Old 06-29-2012, 02:01 PM   #29
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Originally Posted by miodculae View Post
What happened to 87 ? Nobody ? Its not like you're harming the engine.
Troll? This may not be an Evo's 4g63 but it's still no bueno if the vehicle is tuned to use premium.
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline   Reply With Quote
The Following User Says Thank You to Chewie4299 For This Useful Post:
russv (06-29-2012)
Old 06-29-2012, 02:03 PM   #30
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
Originally Posted by drifter View Post
California's highest octane is 91. Should we be using some kinda of octane booster? If so, what is recommended? thanks
They don't work. The best additive I've found over the years of driving was STPs water remover. I saw difference right away on a port injected 2E 2.0L VW/Audi engine. But that was not in US, and the area I lived in had a crappy fuel for injector engines.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
The Following User Says Thank You to Oriental Life For This Useful Post:
MannyO (06-29-2012)
Old 06-29-2012, 02:12 PM   #31
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I went with Shell for my first 4-5 fill ups and then have been suing Chevron. Next will be 76. I'll see if any gets better MPG overall than the rest. 91 since I'm in CA btw. I may try Costco too as I read it is from the same refinery as Shell for NorCal.
Old 06-29-2012, 02:37 PM   #32
soorma
Drives: Ford F-250
Originally Posted by Chewie4299 View Post
Cali tops out at 91 @ the pump if I'm not mistaken
Yup, I own a Valero and a Beacon and 91 is the highest we go in CA
soorma is offline   Reply With Quote
Old 06-29-2012, 03:01 PM   #33
Griffdawg
Drives: 2013Scion FRS, 02 Shitty PT Cruiser
I been running 87 in my supra for years so I'm sure it will run in frs.
Griffdawg is offline   Reply With Quote
Old 06-29-2012, 03:22 PM   #34
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
In a pinch 87 should work, I don't think there would be any real harm done... the knock sensor will alert the ECU of any pre-detonation occurring, and the ecu will adjust the timing to compensate.. which will affect your power output, but shouldn't do any real physical harm... course, that assumes the ecu works fast enough to counter the knocking and save your crank, rod and piston bearings and journals as well as your valves and injectors from damage caused by pre-detonation.
EsoBOFH is offline   Reply With Quote
Old 06-29-2012, 03:24 PM   #35
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Originally Posted by fenton View Post
Using Husky 94, 10% ethanol blend.
ugh.. stay away from that.. why pay premium price, and use ethanol?
Ethanol has 66% of the energy of straight fuel... you're lowering your performance, and/or hurting your fuel economy using ethanol blended fuels...
Old 06-29-2012, 03:52 PM   #36
Hanakuso
Some places have 100 in Cali but those are getting rare. I think a lot of places that are 93 octane have ethanol
Hanakuso is offline   Reply With Quote
Old 06-29-2012, 04:15 PM   #37
My1FastFRS
Drives: 2013 Ultramarine Scion FRS
91 for the first tank the dealer filled with. Now 93 only a few places left with it in my area too.
My1FastFRS is offline   Reply With Quote
Old 06-29-2012, 08:52 PM   #38
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
but it also depends on how much you push the car and the type of driving you do, no ? more city stop-and-go vs open highways ?
miodculae is offline   Reply With Quote
Old 06-29-2012, 09:35 PM   #39
maxx
maxx's Avatar
Drives: 2012 Mini Cooper S
Do your car right, you bought a nice car.
You really should be burning 93 or 91 if thats all you have available and try and avoid ethanol.
Your car will
Mo torque please
maxx is offline   Reply With Quote
Old 06-29-2012, 09:48 PM   #40
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
1st tank was Shell 91, 2nd tank Chevron 91, next tank will be Arco 91. Trying them out just to see the difference (if any). Will most probably be sticking with Chevron afterwards though.
Also will be trying putting this in:
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 06-29-2012, 09:51 PM   #41
mo8ius
mo8ius's Avatar
Drives: 2013 FR-S Asphalt Auto
In Oklahoma; only 1 station that I know of sells 93 in the OKC Metro area. I fill up there anytime I anticipate having fun. 91 no ethanol any other time.
mo8ius is offline   Reply With Quote
Old 06-29-2012, 10:12 PM   #42
Lonewolf
Lonewolf's Avatar
Drives: Moped
Just kidding, but seriously, don't use 87 unless you hate your car...
