Old 01-20-2017, 03:39 PM   #15
Originally Posted by Odd View Post
Mines 1 week for parts. 1-3 days for the fix. The tech sounded like he was doing three simultaneously on a weekend.
My other question is, how the hell am I driving incorrectly to wear this part out at 25k on the Odo? Been driving manuals my whole life, thank god I had the extended warranty (2014 brz)...
Maybe you have been doing it wrong your whole life .......
Old 01-20-2017, 03:47 PM   #16
Teseo
Drives: frs
Mine was 4 days and they ordered some parts
Old 01-20-2017, 06:13 PM   #17
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
It's a faulty part to start with, based on the fact that this seems to be a pretty common occurrence.
The only thing I can say is yours seemed to fail at a lower mileage than the majority of the cases that I've read about, but I have seen a few that failed at lower mileage as well, so you're not alone.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 01-27-2017, 11:47 AM   #18
ARTBRZ
Aloha!
ARTBRZ's Avatar
Thanks for all the replies.
Follow-up on the repair: The tech did not look at the vehicle after returning it on the day of 1st repair completion (took 3 weeks to complete). After 2 weeks I questioned why there was still a rattling in the gearbox after the initial repair and why it wasn’t completed. Apparently the tech forgot the bolt on the drive shaft or did not torque it down. On the same day that I brought up this issue my vehicle repair was completed (5 weeks total).
Tech notes (verbatim): Replaced throw out bearing, release fork, pivot fork rides on and pressure plate
Parts used:
· FP number 44022AA123 GASKET(CR)
· 44011AG000 GASKET EXH PIP
· 30210AA760 COVER COMPLE
· 30502AA051 BEARING CLUT
· 30531AA220 LEVER CLUTCH
· 30537AA061 PB000955 PIV
· 35025CA000 COLLAR
Things I noticed after repair:
· Clutch pedal is now smooth and there’s no longer a crunch at the end when pressing down on clutch.
· The RPM does not drop as fast when shifting gears
· At the 750 to 1300 RPM, the engine no longer wants to die or sputter (I don’t need to rev higher)
· No more clutch squeak
I so excited to have my car back! I hope this will be helpful information for those who are experiencing the same clutch fork/throwout bearing problem.
ARTBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to ARTBRZ For This Useful Post:
carsebuco (01-28-2017), SLVRSRFR (01-27-2017), treminaor (01-27-2017)
Old 01-27-2017, 03:16 PM   #19
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
How much was it dropping? Mine drops 2k from 1st to 2nd, no idea what's actually normal.
treminaor is offline   Reply With Quote
Old 01-28-2017, 10:28 AM   #20
ARTBRZ
Aloha!
ARTBRZ's Avatar
Mine was from 4th to 5th. I don't know how much rpm it dropped
Repair shop in LA - Clutch Throw out bearing Octoman Southern California 18 09-06-2016 05:45 PM
Throwout bearing. bdanisi Issues | Warranty | Recalls / TSB 54 07-17-2016 07:13 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 02:17 PM
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 03:17 AM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 09:08 PM
