#127 | |
Small resonator = more noise Big resonator = less noise The piping diameter makes a difference as well. The bigger the pipe, the more noise it will produce & vice versa. Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
| The Following User Says Thank You to alxtheoreo For This Useful Post: | goonz_maroon (08-23-2016) |
#128 | |
Drives: 2015 Scion FR-S
Sent from my SM-N910W8 using Tapatalk |
#129 | |
Don't believe the words that a high flow cat will eliminate drone & rasp. It'll just produce the same sounds as a straight pipe but at different engine loads. The other option is to keep the stock piece. It's very good at keeping bad noises at bay. Sent from my SM-G930V using Tapatalk
#130 |
Drives: 15 BRZ LTD, 05 FXT
Catted or Double resonated are pretty good imo.
#131 |
#132 | |
Resonators help with rasp most, but help with volume some. You'd do okay, I recommend doing one part at a time, and using the next part to adjust further. IMO a resonated Perrin CBE, and high flow catted front pipe sounds great. If you go with a catless header it's going to get louder too, which is when you may want to add another resonator to the midpipe to help where it can. One piece at at time if you actually care about getting the right volume and sound quality is my recommendation. I have a catless EL header and MXP SP catback, and don't intend to add any more exhaust components, as I'd like to keep it quiet. If I choose to swap out the front pipe, it'll be a high flow catted, resonated FP like the JDL ultra quiet.
#133 | |
#134 | |
I think you should get the Perrin 2.5" resonated exhaust. If you want a little more rasp, get a resonated FP OR get ballsy with a header. Changing the front pipe is technically emissions as well, no different from the header as it has a cat in it.
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | goonz_maroon (08-23-2016) |
#135 | |
Drives: FT86
like the other guy said khs and jdl do quiet front pipe but they are expensive. and they may not be much louder than stock one. its all a bit suck it and see with exhausts as their are son amny combinations |
| The Following User Says Thank You to steve99 For This Useful Post: | goonz_maroon (08-23-2016) |
#136 |
Drives: FT86
Added info now that opensource tuning and OFT now have flex fuel and map switching capability on some roms.
#137 |
Any new info to add for this thread for the 2017+?
#138 |
Drives: FT86
have not seen a 2017 here yet. they already have better air filter The ecu has different programming and appears to run full time closed loop fuel control and does not run rich at high rpm load (from what I've seen on usa model ecu logs) Header is changed and intake manifold changed. Due to stock header being better and fuelling control being better you may not see as much gains from header and tunes as you did on earlier models. but its early days. |
| The Following User Says Thank You to steve99 For This Useful Post: | GeorgeJFrick (01-14-2018) |
#139 |
Drives: 13 frs red
Thanks for your hard work steve. I recently switched to e85 and relied on your info. Very happy.
#140 |
Drives: 2013 FR-S Raven
Hello I couldn't find anything on this, so please excuse me if it's a double. I have 13 FR-S with and agency power catback. I love the way it sounds and is great quality no issues what so ever. Just wondering has anyone with this set deleted there CATS, of so what's the sound like? I'm concidering it until I have the money to buy a new header and down pipe. Any vids would be fantastic. Thanks the car is stock ATM other than the catback.
| Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! | Simon99 | BRZ First-Gen (2012+) — General Topics | 104 | 10-10-2016 01:45 PM |
| What mods next? Exhaust? Intake? | Ludacrits | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2013 09:25 PM |
| Question about basic performance mods | bdanisi | Engine, Exhaust, Transmission | 2 | 01-25-2013 06:40 PM |
