Old 02-18-2017, 11:51 AM   #631
CARBON10
CARBON10's Avatar
Drives: 13 FR-S 10 series #0783
so killer man... I started reading your build at page 1 yesterday and just finished. Your attention to detail has given me ideas, and has made me backup and re-think what I'm doing with my own car.
CARBON10 is offline   Reply With Quote
The Following User Says Thank You to CARBON10 For This Useful Post:
zeal86 (02-18-2017)
Old 02-18-2017, 09:41 PM   #632
zeal86
zeal86's Avatar
Drives:
I didn't get around to doing much with the rear seat delete today... I just set the templates up to see what I would be up against tomorrow. What I found is that I have to raise the center of the panels as they drop about 1/2 as they approach dead center. I'm going to come up with a wedge spacer that I will probably run down the center. I will likely join both top panels... doing so will make it easier to raise the center with bias towards the rear.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is online now   Reply With Quote
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
civicdrivr (02-23-2017), Koj (02-22-2017)
Old 02-19-2017, 04:11 PM   #633
zeal86
zeal86's Avatar
Drives:
I will create a dense foam spacer to fit the gap towards the rear.
Design change here... I was going to secure the channel differently... but in the process I noticed this was a easier option.
I'll extend out the top of the channel in my next template to line up with the OEM snaps.
Also, I will probably modify my rear supports once more... I'll raise them up a bit more...
Old 02-21-2017, 07:11 PM   #634
zeal86
zeal86's Avatar
Drives:
I had planned to use alcantara but it is more expensive than I thought...I am also considering Bride fabric...
However, in the interest of saving money and still arriving at a desirable outcome, I wanted to source an OEM quality carpet that matches our interior in texture and color. I was hoping someone here has found such a product and is willing to share a link to the product page as well as a side by side comparison pic to the OEM carpet.
Thanks in advance!
The Following User Says Thank You to zeal86 For This Useful Post:
Koj (02-22-2017)
Old 02-21-2017, 08:11 PM   #635
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Not sure it helps, but didn't someone made some custom interior part? Like dashboard, knee pads, gauge trim & so on. I remember reading in "What did you do to your 86/BRZ today"
His material were bought all online (for decent price) & all looked OEM looking too.
Sorry couldn't be much of help.
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
Koj (02-22-2017), zeal86 (02-21-2017)
Old 02-21-2017, 09:00 PM   #636
zeal86
zeal86's Avatar
Drives:
This should be the last version of the templates for the rear supports...
Top ledge will support the center channel and the lower ledge will support the top panels...
All rivets double countersunk... one bracket down one to go...
Old 02-22-2017, 02:38 AM   #637
zeal86
zeal86's Avatar
Drives:
I test fitted the latest version of my rear supports and they fit just right after I adjusted the angles of the top ledges downward.
Tonight I'm going to try and cut all the panels I've created templates for.
Next up will be getting the center channel template right... once that is complete I'll try and work out a way to hinge the seat back panel.
Old 02-22-2017, 01:04 PM   #638
zeal86
zeal86's Avatar
Drives:
Pics of newest supports installed...
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
civicdrivr (02-23-2017), Koj (02-22-2017), olsonpg (02-23-2017)
Old 02-22-2017, 06:08 PM   #639
zeal86
zeal86's Avatar
Drives:
I may or may not need to use this foam spacer but I cut it out anyway...
It is for the space pictured in the image below...
Old 02-22-2017, 11:49 PM   #640
zeal86
zeal86's Avatar
Drives:
I'll probably still need to tweak the angles but at least the panels are cut from the Kydex T.
I cut the top panels from ABS and the material is not as rigid as the Kydex 100 of the same thickness.... hopefully once laid out it will suffice... if not, I'll have to brace it or order a thicker material.
Old 02-23-2017, 09:49 PM   #641
zeal86
zeal86's Avatar
Drives:
Temp installed the mounting brackets to the angled panels... I made them out of .020" tclad aluminum. The aluminum should provide sufficient strength at the bracket location without the bulk.
This was practice piece I was working with in preparation for the final center channel panel...I believe I only have enough Kydex left for one shot at the panel... so I didn't want to mess up the material...
I had to beef up my foam spacer a bit...
Old 02-23-2017, 10:24 PM   #642
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Wow this is going along nicely. Can't wait to see the end product
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
zeal86 (02-23-2017)
Old 02-24-2017, 12:15 PM   #643
zeal86
zeal86's Avatar
Drives:
More progress pics...
The riveted bracket slides right behind the slit... I'll adhere a piece of OEM like carpet on top of the aluminum to conceal it ... This bracket adds additional strength to the panels...
I held the panels in place with tape so I can remove and rivet them...
The gap allows for fabric/material to fit snugly...
Center channel template fitment... will be velcro'd on two sides...
Old 02-24-2017, 03:27 PM   #644
zeal86
zeal86's Avatar
Drives:
Partially riveted together... I used a hand squeezer for these rivets... I'll have to use a rivet gun for the rest...
***These panels could be cut out together from the template but I felt they would be easier to deal with as separate panels... plus, I would've had to buy a 48" x 96" sheet of Kydex or ABS.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
