Old 03-02-2017, 11:58 AM   #1
Kendallkab
Drives: Black MT LMT BRZ
Does this sound right?
I just need someone more seasoned to tell me I should be good or if I'm off.
I'm ordering work cr kai wheels next weekend. There 18x8.5 +38
I've done my research and it seems 245/35/18 tires would be good. Im looking for a nice clean flush look like the 17 86 ft86 speedfactory has. I literally just want someone with experience to tell me that sounds right so I'm more comfortable spending around 2400$.
I'm on Tein coilovers lowered 1 1/2 in right now. If you have any suggestions on tires that would be nice to. Thanks
Kendallkab is offline   Reply With Quote
Old 03-02-2017, 12:00 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
with 35 height tires its gunna be a rough ride. Tires that thin will not soak up much for potholes and cracks in the road.
jasonojordan is offline   Reply With Quote
Old 03-02-2017, 12:13 PM   #3
Kendallkab
So 245/40/18? I was looking at that first but I don't want to have to raise my car at all. I'm worried about if the wheels will fit properly
Old 03-02-2017, 12:26 PM   #4
jasonojordan
It all depends on how much ride comfort your willing to sacrifice. I do not know if you would have to raise the car to fit 40's or not. I just simply commented to make sure you were aware if you go with as thin of a tire as a 35 its gunna be a rough ride.
The Following User Says Thank You to jasonojordan For This Useful Post:
Kendallkab (03-02-2017)
Old 03-02-2017, 12:54 PM   #5
Brayden_23
Drives: Asphalt 2015 FRS
I don't believe you would have to raise your car. Play around on this site for comfort https://frsproject.com/
Edit: with a 245/40 tire, you will probably need to add a tad bit of camber (which you should probably have anyway) to make sure no rubbing happens over bumps.
Brayden_23 is offline   Reply With Quote
The Following User Says Thank You to Brayden_23 For This Useful Post:
Old 03-02-2017, 02:16 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I roll 245/35 MPSS. The ride in not harsher. Suspension is more important to ride quality than your tires.
The side wall "series" is a % of the width. From a 215/45 to 245/35 the side wall is only 11mm smaller, hardly a difference that is going to result in a harsher ride.
245/40 is too tall IMO, it is 1.1 inches taller. Check out the specs with this tire calculator.
http://www.discounttiredirect.com/di...nfoTireMath.do
I LIKE TIRES!
jasonojordan (03-02-2017)
Old 03-02-2017, 02:37 PM   #7
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I run a similar setup, 18x8.75 +35 with 245/35/18, lowered about 1", fits perfectly and is about flush (in my case it pokes some mm, but since youre on coilovers you can always correct this with camber if needed) If you need pictures, in my signature is a link to my car journal with alot of them.
Tirewise, 245/35/18 is the "correct" choice. Its near factory diameter and will not "raise" your car or offset your speedo due to a wrong diameter. A 245/40/18 is bigger than factory diameter, therefore "raising" your car and messing up your speedo.
I can NOT confirm the statement about a "rough ride". I'm driving this setup for more than 4 years now on a daily basis, and its more confortable than any lowered car I ever had.
Hope this helps
Killerbee is offline   Reply With Quote
The Following 3 Users Say Thank You to Killerbee For This Useful Post:
Kendallkab (03-02-2017), Leonardo (03-02-2017), MyNameIsKeh (03-02-2017)
Old 03-02-2017, 03:07 PM   #8
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
245/35 is the only sane choice for the wheel size you want. Period.
Whomever tells you to put 40 series tires on this setup doesn't understand fitment.
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
Old 03-02-2017, 03:46 PM   #9
Kendallkab
I'm sticking with 35.. I'm just looking for a good deal on tires now. Thanks for all your guys help
What is this sound? D_Thissen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-10-2016 12:19 AM
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 11:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 02:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Sound - ASL ScottKR Electronics | Audio | NAV | Infotainment 0 07-01-2013 11:34 AM
