Old 02-21-2017, 12:00 PM   #1
mikeh6
Drives: 2013 Subaru BRZ E85
Zeitronix ethanol content reader issue
So yesterday i filled up with my usual E60 ratio and was confused as my ethanol reader leveled at E46 where im always low 50s-57 on that ratio so today with about .65 of my tank full threw in 3.8 gallons of e85 to try to get it back to e60. It's leveled out at e50 now which makes absolutely no sense.
So my questions are:
Could this be an Ecu issue? Just a reader issue? or bad e85?
Also just want to make sure that my EcuTek tune is compensating for the fuel ratio despite what the reader is telling me.
mikeh6 is offline   Reply With Quote
Old 02-21-2017, 12:11 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
WOT is your ecu reporting any knock correction?
Ive had gas stations e85 pump give me e60 and the station right by my house always gives me e74-e75.
Although I just run flex fuel strait no mixing math for me. My tuner did set it to adjust every 1% from 10% to 65%. Ask your tuner how he setup your tune.
That station may just have a winter blend of flex fuel and everything is normal.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-21-2017, 12:32 PM   #3
mikeh6
Engine is running smooth as ever not hearing any knock...ill look into checking the tune for any codes. And on top of that i have no idea where this car was tuned as i bought it with the tune and flex fuel kit.
You might be right about the low ethanol e85 though, the price just went down slightly after its been the same for at least a month and the first time i filled at the lower price this came up. thanks for the reply
Old 02-21-2017, 03:15 PM   #4
wparsons
wparsons's Avatar
Don't trust that you'll get consistent ethanol percentages tank to tank, even from the same station.
If you want to verify the reading on the sensor, siphon some gas out of the tank and manually measure the ethanol content.
http://www.waldeneffect.org/blog/How...t_of_gasoline/
flickr
e85, ethanol, flex fuel, tune, zeitronix
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 07:43 PM
FS: Unichip w/ download cable, Zeitronix ethanol content analyzer Ashikabi Engine, Exhaust, Bolt-Ons 27 03-06-2015 10:18 PM
Zeitronix Ethanol Content Analyzer - E85! No Limit Motorsport Engine, Exhaust, Bolt-Ons 7 05-03-2013 04:04 PM
