#15 | |
#16 |
Drives: BRZ + Ducati M796
I'm confused. You think it won't hold?
#17 |
Nope I don't. Not so much the bracket to the car but the clamp that holds it in. Now if you can find a bracket that is crash tested then cool. Otherwise the trunk is where it should be.
#18 | |
Drake Off Road FIREX-MNT-DOR Fire Extinguisher Mount https://www.amazon.com/dp/B006VFR2LS/ref=cm_sw_r_cp_api_NR-MybEW4E4VE |
#19 |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | cjd (02-09-2017) |
#20 | |
#21 |
#22 |
Drives: Scion FR-S
#23 |
Drives: Subaru BRZ
I made an aluminium plate that bolts into the center console bolt holes. The extinguisher brackets mount to the plate. I did it this way because
1) It uses original holes. No drilling or screwing required 2) Didn't want to lose the ability to move passenger seat forward 3) For track days (and safety in the event of a crash) screwing a couple of self tappers into the center console is not strong enough. ![]() Can't help but think that the center console was deliberately designed to accommodate a fire extinguisher, perfect fit, and the little recess for the trigger. |
| The Following User Says Thank You to Purist For This Useful Post: | Tristor (04-28-2019) |
#24 |
Drives: 2013 scion fr-s
Another center console mount ... obviously won't work for most lol
#25 |
Drives: MY14 86 GTS Manual Velocity Orange
for those in Australia there is this CAMS/FIA approved mount for the twins:
https://www.ebay.com.au/itm/Toyota-G...YAAOSw-Ihd3lY4 https://www.autoracingtechnik.com/ Last edited by sneaky_pete; 04-27-2020 at 08:18 AM. |
#26 |
JHerbert Racing
Drives: 2013 Scion FRS
I have seen a lot of THESE being installed in racecars as of late. Compact, lightweight and efficient. Unfortunately I had just bought a regular style one when I found out about this style.
This is an old pic when I still had an interior, but mine is currently mounted behind the driver seat with a braketeer mount. I like it behind the rear seat bc in order to get it I have to have most of my body outside the car. It stayed in place for my crash at NJMP and hasn't given me any issue.
| The Following User Says Thank You to Takumi788 For This Useful Post: | kevaughan (08-02-2024) |
#27 | |
Drives: 2013 Toyota 86
Sent from my SM-N975F using Tapatalk |
#28 |
Drives: Subaru BRZ
I thought about doing a small production run of these packaged with an extinguisher. Reckon there would be a market?
Sent from my SM-G973F using Tapatalk |
| Mounting a Fire Extinguisher | Xauterus | AUSTRALIA | 37 | 05-21-2017 06:15 PM |
| new buckeye dry chemical fire extinguisher | Jhon19lopez | Interior Parts (Incl. Lighting) | 4 | 08-18-2013 04:25 PM |
| Fire Extinguisher | sw20kosh | Tracking / Autocross / HPDE / Drifting | 5 | 08-08-2013 05:28 PM |
| Fire extinguisher install | ICantAffordAnLFA | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 10-18-2012 07:37 PM |
