Old 03-14-2017, 04:43 PM   #323
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
3 months and a ~1200 miles on the new pump: still no crickets on the 10% ethanol 91 octane gas we get around here.
mrderp is offline   Reply With Quote
The Following 3 Users Say Thank You to mrderp For This Useful Post:
HunterGreene (03-15-2017), N1rve (03-15-2017), stevesnj (03-14-2017)
Old 03-15-2017, 09:23 PM   #324
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
Originally Posted by Resolute View Post
Yep. Had it towed back and they sorted it out today. Picked it up this evening and so far so good. Will keep an eye on it for leaks, and will give an update in a few months on how well the new pump is working. Hopefully, the crickets are gone for good with this new pump.
One thing that I find interesting with this second generation pump is the inclusion of a reduced fuel pump cam lift profile on the intake cam of the 2017 engines. Obviously, the 2017 ECM is designed with different fueling parameters to match the reduced fuel pump flow rate, but retrofitting the newer pump to the older engines means the new HPFP is operating with a more aggressive fuel pump cam profile, and consequently, at a higher output than the 2017 engines. This makes me wonder if the new pump design was optimized for use with the milder fuel pump cam profile, and using it with the 1st gen camshafts will result in lower pump life, or an eventual return of the crickets that would otherwise not appear in a 2017 engine.
No expert on this, but what about the engine in the 2017 auto? Isn't that unchanged? Does that one get the 2nd fuel pump as well?
Sent from my Nexus 6 using Tapatalk
aa_chow is offline   Reply With Quote
Old 03-15-2017, 10:45 PM   #325
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Correct, the automatic still has the old engine setup and tuning, but it's still likely that they would have started using the upgraded fuel pump on everything in 2017 to avoid having to deal with people bringing it back to them anyway if the chirps show up.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 03-15-2017, 11:50 PM   #326
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
So far it's been about 5 months, a bit over 4000 miles later, California E10 from Costco @ 80+ degrees. No Chirps.
N1rve
The Following 3 Users Say Thank You to N1rve For This Useful Post:
funwheeldrive (03-16-2017), stevesnj (03-16-2017), Tcoat (03-16-2017)
Old 03-16-2017, 09:11 AM   #327
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Okay coming back now to ask this, hoping for an update... Has any BRZ owner had success going to Subaru with this? Last I checked, it was unclear if Subaru had a new TSB vs the ones in the past for the same issue.
Old 03-16-2017, 10:31 AM   #328
stevesnj
stevesnj's Avatar
Would you have chirping at that temp and that gas with the old pump?
My 2016 Build thread
Old 03-16-2017, 10:33 AM   #329
stevesnj
stevesnj's Avatar
If you have audible chirps and a pre 2017 model you qualify. I had a recording of the chirp and they accepted that.
Old 03-16-2017, 10:36 AM   #330
PandaSPUR
PandaSPUR's Avatar
Yea but youre an FR-S owner right? :\
I havent heard of any BRZ owner getting this newer TSB done yet.
Old 03-16-2017, 11:00 AM   #331
stevesnj
stevesnj's Avatar
True, but the engines are the same, I couldn't see why they wouldn't accept the Toyota TSB unless liability reasons stop it. Here's the TSB PDF, http://www.ft86club.com/forums/showp...53&postcount=1
check the VIN sequencing. Print out the TSB and take it to the Subaru dealer and see what they say. If it was built at the Gumma plant which all of them were.
Attached is the last TSB specific for the BRZ revised in 2013 for 13-14my BRZ's
Take both and at a time when the chirp is audible, summertime usually, and see what they can do. If it bothers you and the dealer says no, call Subaru.
The Following User Says Thank You to stevesnj For This Useful Post:
HunterGreene (03-16-2017)
Old 03-16-2017, 11:23 AM   #332
PandaSPUR
PandaSPUR's Avatar
Just more worried about Subaru dealer denying the work because they cant order the same part or they dont think they'll get reimbursed by Subaru for it.
But thanks, I'll print out both and probably drop by this summer when the crickets come back. Haven't noticed them much during the winter.
Old 03-16-2017, 11:45 AM   #333
funwheeldrive
I've had crickets since I bought the car in 2014. I got the new pump in early March. So far, no crickets.
The Toyota dealer didn't question the repair and it was all covered, free of charge.
The Following User Says Thank You to funwheeldrive For This Useful Post:
Old 03-16-2017, 11:52 AM   #334
Ragin Gti
Drives: '15 Subaru BRZ
Subaru TSB 09-54-12R. '13-'16 BRZ, last updated 9/27/16. Some get just the pump. Some get the drive case and a left side rocker cover.
Ragin Gti is offline   Reply With Quote
Old 03-16-2017, 11:56 AM   #335
PandaSPUR
PandaSPUR's Avatar
Do you have the actual TSB PDF? I cant find one thats from sept 2016.
EDIT: On subaru's TSB site I only see "09-54-12" and "09-54-12R". The more recent of the two was dated 10/28/13 :|
The Following User Says Thank You to PandaSPUR For This Useful Post:
Old 03-16-2017, 12:56 PM   #336
Ragin Gti
NEW FUEL PUMP RELEASED....
I don't have the PDF but that's what a
dealer will find when they look it up on STIS.
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 07:39 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 07:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 04:52 PM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 11:21 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
