#57 | |
Drives: GR Corolla
#58 | |
Drives: 2013 BRZ Premium MT
They're indeed extremely bright as BRZ's front side markers, but the exact same bulbs aren't all that effective as Impreza's front side markers. These little enclosures don't have room for back reflectors, or the reflectors are literally the size of the bulb itself, so unless the bulb is translucent, like the incandescent bulbs, all we see is the LED chips that are pointing outwards. The ones pointing the other way don't contribute at all to what we see. I also bought their red 194 and put them in the rear, and they're insanely visible in the Impreza, but just okay in the BRZ. The reflector design and the bulb orientation, or rather the location of the actual emitters, is paramount to these LEDs. I tried to illustrate this by combining a bunch of photos I took with the cars parked side-by-side in my garage. ![]() The rear side markers illustrate this best. On the Impreza, the entire housing is lighted, and it's bright no matter which direction I look from. I think at least 4 (out of 6) emitters are really contributing here, with the remaining 2 also contributing some. In the BRZ, maybe 3 are contributing somewhat, and their angles aren't ideal for the housing design. I'm thinking even one emitter placed just right can be more effective in some cases over 6 emitters in a generic pattern. Unless they start making custom bulbs for individual cars, we'll just have to get by with what we get. |
#59 | |
Drives: GR Corolla
Wow, that's pretty crazy. Great post tho. I don't think anyone is ever going to make car specific bulbs. That R&D would make the bulbs super expensive. lol |
#60 | |
Drives: 86
At least it looks like TRS carries them so you could always stock up on a few sets
| The Following User Says Thank You to maui86 For This Useful Post: | Kaotic Lazagna (01-08-2017) |
#61 | ||
Drives: 86
I've been toying with the idea of a high powered red brake light (i.e. Triton, Probright) Under some type of diffusion material (frosted vinyl overlay would be the "easy" first choice) - The trick would be to do it without breaking up the overall design of the original tail light housings . . . |
#62 | ||
Drives: 86
Nice comparison. My only concern with a vehicle specific bulb would be only OEM production/quality ( ,) and pricing ( ) for them initially - and subsequent less than stellar "replicas."i.e. Winjet headlights that are replicas of the OEM Toyota monogram/JDM headlights - From the outside they look great, but their stock h7 projectors are just "ok" and their LED "eyebrows" are way too under-powered compared to the genuine Toyota product. But for the price ($300 for a pair of Winjets vs. ~$800 PER SIDE for the Toyota's) the Winjets are hard to pass up. On that note, the Valenti 9 LED side markers look like nice aftermarket alternatives, although a bit pricey ($100+) for a set . . . |
#63 | |
Drives: GR Corolla
#64 |
Drives: GR Corolla
So got around to installing the HVA bulbs in the rear turn signals on the Yaris. Have a look. OEM on the driver side, VLEDs HVA on the passenger.
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | maui86 (01-09-2017) |
#65 |
Drives: 86
I've re-wired my brakes to be "quad" brake lights, with the stock tail lights set to blink when turn/hazards/lock are activated: ![]() (This BTW is a crappy quick comparison - Red Rocket on the Left, Phillips Ultinon on the right. Almost identical, except for a bit more light spill with the red rocket.) So it would be a matter of modifying the former turn signal now brake location with some type of optical diffuser. |
| The Following User Says Thank You to maui86 For This Useful Post: | Kaotic Lazagna (01-09-2017) |
#66 | |
Drives: GR Corolla
#67 |
Drives: 86
#68 | |
Drives: 86
![]() I haven't had a chance to run them longer however as the bulb is difficult to seat (have to hold the bulb halfway in the housing, hope you don't drop it in by mistake, and snug it up into the socket) and not super secure either. Also leaves an ugly red reflection when off due to part of the base protruding past the reflector edge. When I get the time, I'll probably look at getting it all to fit properly, secure with a bit of electrical tape or something for security, and do a bit more testing. |
#69 | |
Drives: GR Corolla
Yup. The Yaris hatch has a weird frosted tail light lens. The JDM RS taillights are even worse. Lol. But I suppose they help in this case to diffuse the LEDs properly. Haha, that's how I had to install the HVA bulbs as well. Actually dropped them in a couple times and had to use pliers to retrieve them. Did you really push the bulbs into the socket? I thought they weren't very secured until I pushed them in harder. Haha. Pretty secure after. Eek, I don't want any colored reflection if possible, and if they're just shining the bumper, that's not good. |
#70 | |
Drives: 86
It's odd, I've had lots of "loose bulb" issues with the FRS, both front and rear. As usual, the best bulbs in terms of fit have been (surprise surprise) the Phillips Ultinons! The Ultinons are super secure, have a satisfying "click" to them, and don't leave any ugly reflections front or back. They're also small enough that I don't have to risk dropping it in the housing just to install them ![]() At some point I might do a full comparison/test of the red rockets - In person they do seem just a bit brighter (hence the light spill/bleed on the bumper,) and the small, almost unnoticeable, amount of shadow left in the center of the reflector by the Ultinons is not apparent with the Red Rockets as they have a couple emitters on the top with a "projector" lens. The real test however would be to see how they do in direct sunlight, particularly as their use as brake lights makes all weather visibility even more important (another reason for the "diffused lens" idea.) Or, if I can manage to find a set at the right (low) price, I may just decide to switch to TOM's tails at some point
| The Following User Says Thank You to maui86 For This Useful Post: | Kaotic Lazagna (01-10-2017) |
| Tags |
| 7443, led, morimoto, switchback, turn signal |
| Review: Philips X-treme Ultinon 7440 Amber LED Front Turn Signal Bulbs | maui86 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 12-16-2016 02:09 AM |
| WTB: Reverse white bulbs + clear switchback front turn signal bulbs | Xplicit | Canada Classifieds | 9 | 06-12-2016 11:47 AM |
| Front Turn Signal Diode Dynamics Switchback Installation Question | FRS'd | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-27-2015 11:17 AM |
| ***LIGHTING: X-light HID kit (4300K) and LED Switchback Front Turn Signal | CreinCrein | Exterior Parts (Aero, Lighting, Etc.) | 6 | 04-13-2014 06:13 PM |
| FS: Front/Back LED Switchback and Turn Signal with Relay - Concept 3/Vicious LED | Rich1 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 07-26-2013 12:04 AM |
