#7743 | |
Drives: None
So, from my understanding Coating the header - prevents some heat from rising up to the intake system. Therefore, effective. OP/FP wrap - probably slightly effective, but still effective at reducing raising heat. Guady Gold on the bottom of the IC - Prevents any ambient engine/exhuast heat from warming up the air on the hot side of the supercharger - should be effective. Guady Gold on the it take system - probably effective. Aluminum jungle gym in the bumper - Probably does something, but not anything that will help the sprintex kits real problems - high IAT? |
#7744 | |
Drives: UK GT86
The stock intake already pulls air from the coldest area possible if the rad ducting is intact.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Njjawn (01-27-2017) |
#7745 |
Drives: 2013 Scion FRS
Get rid of the stock intake and swap it for something that is still cold air but not a box in the engine bay.
I noticed a world of difference in IAT at the supercharger afterward. As far as the rotors go, you won't see any problems running 12.5psi on a 90F day even without a charge cooler doing spirited runs and street racing(with a conservative tune [although I wouldn't suggest tracking with this setup at these temps]). There is always the option to go with alcohol injection just to be safe though. It cools the rotors and airflow down substantially, adds around another 1-1.5lb boost, and ups the octane level in combustion. I use it on ambient temps above 85F. It's worth noting that you'll probably start to feel less performance at around 80F+. Another thing you'll feel is humidity. A dry 70 degree day will give you a much nicer run than a humid one. For safekeeping (this hasn't been proven by any means), I vent my charger crankcase pressure through the dipstick when it is at temp about once a year. The oil seal has been known to weep, so my best practice has been to run it at about ambient pressure when hot, and vacuum when cold. Haven't had any weeping since. This is all personal speculation, of course. You can do whatever the $*(& you want to do.
ScreamingElectron - SnakeShit Last edited by riboyster; 01-27-2017 at 01:51 AM. |
| The Following 2 Users Say Thank You to riboyster For This Useful Post: | CK_Bladesmith (01-27-2017), Njjawn (01-27-2017) |
#7746 | |
Drives: UK GT86
I do understand that you're in a hot part of the world, I really should try rigging up the MAF IAT sensor into my rear O2 input so that I can compare ambient/pre/post charge. Think about ideas like: Better IC radiator More water in the system Better coolant:water mix Larger water pump Water/meth spray None of these have been proven, except the last. But it may be what I'd try. However the issue may be the laminova core, which we can do nothing about.
.: Stealth 86 :.
#7747 | |||
Drives: None
#7748 | |
ScreamingElectron - SnakeShit |
#7749 |
Drives: SC BRZ
I think i'm about to ditch my perrin CAI. The fitting that attaches to the sprintex intake tube(what is this called btw?) always comes loose and isn't supported well. Anything easier to run here?
#7750 |
Drives: None
So I finally took the drive and picked up my SC.
The previous owner gave me a dyno sheet for his car, showing 246WHP 199TQ... I asked him what other "supporting mods" he had and he told me that the car was 100% stock otherwise. The supercharger was rebuilt by Jon Bond and he was running the stock pulley, and the innovate provided tune without any re-tuning or adjusting. Not that I doubt him, I mean the paperwork was in my hand... but how? Arent those like 70mm numbers on a full bolt on car? |
#7751 | ||
Drives: 2013 Firestorm FRS
You're in for some fun though! |
#7752 |
so finally got my 335 installed yesterday. PITA lol. I highly suggest removing the whole intake manifold, instead of my impossible way of NOT haha.
I took a ton of pics and video, so I'll have something up in the next few days. Anyway, the car started up (thanks Mike/Moto East) and went for a short drive to check everything over. Didn't beat on it, as I still need to log and send that back to Mike After that, it'll be clutch time...and then back on the dyno @yip @moto-mike |
| The Following 2 Users Say Thank You to continuecrushing For This Useful Post: | riboyster (01-30-2017), stockysnail (01-31-2017) |
#7753 | |
Drives: None
#7754 |
Drives: SC BRZ
aaaand now moto east didn't send me a license with my tune
this car is a disaster |
#7755 | |
Kinda makes me happy they aren't my tuner. Never too late to switch to delicious tuning.
#7756 |
I've dealt with both Delicious and now Moto-East, both have been good.
Give Moto East a call, I'm sure they'll be quick to help out |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
