Old 02-06-2017, 02:00 PM   #1
Inspir3dk
Drives: Red 2016 BRZ Limited
P2096 CEL Code week after installing header
As the title states. Recently installed CNT UEL headers with an o2 spacer in my car and after a week a code appeared reading P2096 Post Catalyst Fuel Trim System Too Lean Bank 1. I can't think of what might be causing the CEL. Possibly something with the o2 spacer? I don't think it could be an exhaust leak or faulty sensor considering its a brand new car (4K miles).
I cleared the code and it hasn't come back as of yet. I'm also not running a tune yet but I will be soon. Would the tune get rid of the CEL?
Inspir3dk is offline   Reply With Quote
Old 02-06-2017, 02:16 PM   #2
Icecreamtruk
Drives: Track preped NA FRS
Cant think of anything? Not even the header you just installed? ....
An O2 sensor spacer is not a solution, its a bandaid. It works sometimes, it doesnt on others. If you want to use headers, get the car tuned.
Icecreamtruk is offline   Reply With Quote
Old 02-06-2017, 02:20 PM   #3
vietspride70
Drives: 2016 scion 86
i got a same question (its in grupp-s header thread, last page) related to CEL code if i wanna run catless header, and the answer is OFT will help eliminate that code.
vietspride70 is offline   Reply With Quote
Old 02-06-2017, 04:59 PM   #4
Vten
Drives: Too heavy
I just got the same code yesterday! It's weird being the car is full e85 Moto-east tuned staged 2 sprintex sc with a full exhaust for a while without any hickup, and the CEL comes on. And I had the secondary 02 switched off from that tune.
Vten is offline   Reply With Quote
Old 02-06-2017, 07:12 PM   #5
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
First off, you should get a tune if you're going to run headers.
That being said, I had problems with my O2 sensors shaking out of the headers because I didn't torque them down enough.
demasrv is offline   Reply With Quote
Old 02-06-2017, 07:56 PM   #6
Inspir3dk
Thanks for the snarky response haha stating the truth. So there's no way there's an exhaust leak (being a new car) and just the o2 spacer not doing its job? Looks like a tune will be my next investment.
Old 02-06-2017, 08:16 PM   #7
swarb
Leak is possible. More likely it is the spacer.
Old 02-06-2017, 09:39 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
When you installed the header, did you use new gaskets? The lean code is most likely an exhaust leak in the header gaskets. Air gets in there and the upstream O2 sensor sees the extra oxygen and throws the code.
Fix it because it's throwing off your AFR even if there's no code and that will adversely affect engine performance- you're losing power. Plus the possibilty of damaging stuff. Your fuel trims will be all screwed up and if the engine is dumping fuel into the cylinders to treat a lean condition that doesn't exist, you can end up washing down the cylinders and getting fuel in your oil- which is bad. Plus there's other bad things that can happen. It's not the O2 sensor. It's working and telling you that you fucked something up. Your exhaust may be new but you messed with it- fix it.
NEVER clear a code unless you KNOW what caused it.
guybo is offline   Reply With Quote
Old 02-06-2017, 10:30 PM   #9
Inspir3dk
I used the same gaskets considering how brand new the car is. I'll check for a leak tomorrow and get new gaskets if need be. We checked it through a friend's OFT and fuel trims seemed fine. Also got a deal on an OFT of my own so that'll help. Thanks!
Old 02-06-2017, 10:33 PM   #10
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Toss that junk ass spacer and get a tune. Leave that damn code enabled until you get that tune. Your now introducing alot more fuel into your oil and degrading it badly.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
guybo (02-06-2017)
Old 02-06-2017, 10:34 PM   #11
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I had this code triggered when my secondary o2 sensor was pooched. Part of the problem was that the OFT tune I had prior to going FI and ECUTek, disabled the code P2096 along with P0420. The sensor was likely failing long before that but I wasn't getting a CEL so I was fat dumb and happy. With my EcuTek tune only P0420 code is disabled since I am catless. The ECU still needs the the secondary sensor for keeping LTFT in control when in closed loop so disabling it or shutting the sensor off isn't a good practice. A spacer can also trigger P2096 as it is moving the sensor out of the exhaust stream.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 02-06-2017, 10:35 PM   #12
guybo
Huge E85 fan!
guybo's Avatar
Bingo. You need the Grimmspeed gaskets http://www.grimmspeed.com/grimmspeed...t-pair-subaru/
Also, did you retorque after install?
Part of the problem was that the OFT tune I had prior to going FI and ECUTek, disabled the code P02096 along with P0420
OFT disables P0420 only. Not any lean code- that'd be insane if they did that.
Old 02-06-2017, 11:00 PM   #13
Apoc
Apoc's Avatar
I opened it up in RomRaider and was surprised to see it off. Just downloaded the OTS_v2.076 from openflash and both P2097 and P2096 are off in the stage 2 tunes
“The World is Flat”
[||•]=(86)=[•||]
Old 02-06-2017, 11:33 PM   #14
Inspir3dk
Yeah I thought OFT gets rid of P2096 as well. At least from what I read on other threads and other's experience.
Help installing a header & front pipe rns294 Mid-Atlantic 3 06-24-2016 09:52 AM
P0175 code after installing intake VictorKassil Issues | Warranty | Recalls / TSB 5 04-14-2016 08:36 PM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 05:30 PM
Need to replace FP/MP gasket when installing header? 1Cor10:23 Engine, Exhaust, Transmission 16 04-24-2014 05:09 PM
CEL Code P2096 w/ exhaust only ShutterSpeed Issues | Warranty | Recalls / TSB 7 12-03-2013 01:59 AM
