Old 01-17-2017, 11:15 PM   #15
Chad_W
Drives: 2013 BRZ DGM
Originally Posted by Snake View Post
The 200 to 243hp bump in power seems a bit low considering all the other work they did.
But that'd be why it'd be interesting to see the dyno, I'd assume they made significantly more torque everywhere so it'd probably feel much faster than the 43hp bump suggests.
Clearly something is missing here. Most stock FA20 can see a roughly 20% increase in power through ecu mapping and header. An increase in displacement with all the supporting they are doing, should also see an minimum increase in as 20% as well. Engines aren't just a simple mathematics equation (they're many, many equations), but it's reasonable to assume that you would see 240hp with the displacement increase alone and be able to 20% more with all the supporting mods and tuning. It would odd to think that this car makes less than 280-290hp. It's possible that they're comparing 200bhp to 243whp.
Chad_W is offline   Reply With Quote
Old 01-18-2017, 12:46 AM   #16
Snake
Drives: ADM Toyota 86 GT
Video definitely looks like they have the finished product on the engine dyno, not in a car on a chassis dyno.
Could be that it makes all the additional torque down low so it doesn't bump up the peak power?
Sent from my HUAWEI RIO-L02 using Tapatalk
Snake is offline   Reply With Quote
Old 01-18-2017, 08:34 AM   #17
stevesnj
stevesnj's Avatar
Mid range torque is needed in the FA20, Increase the torque, that would be very welcome.
My 2016 Build thread
Old 01-18-2017, 08:56 AM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
This is jdm NA car. It's supposed to be high-rev-ed. While it's simpler to daily drive with more torque more down, i find in some ways more enjoyment/involvement feel due this need of high-reving & rowing through gears to keep in powerband vs relaxed driving in one gear and lazy accelerator use only for change of pace. Imho it would be more fun to make this car more high revving vs adding more torque down low. Even in cases if later one would make car faster then former
Anthony (01-19-2017), Scrappydoo (06-11-2017)
Old 01-18-2017, 09:46 AM   #19
Bach415
Bach415's Avatar
Drives: Whiteout FRS
2.0 >2.4 NA by Monster Sport
According to the sign they had at TAS17, the price of this engine package, believe it or not, is 1,950,000 yen, which converted to USD is around 17211 USD. Attached is the picture of it I took when I was there. Feel free to correct me if I'm wrong.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
stevesnj (01-19-2017)
Old 01-18-2017, 10:03 AM   #20
Chad_W
Torque is 190 at 5800, so it doesn't seem like too much down low. We still need dyno chart to tell the whole story.
Looking at the list of supporting modifications, 243 hp at the crank would be disappointing even without the bump in displacement.
Old 01-18-2017, 10:23 AM   #21
Pat
Pat's Avatar
Drives: 2023 BRZ
Again, we don't know all of the details with this engine, but if things are what they seem to be at first blush, this looks to be a pretty spendy proposition given the engine output.
It seems to me like this is just more confirmation of why the Jackson or Edlebrock superchargers are the way to go with this engine.
I can't imagine paying more money for a Subaru flat four than a Porsche flat six. The normally aspirated Porsche engines are SO much nicer to drive than the FA20, too.
Old 01-18-2017, 11:54 AM   #22
Traktor
Drives: Subaru BRZ Limited
I wonder what cams they used? I recall on LS builds the bigger bore engines need a more aggressive cam to move the power band up. (Very different engines I realize)
243 PS is what you might expect with the stock 2 cat exhaust and a stock-like tune. But they looked to be running Catless EL headers with a custom tune.
Very disappointing.
Traktor is offline   Reply With Quote
Old 01-18-2017, 01:27 PM   #23
stevesnj
stevesnj's Avatar
Good points all. I would like the power for the track days powering out of the corners. But for $17,000 I don't need it that bad.
Old 01-18-2017, 01:33 PM   #24
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Stock header, but after market intake and cat back exhaust + e85 will get that same power lol.
irax is offline   Reply With Quote
Old 01-18-2017, 02:29 PM   #25
Lantana frs
Drives: 13 frs red
Another jdm money toilet imo.
Lantana frs is offline   Reply With Quote
Old 01-18-2017, 05:21 PM   #26
-Willis-86touge
Drives: Stock
Just checked out there web site and there's another video of a dyno with just an intake. Before it is 187ps to the wheels and after intake it is 195ps to the wheels. I think the 2.4 stated is to the wheels. So 243ps to the wheels witch makes since. So converted 239whp
-Willis-86touge is offline   Reply With Quote
The Following 2 Users Say Thank You to -Willis-86touge For This Useful Post:
DAEMANO (01-25-2017), stevesnj (01-18-2017)
Old 01-18-2017, 07:51 PM   #27
Turdinator
Señor Member
Turdinator's Avatar
2l @ 200hp bored and stroked to 2.4l @ 240hp... Why are people disappointed? There are losses they would have to overcome. Increasing the stroke would make for a pretty crappy rod ratio and increasing the bore will negatively effect the quench built in to the combustion chamber....
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
celek (01-24-2017)
Old 01-18-2017, 09:06 PM   #28
Traktor
Because it costs $17k and an ACE Header + a tune on a stock engine will get you around 240 at the crank on 91 fuel. Other headers will generally get maybe 10-15 less chp than the ACE.
As stated above, that engine appeared to be running a catless header and has a custom tune, so you would expect bigger gains even taking into account the losses from increased capacity. You wouldn't quite get the 120hp/litre in the ACE example, but still...
And then there was all the porting/polishing work that seems to have been for naught?
Monster-sport pedals adprokid Cosmetic Modification (Interior/Exterior/Lighting) 9 01-07-2016 08:26 AM
Monster Beats by Dre PRO, Monster Inspiration headphones Sgt.Beardface Miscellaneous 4 09-08-2013 07:05 AM
MONSTER SPORT Toyota Super 86 ichitaka05 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 04-29-2013 08:07 AM
Monster's Sport Super Toyota 86 Pike's Peak Ryeong86 Scion FR-S / Toyota 86 GT86 General Forum 2 04-25-2013 12:57 PM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
