Old 01-11-2017, 02:17 AM   #71
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Yeah, if you don't want to put $5k into it then it's not the class for you.
I bet if you picked up stock springs and a sway nobody would bat an eye at your car running DS.
I do have stock springs that I bought in case they said it was okay and the sways that come on the RS 1.0 are OEM. No one would let it slide when contingency money is involved though so I'm not going to risk that. Asked the committee and they specifically said the RS cannot move even with OEM springs.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
strat61caster (01-11-2017)
Old 01-12-2017, 12:21 PM   #72
M0nk3y
Originally Posted by Locust View Post
I do have stock springs that I bought in case they said it was okay and the sways that come on the RS 1.0 are OEM. No one would bat an eye when contingency money is involved though so I'm not going to risk that. Asked the committee and they specifically said the RS cannot move even with OEM springs.
There have been people that have checked VINs and have ran VINs to make sure a car is legal with certain packages. Latest I can think of is the ZCP equipped M3s. Because stiffer springs/wider wheels/EDC
Old 01-12-2017, 05:05 PM   #73
Locust
Custom User Title
Locust's Avatar
Ya I typed that wrong I meant no one would ignore it when money is on the line.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 01-14-2017, 07:19 PM   #74
Locust
Custom User Title
Locust's Avatar
So what exhaust are most people running for C/D-Street? I've seen that the STM is like the lightest bang for your buck but it being aluminum I'm curious how it holds up to a full autocross season.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 01-14-2017, 08:43 PM   #75
bslate3
Drives: 2015 CWP BRZ
Just get a Berk track pipe muffler delete. Best bang for the buck.
bslate3 is offline   Reply With Quote
Old 01-14-2017, 09:48 PM   #76
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I've seen more than a few people with the muffler delete, but there are still plenty of people with the stock catback or something else
G_Ride is offline   Reply With Quote
Old 01-16-2017, 02:11 PM   #77
renfield90
The Stig's German cousin
You won't even get close to blowing sound at sound-sensitive sites (93dB at 50') with the muffler delete in Street trim. Don't go kidding yourself about the other setups making more power either. Go with the lightest solution.
My preferred objective for designing an exhaust system is the lightest system that will meet the sound requirements, with the desired torque curve as a secondary factor for the header.
Old 01-16-2017, 04:38 PM   #78
Locust
Custom User Title
Locust's Avatar
Haha ya when I went from the quad on my RS to a single pipe turn-down it went from 78db to 75. These cars are not loud in street class.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 01-20-2017, 09:50 PM   #79
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Thanks for all the info guys, this thread really helped me out as a first time autox'er.
Where do you guys get magnetic number sets? I used painters 3M tape last time I went and it started to peal off from all the air movement.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 01-20-2017, 09:56 PM   #80
FastWhite
Drives: Subaru BRZ Limited M/T
http://www.soloperformance.com/#_
FastWhite is offline   Reply With Quote
The Following 2 Users Say Thank You to FastWhite For This Useful Post:
Bowen (01-20-2017), whataboutbob (04-12-2017)
Old 01-21-2017, 06:51 AM   #81
G_Ride
G_Ride's Avatar
http://www.izoomgraphics.com/index.p...=index&cPath=1
The Following User Says Thank You to G_Ride For This Useful Post:
Bowen (01-21-2017)
Old 01-21-2017, 12:45 PM   #82
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Hawgee Decals at www.hawgee.com
All proceeds go to helping my buddy, a fellow 86 owner, fund his autox habit!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
G_Ride (01-22-2017)
Old 02-12-2017, 12:35 AM   #83
dutchman1
Drives: 2017 86 6-Speed
Mike,
What's the best way to launch a street class autocross car? Seems like if I launch (by simply dumping the clutch) around 3k, I get severe wheel hop and if I go up to 5k+ I get so much wheel spin I'm basically just doing a burnout. Is slipping the clutch the only way to get these cars going quickly? I'm also running koni yellows, would softening up the rebound a tad be helpful?
dutchman1 is offline   Reply With Quote
Old 02-12-2017, 01:49 PM   #84
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by dutchman1 View Post
Mike,
Launch RPM changes as surface and tires change... At least in my experience. That said, minimizing clutch slip without bogging and without excessive wheel spin just takes practice. A very quick lift if you get spin often gets things back on track. I'm still inconsistent on launches and it was one of the things I focused on a lot last year. A smooth start does seem faster, and if that takes a tiny bit of clutch slip... If you smell it, you've gone too far.
The softer suspension probably makes hop more of a problem for you than for me. Just barely into wheel spin rpm with a little throttle sensitivity is probably the way to go, with just enough clutch slip to soften the shock you get with a clutch dump.
Curious to hear how others approach this.
The Following 2 Users Say Thank You to cjd For This Useful Post:
dutchman1 (02-12-2017), strat61caster (02-13-2017)
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 03:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 06:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 09:09 PM
Official FT86Club decal ideas? Hanzo BRZ First-Gen (2012+) — General Topics 46 06-04-2012 02:15 PM
