Old 03-14-2017, 02:09 PM   #15
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by SLVRSRFR View Post
Hope you cleared that shit out before you drove so your rad could breathe!
My car had a mask this morning too, but nothing like that.
This was AFTER I got done hooning around on local roads for 30 minutes. Turns out our radiators don't need air to work, lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 03-14-2017, 02:15 PM   #16
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
If it were physically possible to have snow covering your grille on a 110° day, I'd say that's about the only time you'd be concerned about your grille being obstructed by snow. If it's cold enough to snow, it's cold enough to not worry about your car overheating unless you're bouncing off the Rev limiter for 5 minutes...at which point you'll have many other problems.
Old school cars used to actually close the grille slats in cold weather to keep cold air out. Humfrz probably remembers that.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 03-14-2017, 02:19 PM   #17
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
The option I went with was the black housing, glass lens outback fogs, with Hella H11 bulbs in yellow, and a PSX24W to H11 adapter. I'm happy with my solution.
JazzleSAURUS is offline   Reply With Quote
Old 03-14-2017, 02:20 PM   #18
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
I was mostly being facetious, but there ya go.
I did a little hooning last night too. Couldn't resist.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 03-14-2017, 03:12 PM   #19
Stang70Fastback
A.K.A. Starlord
Good thing I wasn't revving the crap out of it for 30 minutes straight while I hooned around all the snowy roads or anything...
...wait, no, that's EXACTLY what I did :P
The Following User Says Thank You to Stang70Fastback For This Useful Post:
SLVRSRFR (03-14-2017)
Old 03-14-2017, 03:22 PM   #20
SLVRSRFR
Looks good, but I'm apprehensive about a glass lens considering all the dents and dings my current fog light lenses already have...
One of the glass fog light lenses on my 944 that I used to have about 10 years ago cracked after a huge rock was kicked up by an 18-wheeler I was following. I watched it bounce, bounce...and then heard a sickening "ting" sound. Got home to see the glass lens cracked right the way through.
@bpennerz
Old 03-14-2017, 07:21 PM   #21
Overdrive
Sittin' Sideways
Overdrive's Avatar
Crap revving isn't constant flooring with no load and no relief, so yeah, good thing you weren't doing that, lol.
Can't wait to allegedly hoon around the neighborhood later...
-O/D
2016 FR-S, Hot Lava
The Following User Says Thank You to Overdrive For This Useful Post:
Stang70Fastback (03-14-2017)
Old 03-15-2017, 10:31 AM   #22
JazzleSAURUS
Based on how awful my oem plastic lenses looked after 25k miles, I'll take my chances.
I generally prefer glass lenses as they are much clearer, don't pit as fast, and can usually be replaced. For $35/side, I'll just buy another housing and swap it out and enjoy being able to run higher wattage.
WTB fog light bulbs Jajanken86 Want-To-Buy Requests 0 11-21-2016 08:31 PM
led license plate bulbs keep burning out DanBrz91 Cosmetic Modification (Interior/Exterior/Lighting) 4 04-28-2016 06:55 PM
10 Series Fog light bulbs. 0351USMC Cosmetic Modification (Interior/Exterior/Lighting) 2 03-10-2015 08:36 AM
Light Bulbs FRSure Cosmetic Modification (Interior/Exterior/Lighting) 4 02-05-2014 11:50 PM
LED fog light bulbs pghfan19 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-10-2013 12:38 AM
