Old 01-26-2017, 01:15 PM   #1
BillWeiss
Drives: 2016 Hot Lava FR-S
TPMS cloning
I'm hoping some of y'all understand this better than I do.
I'm planning to have two sets of wheels for the car: summer and winter. The summers will probably be my autox tires, but I don't think that matters for this. I'd prefer to not just have the sad tire pressure light on in the car for half of the year. After some searching, I found http://clonemytpms.com/ , which I think can (as it says on the tin) make me a duplicate set of sensors. If I do that and then have them mounted in my second set of wheels, am I correct in thinking that I just won't have to worry about it again?
The other option seems to be to have the car paired to the new set of sensors when I swap, or to buy a tool to do that. The tools look like they're not that expensive, but that looks like more hassle than a one time purchase and having it work.
Sorry if this is a duplicate. I think I searched appropriately, but maybe not? Point me in the right direction if so, please
BillWeiss is offline   Reply With Quote
Old 01-26-2017, 01:17 PM   #2
BillWeiss
I do see http://www.ft86club.com/forums/showthread.php?t=114110 , but that doesn't seem to be the same question I've got.
Old 01-26-2017, 01:28 PM   #3
You are correct. Never seen that site before but if they are sending you the scanner to get the codes then I see no reason why it wouldn't work. Not sure how it compares in price with what a dealer would charge you though.
Old 01-26-2017, 01:36 PM   #4
BillWeiss
Will a dealer clone them? I was under the impression that they would just reprogram the car to use the new ones and I'd have to repeat when I swap.
Old 01-26-2017, 03:27 PM   #5
They can set the car to the sensors yes. Some can also set the sensors to the car.
Old 01-26-2017, 05:05 PM   #6
TheDetailer718
TheDetailer718's Avatar
Drives: 2013 Subaru BRZ
Too bad you're not in NY. My company manufacturers our own re programmable sensors. If you bought 4 sensors then I would scan your car, get the sensors ids from your current wheels and clone all 4 sensors.
Then you can just swap wheels and never have to worry about reprogramming your wheels every time.
TheDetailer718 is offline   Reply With Quote
Old 01-30-2017, 03:00 PM   #7
BillWeiss
1) Yeah, that would be easy
2) So it sounds like this will work out well? I'll order some soon, but it'll be a while until I get a second set of tires.
TPMS cloning question for two OEM sets iketiak Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-28-2016 07:08 PM
TPMS cloning shop? Metzatricity Northwest 0 07-31-2016 09:00 AM
AZP Aug/Sep Discounts on Major Service & TPMS Cloning! AZP Installs NY / NJ / CT / PA 0 08-17-2014 09:53 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
