Old 02-20-2017, 09:31 PM   #1
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
3M tape for TRD JP parts?
Hey everyone,
My car is currently in the body shop and the owner called me asking if I knew how to obtain the 3m tape that came on the TRD japan sideskirts and the rear TRD japan wing. He had removed both sideskirts and rear wing to prep for paint and is having a hard time trying to find thick enough 3m that can replace the 3m those parts came with. He told me he tried multiple auto parts stores and couldnt find anything thick enough. My question for you guys is, does anyone know 3m tape that will work or any thick 3m tape?
Thanks
Instagram: trevor.parque
Old 02-21-2017, 01:55 PM   #2
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
You're saying thick enough so that the body meets the skirt better right? Not width of tape? Not sure I've seen the thick version, I myself have been looking.
2013 SWP BRZ Limited // 6 MT // Grimmspeed Intake // Tomei Supreme UEL Header // OFT Stage 2, 93 Oct, UEL Tune // Enkei RPF1's // Borla Catback and Diffuser // Bilstein Shocks // Eibach Anti-Roll Kit // TRD Strut Bar
Subie_Nubie is offline   Reply With Quote
Old 02-21-2017, 06:10 PM   #3
MisterSheep
Killed Scion
Yes thick enough to the point where the sideskirt can meet up with the body
Old 02-21-2017, 06:50 PM   #4
Cole
Not a troll
Cole's Avatar
What about doubling up on the tape?
Cole is offline   Reply With Quote
Old 02-22-2017, 11:20 PM   #5
Poodles
Drives: 2015 Series.Blue
I've got a Series.Blue and the body shop had the same issue. Their only solution was replacing the parts (lip, skirt, spat)
I know that doesn't help, but it appears the adhesive isn't available separately (which is idiotic)
The Following User Says Thank You to Poodles For This Useful Post:
MisterSheep (02-23-2017)
Old 02-22-2017, 11:51 PM   #6
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Here you go: http://solutions.3m.com/wps/portal/3...9ZVgl&MDR=true
Matched the tape on my STI skirts in thickness but double the width so I had to cut in half lengthwise. I managed to buy a sample roll they happened to have back in 2012 by asking politely over the phone. They wouldn't normally sell this to consumers at the time.
Old 02-23-2017, 01:06 PM   #7
sirsol66
Drives: 2013 FRS- Hot Lava
This is the same one I've found, but sadly have not been able to find a single place that actually sells it. I guess calling 3M is the only solution.
sirsol66 is offline   Reply With Quote
Old 02-25-2017, 11:14 PM   #8
wraparmor
Vehicle Wraps PPF Install
wraparmor's Avatar
Drives: Fiat Abarth
Calling 3M will take a long time to get a solution if you're going to buy just a few feet. They're a big company, it might take a few transfering and numbers to press before getting an answer. And the word thickness & thicker is preference, so if you ask them what type of tape and thickness you are looking for, it's hard to describe on the phone.
3M VHB is what you want to use. We have our guys use the VHB on the Teslas and other vehicle exterior.
Pressure Sensitive Acrylic Double Sided Tape
Follow this link:
http://solutions.3m.com/wps/portal/3...e?N=6105&rt=r3
On the left menu, click: "+tape thickness"
click "more"
You will see the menu expand like how it is below arranged by Thickness
And these are the tapes called 3M VHB perfect for automotive.
For more adhesion, the surface of the parts need better cleaning
Or: use 3M Primer
Tape Thickness
And then just GOOGLE the part number on google or amazon, and you will see a supplier pop up
Hope this helps everyone out here!
wraparmor is offline   Reply With Quote
Old 02-25-2017, 11:36 PM   #9
wraparmor
wraparmor's Avatar
Drives: Fiat Abarth
Doubling the width will cause premature sagging and could make things inaccurate to install. 3M makes the tapes as thick as possible while maintaining the durability and not cause any sagging.
Check out the link above, or click around the menu. the VHB tapes are the ones you need.
Two-Sided tape for Aero parts Freude am Fahren Cosmetic Modification (Interior/Exterior/Lighting) 9 12-15-2017 06:39 AM
Tape on Windshield? Ratez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 18 01-31-2016 10:46 PM
3M Tape ThatManAnt Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2014 08:28 PM
which 3m tape is this? mokinbird87 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-29-2013 10:12 PM
Painter's tape Mazdaspeed Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 07-10-2012 11:40 PM
