| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2008 Fit Sport
Wider rear wheels and tires will produce more understeer.
#16 |
Drives: Legacy GT
Unless you are tracking the car it's not really a concern.
Going to a wider rear tire on these things will result in more understeer. The reason for a staggered setup has more to do with balance and temperature management than grip. If you are on a track and are trying to put a lot of power down on corner exit then a wider rear tire might work better because it has more rubber and can handle more heat and load. To go into it further would get pretty complicated. For the most part I like a square setup, even on a car with more power like a Z or a turbo S2k. And it could be worse. I know a guy who put wider rear tires on the back of his accord. |
#17 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Wider rear wheels are used to help the engine put down power out of turns. Considering that our cars only make 151tq, there really isn't a need for larger rear tires. Going with a square setup will help keep the grip even front-to-rear. Going to a staggered setup will encourage understeer.
#18 |
Drives: 2013 Premium White, 2006 TL
I would think that going from a neutral non staggered car to a staggered would make the biggest difference in upsetting the balance. In a staggered I would think you would be setting up a neutral car to have more understear due to more tracking in the bak and less in the front? Am I wrong thinking this way?
Now if the car was built to be neutral in the staggered format but then to go an put an unstaggered wheel set up, I would think you would end up with oversteer. Just imagine putting a pair of spare tires on the front or back of the car. I know that is drastic staggering, but do you see my point? |
#19 |
Custom User Title
Drives: Asphalt FR-S MT
It is really cool readings everyone's explanation. I never would have really thought of oversteer and understeer being so related to width. Thanks guys.
Now if you chose much wider tires (on a square setup) than stock in both the front and rear, would this create more understeer? or is this directly related to the ratio between the front and rear? |
#20 | |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
![]() Remember this is a small sports car we're dealing with. The wheel/tyre combo you choose should be suited to what you want the car for - show car / track work / street etc etc. My advice would be that if you want to enhance the performance of the car by ONLY swapping out the wheels and tyres is that you keep the changes to a minimum. Look at rotational weight and look at putting on 225 or 235 section tyres. Putting on 19" with 255's......the car will be better served on the show car circuit than as a daily driver or back road / track weapon. Of course if your plan is to supercharge or turbocharge it to 300 HP, look at wider rubber (as well as brakes, suspension etc) but remember that 19's can be a little precious (delicate) if pushed fast due to the lack of rubber between the rim the pot hole you just ran over. ![]() The engineers who designed and built this car knew what they were doing. Improvements are best made incrementally.
BRZ001: Peace Love and Wheelies @metabrz on IG
#21 |
Wider tires would mean more grip assuming they are good tires. Just remember now it will be harder to get the back wheels to break loose so maybe harder to get the car into a drift. But also realize you will be going faster when the tires break loose. You should learn about the car first with stock tires before you increase your grip and speed.
#22 | |
| The Following 2 Users Say Thank You to fatoni For This Useful Post: | BlaineWasHere (06-27-2012), DrDuquette (06-27-2012) |
#23 |
Tires
#24 | |
Site Moderator
Drives: Stuff
I don't pick a size unless the tire I want is available in it
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | fatoni (06-28-2012) |
#26 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Compound and taking a tire to it's maximum width wheel it fits is much more important to me for balancing the car than just getting wider tires. Wider tires are no good if the wheels you have aren't wide enough to minimize sidewall flex and keep the tread in shape. It's the main reason I stayed with the stock tire size but went with better tire compound and wider wheels for my track setup... besides the obvious weight component (wider tire sizes add 3-4 lbs at a location which will affect the handling/balance more than slightly overweight wheels). I am also not going for quickest time or driving 100% on the limit 100% of the time [this is my daily driver the bank owns after all!] where wider tires would provide more grip (but still at the expense of poise/balance). I am just wanting the car to be better balanced than stock while having a great time on track. Stock size sticky tires on maximum width wheels balance the car even better at the limit than stock because you can read the tires that little bit better with less 'slop' and you have noticeably more grip available. On the street though, Grippy stock sized tires on maximum width wheels for the size will make it seem more 'understeery' or less prone to kick the rear out but you still have excellent steering feel and response. For me, maintaining the balance means the wheel/tire combination needs to be lighter than stock and the tires should gain minimal weight (not be more than ~2 lbs heavier than stock weight - because no matter how light the wheels, a heavier tire will mess more with the suspension feel than a lighter one.) The reason I went with Kumho XS's over Hankook RS-3's (besides being very familiar with the RS-3's, having always wanted to try the XS's, and the XS's being $14 cheaper) was they weigh less. Having put my FR-S on track last week, sticky stock sized 215/45-17 XS's on 15.6lb 17x8 Kosei K4R's are definitely better balanced than the car was stock... stickier tire compound, 8" wheel width chosen for the maximum tire stretch recommended, and ~4lbs less weight a corner all add up to something really impressive - impressive poise and control with very high level of grip! Last edited by Vracer111; 06-28-2012 at 12:33 AM. |
| The Following 3 Users Say Thank You to Vracer111 For This Useful Post: |
#27 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
So what you guys are trying to say is this car is in optimal handling mode stock?
#28 |
i'm sorry, what?
Drives: Canada
is that really hard to believe?
| GReddy Scion FR-S Makes First USA Public Appearance at Cars & Coffee in Irvine, CA | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 01-16-2014 01:28 AM |
| BRZ making appearance at Park Subaru in Akron | Rampage | BRZ First-Gen (2012+) — General Topics | 3 | 05-03-2012 05:38 PM |
| Stock Wheel Weight | Dionysus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-01-2012 01:46 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
| Weight of FT-86? | Levi | Engine, Exhaust, Transmission | 38 | 06-14-2011 10:43 PM |
