#43 |
Drives: GR Corolla
#44 |
Drives: GR Corolla
@maui86
Received and installed the 7440 VLEDs HVA bulbs in the rear turn signals. Check it out: ![]() ![]() The difference between OEM and these are nuts! No one can say they didn't see me signalling. haha |
#45 | |
Drives: 86
HOLY CRAP thats nice! ![]() I'm going to have to see if they make a comparable version in red . . . after they get my triton switchbacks out of backorder and shipped
#46 | |
Drives: GR Corolla
I can't wait to see your Triton once they're installed. haha. Where are you installing them? |
#47 | |
Drives: 2013 BRZ Premium MT
I can see they're very bright, but unless you're using them as back-up lights, the projection pattern is important, too. The reflectors are designed to throw fairly far, with fair amount of spill, too. This is why I like the Philips. I see the HVA bulb has some LEDs pointing straight out, so they obviously won't have problem with spill, and with enough brightness, throwing long distance shouldn't be a problem even without the proper reflector usage. But I wouldn't want to be sitting behind you at a stop light at night. ![]() Also, you can't really compare lumen ratings between HVA and red. HVA is really a phosphor coated ultra-warm white LED emitting wide spectrum of light, whereas red LED is really red specific LED. For example, the 21 watt incandescent bulb used for brake light behind the red lens outputs barely over 50 lumens worth of red light, which is good enough for brake lights. |
#48 | |
Drives: 86
Anyhow, here's the cached page: https://webcache.googleusercontent.c...&ct=clnk&gl=us I don't know how many CSR's they have, but I usually deal with Jamielle over there and she really knows her stuff (she's the one who found the D2S' for me) |
| The Following User Says Thank You to maui86 For This Useful Post: | Kaotic Lazagna (01-07-2017) |
#49 | |
Drives: GR Corolla
I think the people behind me shouldn't be affected in a bad way if I'm sitting in a left turn lane at a light. So do you think the brake light version would be insanely bright (can't use em in our cars). |
#50 | |
Drives: GR Corolla
#51 | |
Drives: 86
nah, they're going in the front turn signal location - 6k white/amber switchbacks. Until I have time to research and crack open my Winjets again (or if someone wants to sell their Monograms headlights lol) I've disabled DRL, and will probably run the Tritons as DRL instead. Looked quickly last night - looks like the red are part of the "Platinum" series. I need to find some good output shots of those in clear lens housings as I'm not too concerned about stated lumen output as much as I am about configuration. Example - I recently ordered the ACME Red Rocket's from TRS (rated at 272 lumens) since they have a down/backward firing configuration vaguely similar to the Philips Vision and Ultinon. compared them to my 75 lumen imported Ultinon's (75!?!? that's it??!) annnnd . . . the ACME's were just a tiny bit brighter than the Ultinon's Fitment is also a bit of an issue. The HVA's and the Platinums look like they use a brute force method; which can have it's advantages
#52 | |
Drives: 86
- I only found out about them after stumbling upon a random listing on some site
#53 | |
Drives: 86
#54 | |
Drives: GR Corolla
#55 | |
Drives: GR Corolla
#56 | |
As maui86 mentioned, Red Rockets supposedly rated 272 lumens weren't much better than 75 lumens rated Philips, so.... If it's actually 170 lumens, that would be way too bright for brake lights, but then, the bulb design won't be able to utilize the reflector very effectively, so, who knows? |
| Tags |
| 7443, led, morimoto, switchback, turn signal |
| Review: Philips X-treme Ultinon 7440 Amber LED Front Turn Signal Bulbs | maui86 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 12-16-2016 03:09 AM |
| WTB: Reverse white bulbs + clear switchback front turn signal bulbs | Xplicit | Canada Classifieds | 9 | 06-12-2016 12:47 PM |
| Front Turn Signal Diode Dynamics Switchback Installation Question | FRS'd | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-27-2015 12:17 PM |
| ***LIGHTING: X-light HID kit (4300K) and LED Switchback Front Turn Signal | CreinCrein | Exterior Parts (Aero, Lighting, Etc.) | 6 | 04-13-2014 07:13 PM |
| FS: Front/Back LED Switchback and Turn Signal with Relay - Concept 3/Vicious LED | Rich1 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 07-26-2013 01:04 AM |
