Old 01-26-2017, 09:39 AM   #1
halleffect
halleffect's Avatar
Drives: 2016 Subaru BRZ Series.Hyperblue
2017 Limited Gauge Cluster
This is probably a long shot, but does anyone know how feasible it is to retrofit the new gauge cluster with the LCD screen from a 2017 limited model onto an older model? How different is the wiring? Are all the electronics used by that display mostly self-contained?
halleffect is offline   Reply With Quote
Old 02-01-2017, 09:49 AM   #2
Aboodilatif
Aboodilatif's Avatar
Drives: '14 Red Toyota GT86 RocketBunny
+1, would like to know this aswell
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP
Aboodilatif is offline   Reply With Quote
The Following User Says Thank You to Aboodilatif For This Useful Post:
Cessblood (05-20-2017)
Old 02-01-2017, 10:51 AM   #3
Mvhs09
Drives: Brz
I totally want the new cluster as well... Even if it's illegal as hell to swap but oh well.
Mvhs09 is offline   Reply With Quote
Old 02-01-2017, 12:44 PM   #4
halleffect
halleffect's Avatar
Isn't there a process for legally replacing the gauge cluster by documenting the replacement and inputting the exact same number of miles on the replacement?
Old 02-01-2017, 02:23 PM   #5
Not all of the sensors needed to operate all of the gauges are likely in the early models.
There are legal ways to change the cluster. You can find writes ups through Google.
All in all it would probably be cheaper to trade the car in for a 17 then to do all the work and buy all the parts to change the cluster.
Then the 18s will come out with something even better and you will want that.
Then the 19s will come out and... Well you get the picture.
jcw99 (05-28-2018), Trap63 (05-04-2018)
Old 02-01-2017, 04:48 PM   #6
halleffect
halleffect's Avatar
Thanks for the info. What is the best way to verify whether the 2017 gauges requires other parts that are not on previous models without actually buying the part? Should we look at the diagrams on the Subaru Parts website? The servicing manuals?
Sent from my iPhone using Tapatalk Pro
Old 02-01-2017, 05:56 PM   #7
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Look in service manual for MY17 vs MY16 or older. Find info on the gauge cluster and see what connections it requires, go from there I guess.
Old 02-01-2017, 07:21 PM   #8
This^. Some may run off the ECU as well and although they may be common between the model years you would need to check that.
Old 02-01-2017, 07:23 PM   #9
halleffect
halleffect's Avatar
Sounds good. Thanks for the info. What seems promising is that the non-Limited 2017 models seem to be using the same gauge cluster as older models. I'll try to track down the manuals.
Old 02-23-2017, 04:20 PM   #10
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Any news? interested as well
shaynek is offline   Reply With Quote
Old 02-24-2017, 10:52 AM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
Ugh, just bought a Subaru TechInfo subscription but the 2017 BRZ manual isn't online yet.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
halleffect (02-25-2017), Tim86UK (03-19-2017)
Old 03-12-2017, 03:33 AM   #12
Tjvghn
Drives: 2014 BRZ - 2001 HD dyna
Any update? I've been looking into doing this myself - I would think the computer is fed from the ECU I can get a lot of the info on my head unit
Sent from my ONEPLUS A3000 using Tapatalk
Tjvghn is offline   Reply With Quote
The Following User Says Thank You to Tjvghn For This Useful Post:
Old 03-19-2017, 02:16 AM   #13
Tim86UK
Drives: Toyota GT86
Word, when there is an update let me know!
Tim86UK is offline   Reply With Quote
Old 03-19-2017, 04:51 AM   #14
steve99
Drives: FT86
Physical connections are the least of your worries.
The 2017 dash cluster will likely need the 2017 ECU calibration to work.
Im not sure of all the gauge displays on the 2017, but all the sensors sre likely their in the older cars,
The G force sensing, acceleration slip angles is likely derived from the VCS computer data/sensors already in older cars.
oil temp is already their in older cars
you big issue will be software compatability between the ECU, Dash Cluster VSC computer and the security/imobiliser system.
I know 100% that the earlier ECU calibration will not run on 2017 cars and causes secutity imobiliser system to lock out and need reset procedure.
so I suspect that the 2017 ecu calibration will not run with older security system.
It would be a suck it and see process to swap in the new dash cluster and find out what happens then attempt to correct problems.
The dash/ecu/imobiliser/key fobs form a security set and their are often special proceedures required to sync in any of those components if the entire set is not replaced.
You might be lucky and just be able to swap in 2017 dash using the factory procedure but its going to need someone to shell out the dollars to test it and be prepared to loose that money if it doesn't work
Trap63 (05-04-2018)
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 04:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-15-2016 12:32 AM
Gauge cluster with Oil Temp Gauge Jetbill Interior Parts (Incl. Lighting) 1 10-06-2015 02:41 PM
OEM frs cluster gauge Baramzisyan Interior Parts (Incl. Lighting) 0 08-31-2014 03:39 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 03:54 PM
