Old 09-22-2016, 10:27 PM   #113
Lantana frs
Drives: 13 frs red
When my first motor shit the bed the Toyota tech struggled with it as he had never worked with a Subaru engine. After a failed short block replacement they gave me an entirely new motor. Happy ever since.
Lantana frs is offline   Reply With Quote
Old 09-24-2016, 06:41 AM   #114
3essess
Drives: frs
Fwiw, listened to your video and my 2013 has been making the same (or similar) sound every now and then at idle from when it was new. Comes and goes so I figured it was normal and never bothered to take it in. I also have the rattle while slowing down in neutral along with crickets and various other clacking noises. The idle dip also seems to come and go every now and then. Car has over 35k and is still running strong - knock on wood!
3essess is offline   Reply With Quote
Old 09-24-2016, 06:47 AM   #115
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Doubt yours is making the same as mine doesnt come and go. Once it comes, it happens every time the car warms up.
Havent heard from the dealer yet. I'll call on Monday and ask for an update.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 09-24-2016, 06:48 AM   #116
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Originally Posted by Dr. BRZ View Post
i really don't feel like reading 8 pages so why not convert to e85? there's no knock off with e85. it's much better and car is faster.
Everything is in the first post.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-26-2016, 12:23 PM   #117
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Update: 9/26/2016
I called the service manager today (working directly with the manager now rather than the advisors.) He mentioned a guy from Toyota NA and a tech from the dealer chain's Subaru dealer came by to listen to the car. They thought there may be some debris in the oil system causing the VVT system to rattle, so the Subaru tech recommended disconnecting the cam gear and running the engine without it. The service manager told me that the noise goes away completely with the cam gear disconnected. I don't know what that means exactly, as I don't think the engine can run without it, but maybe the oil control valve was disconnected or something allowing the chain to spin. Not sure.
Toyota NA is sending another engineer to the dealership to work on the car. They are going to inspect the oil system for debris and the vvt components for any damage to see what is causing it to rattle a second time. The service manager says I should hear again "very soon" about what they're going to do. I'm hoping to hear back in the next couple days at the latest.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-26-2016, 12:41 PM   #118
Pat
Pat's Avatar
Drives: 2023 BRZ
That's good news. Getting field engineers involved means they're taking it seriously.
Old 09-26-2016, 01:13 PM   #119
MarkR171
MarkR171's Avatar
Drives: '05 Elise
I figured I'd post this here because the service manager mentioned suspecting debris in the timing system and this video shows potential weaknesses related to that. Also sending a link to the service manager.
[ame="https://www.youtube.com/watch?v=EX5x7PqXyhU"]Subaru BRZ FA20 cam chain info, tips and traps - YouTube[/ame]
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
The Following User Says Thank You to MarkR171 For This Useful Post:
x808drifter (09-26-2016)
Old 09-26-2016, 06:28 PM   #120
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Update from end of Monday 9/26/2016
Service manager says they have NOT opened up the vvt system at all yet. They only disconnected the vvt oil control solenoid to check if it's the vvt system acting up again. All they did so far was drain the oil, cut open the filter and strain the oil. No shavings or any debris visible. Toyota wants him to take the car overnight to test before continuing tomorrow.
I'm guessing he'll call tomorrow saying there is still a noise. Essentially all they did was an oil change... on 2500 mile old oil... and found nothing.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-27-2016, 08:37 PM   #121
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Update Tuesday 9/27/16.
Got the car back today.
The service manager had me speak directly with the tech to go over everything they did with the car. The first thing they did was unplug the controller for the driver side exhaust cam gear. Immediately, the knocking/tapping noise stopped. Toyota had them drain the oil, cut open the filter to look for debris, and even ran some oil through paper to look for debris. They found nothing. They refilled the oil, plugged the controller back in, and no more knocking/tapping. Engine runs perfectly normal.
Toyota believes there might have been a tiny bit of debris in the oil control valve that controls the oil pressure inside the cam gear to control the timing. By unplugging the controller, and plugging it back in, they think they forced the debris through the valve. They didn't want to open the timing cover because there is no longer any symptom to diagnose. Opening it and looking around would get them nowhere.
I asked the tech if there was any oil left that could be used for an analysis, but he said the oil has been out in open air so it wouldn't be a good idea. But he did mention it would be a good idea to do an oil change after 3-5,000 miles and send the oil out for analysis just in case there are particles that the naked eye can't see.
For now, the dealership put 107 miles on it since the noise went away and I put about 50 on it today. Car is back to normal.
I'm somewhat relieved that it seems to not be a mechanical failure. Everything that has been done to my car has been logged to my VIN with Toyota so it's all documented in case the issue comes up again.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
The Following 4 Users Say Thank You to MarkR171 For This Useful Post:
DarkSunrise (09-27-2016), Lantana frs (09-27-2016), Pat (09-27-2016), Wayno (09-27-2016)
Old 12-24-2016, 09:19 AM   #122
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Aaaaaaand its back.
Because today is Christmas eve, part of me wants to try unplugging the control valve, resetting it, then forget about it.
The other part of me wants to just park it until the dealership is open and bring it back knocking.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 12-24-2016, 09:58 AM   #123
Teseo
Drives: frs
Why not give you a complete engine? Swap it and call it a day, rather than wasting time and money on materials and man-labor
Old 01-03-2017, 09:24 PM   #124
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Update: 1/3/2017
So my service manager told me last week that Toyota suggests they disassemble the motor so that we can find the source of the problems. This is the current state of my engine:
He also mentioned that they found metal shavings in the oil but were not aware of the source of the shavings in his text to me this morning.
I asked for an update in the afternoon and got this response that I'm not sure how to take currently...
"We found a very small oil port with a restriction that appeared to be the sealant that is used between the block. Toyota is sending someone tomorrow to inspect the engine now that it is disassembled."
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 01-03-2017, 09:53 PM   #125
Lantana frs
Drives: 13 frs red
I feel for you but stay the course. My experience with Toyota regarding warranty work has been very positive.
The Following User Says Thank You to Lantana frs For This Useful Post:
MarkR171 (01-04-2017)
Old 01-03-2017, 10:10 PM   #126
DarkSunrise
DarkSunrise's Avatar
This thread might be useful for you:
http://www.ft86club.com/forums/showthread.php?t=107959
2022 BRZ Build
2013 FR-S Build
DarkSunrise is online now   Reply With Quote
The Following User Says Thank You to DarkSunrise For This Useful Post:
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
how much psi can the stock motor hold? xUhMeyziing Forced Induction 56 10-13-2017 07:43 AM
Would you take your $ spent and a stock motor, over your FI setup? Timmy_Jones Forced Induction 25 05-21-2015 02:21 PM
STOCK MOTOR 3k Anthony7515 Engine, Exhaust, Bolt-Ons 16 11-25-2014 04:48 PM
Stock Motor Cross Want-To-Buy Requests 2 08-01-2014 07:47 PM
