Old 02-08-2017, 02:04 AM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by rookie View Post
I have my BRZ on ST coilovers, running -2.5 camber all around with a slight amount of toe in the the rear. It feels like around a corner, the rear doesn't have as much grip as it did stock. I'm looking to get some rear LCA to dial some of the camber in the rear back closer to stock, would that give me more grip?
I'm in the same boat. Going to try for -2.0 next seems to be the default aggressive alignment for the rear. Maybe a few tenths more or less depending on the rest of the setup.
ineedyourdiddly
Old 02-08-2017, 02:36 AM   #16
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Dunno what your ride height is at, but I'm on KW V3s, and I'm running -2.5 degrees up front and -2.0 in the rear. And that's what I use for autocross too.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 02-08-2017, 07:01 AM   #17
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
With the minimal power this car has and the minimal squat, you shouldn't need that much rear camber. I wouldn't go above -1.5, but play around and dial in what works for you.
guybo is offline   Reply With Quote
Old 02-08-2017, 11:53 PM   #18
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
I'm sorta thinking this is what I'll try.
rookie is offline   Reply With Quote
This is how camber affects toe in front. Also RCE camber plate info. Pat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-04-2016 11:08 PM
Installed coilover; Too much camber in the back. trueno86power Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 04-11-2016 08:00 AM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
