Old 12-06-2016, 06:27 PM   #337
SpacePartyAnthem
SpacePartyAnthem's Avatar
I read in a previous post that another higher HP version would have it's own header, how big of an impact do you suspect going this route makes as far as power is concerned? (compared to fabricating your own header)
SpacePartyAnthem is offline   Reply With Quote
Old 12-07-2016, 07:45 PM   #338
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
I don't recall the post, but maybe you're referring to a post about a Stage 3 we've talked about that would have internals for lower compression, more boost (and maybe headers).
Regardless, we don't have enough data points to make a strong statement, but anecdotally we saw a minor increase when we switched from the OEM exhaust manifold to a Cosworth header; around 10 whp.
WORKS is offline   Reply With Quote
Old 12-29-2016, 03:28 PM   #339
WORKS
WORKS's Avatar
Our prototype auto-trans turbo kit vehicle back to upgrade to Stage 2.
Old 01-13-2017, 05:41 PM   #340
WORKS
WORKS's Avatar
Another auto Stage 2 kit installed this week.
Old 02-20-2017, 11:39 AM   #341
drz400dude
Has anyone done this install on jack stands? I don't have access to a lift.
Sent from my SAMSUNG-SM-N920A using Tapatalk
drz400dude is offline   Reply With Quote
Old 02-28-2017, 03:22 PM   #342
Yoda
Drives: Crystal Black BRZ(Sophia)
Pretty sure you could but I also would like some conformation.
Yoda is offline   Reply With Quote
Old 02-28-2017, 03:50 PM   #343
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
From what I can tell from pics and the instruction manual (http://www.worksevo.com/store/instru...S_Rev._1.5.pdf) to looks like you should be able to. The only thing you would need the car up for is to replace the "over" pipe which may require undoing an engine mount and jacking up the engine to gain a little more clearance. I've done something similar with a jack and jackstands when I installed my nameless fp/op combo.
The Following User Says Thank You to BigFatFlip For This Useful Post:
WORKS (03-01-2017)
Old 03-09-2017, 06:48 PM   #344
WORKS
WORKS's Avatar
Off the top of my head I know of one customer that has installed the kit at home over a weekend with a few buddies on stands and it came out very clean. There are a few others that I never thought to ask but I am sure they have now that I think about it.
Old 03-09-2017, 10:02 PM   #345
drz400dude
Awesome. I'm going to get the CARB legal kit as I'm in CA. I have about $8k to work with. The car is stock as far as performance upgrades go. What else do you suggest to go with the turbo and my budget? Thanks!
Old 04-04-2017, 08:56 PM   #346
Not_so_Breit
Drives: 2015 Subaru Brz Crystal White Pearl
so (before I say this dont freak out at me if I trigger you please) after reading and reading and research on your kit I have seen the dyno numbers works has posted which are great, but has anyone had this tuned and posted their numbers or videos of them driving it or any long reviews on the stage 2 kit on their car?
Not_so_Breit is offline   Reply With Quote
Old 04-05-2017, 12:32 PM   #347
jawnthen
Drives: 2013 BRZ Limited 6AT
If you have access to e85 nearby, I would add the necessary parts and get a custom tune. I believe works recommends injectors, fuel pump with the flex fuel kit. That's the route I took and couldn't be happier. The other option I was toying with was headers with a custom tune, but I found the gains with e85 to be similar with headers and 91. The torque dip is still there in the dyno but I honestly don't feel it. And when I go to get it smogged, its much easier to remove or hide the flex fuel kit than headers. My other car just failed smog on the visual check b/c of headers and it had passed in previous years.
jawnthen is offline   Reply With Quote
The Following User Says Thank You to jawnthen For This Useful Post:
WORKS (04-05-2017)
Old 04-05-2017, 12:45 PM   #348
jawnthen
4 months with the kit as a daily driver. I had 2 minor issues.
I had an oil leak due to a faulty banjo fitting that works promptly fixed at no charge. It was something new they were trying and did tell me to keep an eye on it which I did. The fix was to use a different fitting. I believe all new kits will have the new fitting.
The other issue I had was mostly my fault. I live on a hill and have to be on boost as I come home. I wasn't letting the turbo cool properly so a hose had kinked up and caused oil to enter the exhaust. I had smoke coming out pretty noticeably. Again a short trip up to works and they fixed the kink and put a clamp around the spot it had kinked up. That fix combined with me always letting the turbo cool 2 minutes before I turn off the car and I've been issue free.
I've been running e85 most of the time and I couldn't be happier. Merging onto the fwy is a breeze. Passing cars is no longer an issue. I haven't been to the track yet. I need to put in an oil cooler before I do that. Since my car is an AT, I have limited options. The turbo spools quick and most of the time, I have to let off the throttle b/c I'm going way to fast for public roads.
WORKS (04-05-2017)
Old 04-05-2017, 03:27 PM   #349
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
This may seem a bit childish but I really do miss turbo noises. The only videos I could find with this kit there didn't seem to be a whole lot of blow off noise or spool noise.
Have you noticed anything? Or is it just stock noise except faster?
sirbobbinhood is offline   Reply With Quote
The Following User Says Thank You to sirbobbinhood For This Useful Post:
WORKS (04-05-2017)
Old 04-05-2017, 03:53 PM   #350
WORKS
WORKS's Avatar
We offer 2 different blow off valve options now
The Forge Splitter valve: https://store.worksmotorsports.com/T....fmdvspltr.htm
and the GFB Respons adjustable valve: https://store.worksmotorsports.com/G.../gfb.t9025.htm
The Following User Says Thank You to WORKS For This Useful Post:
Kaotic Lazagna (05-13-2017)
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 05:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 07:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 08:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 01:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 08:24 PM
