01-2017, 11:24 PM   #369
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
"Myles @ RaceComp ran 8 clicks front with 10 clicks rear both street and track with standard Ohlin dampers and 450 lb. springs front and rear. He preferred a 22 mm front sway and 16 mm rear sway. He also prefers 2.8 front with 2.1 rear camber, and 1/16 inch toe in each side rear."
RaceComp just set me up with the same setup.
Sleepless is offline   Reply With Quote
The Following 2 Users Say Thank You to Sleepless For This Useful Post:
ajc209 (06-02-2017), RavioliG (06-02-2017)
Old 06-06-2017, 07:53 AM   #370
ajc209
Drives: GT86 Cosworth
With those roll bars, that is quite a lot of roll stiffness. @Sleepless you are using AD08Rs IIRC?
I've currently got MI20 with stock rates and 235/40/18 AD08Rs
ajc209 is offline   Reply With Quote
Old 06-06-2017, 07:56 AM   #371
Sleepypistonracing
Sleepypistonracing's Avatar
Drives: GT86 Road legal time attack car.
AD08R 235/40 18" with standard 4/3kg springs and Öhlins recommended ride height my wheels hit the inner arch well in almost any corner on track....
Sleepypistonracing is offline   Reply With Quote
Old 06-06-2017, 08:01 AM   #372
ajc209
Well they are 20mm bigger diameter than stock.
How much camber?
I lowered it 30mm and had slight rub on hairpins at the front but raised it 5mm and its fine now. I have -2.5deg camber up front.
Old 06-06-2017, 08:02 AM   #373
Sleepypistonracing
I'm running 3,6degrees negative up front. Still touching😜
Old 06-06-2017, 08:05 AM   #374
ajc209
Maybe thats the problem?
Sorry I remember you now. We chatted on the FB group about the MP20. Just seen the little knock you had
Old 06-06-2017, 08:06 AM   #375
Sleepypistonracing
Haha yeah! I'll put on 5/4kg springs as soon as the car is drivable again
Old 06-06-2017, 08:09 AM   #376
ajc209
The MI20 has very firm damping. I dont go past 8clicks on the track so if the MP20 is the same I think you could go as far as 6/5 or perhaps 6/6
Old 06-06-2017, 08:19 AM   #377
Sleepypistonracing
Brilliant! I've been running max hardness rear and 4clicks softer front to parry out some understeer.
Old 06-06-2017, 08:26 AM   #378
ajc209
Problem is changing damping only effects balance during weight transfer. Its roll stiffness that effects handling balance in a steady state corner so roll bars and/or spring rates are what need changing.
If you try 5/4 like ohlins want you to, I'd get stiffer roll bars front and back just to stiffen it up, but also adjustable ones so you can shift the roll stiffness ratio to get the balance you want/need.
The Following User Says Thank You to ajc209 For This Useful Post:
ChRZ (08-14-2018)
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 06:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 01:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 05:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 04:27 PM
