CANADA Canada
Old 02-28-2017, 11:30 PM   #1
ermagawd
ermagawd's Avatar
Drives: Crystal White Pearl
smarttap/3 blink, anyone buy these?
Helo canadians. i was just wondering if any of you have purchased one of these smarttaps for their car. if so, where did you buy it from? they all seem to be in the range of 90$ + after USD to CAD conversion..
thanks !
ermagawd is offline   Reply With Quote
Old 03-01-2017, 09:17 PM   #2
n0thing
Drives: Subaru BRZ
fyi, its illegal in ontario unless it came standard
Intermittent red light restricted
(14) Subject to subsections (14.1) and (15), no person shall use a lamp, other than the vehicular hazard warning signal lamps commonly known as four way flashers, that produces intermittent flashes of red light. R.S.O. 1990, c. H.8, s. 62 (14); 2007, c. 13, s. 17 (1).
n0thing is offline   Reply With Quote
Old 03-02-2017, 02:18 AM   #3
ermagawd
ermagawd's Avatar
thanks for the reply, but didn't you just quote me red light ? the turn signals are yellow ? and i am using just the four way flashers, just to flash 3 times instead of 1
Old 03-02-2017, 08:48 AM   #4
n0thing
Drives: Subaru BRZ
oops nvm, I thought you meant blinking 4th brake light
Old 03-02-2017, 11:57 AM   #5
The turn signal 3 blink tap is already built into the car.
Be careful with modules such as this as there have been several people on here that blew their BCU with similar aftermarket doodads.
Old 03-02-2017, 08:46 PM   #6
ermagawd
ermagawd's Avatar
no problem
i mean without holding the turn signal, but good to know. just on the edge if i should purchase one of those modules that replace the oem one
similar to this:
https://www.diodedynamics.com/store/.../category/789/
Diode Dynamics: SmartTap CF18 (LM449) Flasher Relay! Add One-Touch Signaling / Strobe Diode Dynamics Exterior Parts - Lighting 73 06-30-2022 02:30 PM
Factory LED DRL Blink off when braking VIPER Issues | Warranty | Recalls / TSB 27 08-08-2015 09:24 PM
AutoWindow 3 blink Tap-Turn Module schwartzki Exterior Parts (Aero, Lighting, Etc.) 1 08-13-2013 07:28 PM
How to: Fixing hyper blink on LED turn signals Laika Cosmetic Modification (Interior/Exterior/Lighting) 0 01-20-2013 07:58 PM
F.S. Three blink...1 tap signal module BMWDavid Audio/Visual, Electronics, Infotainment, NAV 0 10-02-2012 03:37 PM
