A.K.A. Starlord
Drives: 2015 Series.Blue
Shifter Grind...
Has anyone else had this happen? To copy my video description: "Not sure what's going on here. It's not the gears themselves grinding. The sound comes from the shifter itself - like right there, and it "feels" like it's coming from that area too. Almost sounds like the reverse lockout is getting in the way or something. The faster I shift from 3rd to 4th, the more it makes that plastic-y grind noise before it allows me to go into gear."
I ordered a new shift knob and reverse lockout from Raceseng, so I'm waiting for those to arrive before I take anything apart. The sound and feedback are coming from right around the shifter. It used to do it only in 4th, but now I get it downshifting into 5th too. It's like something in the shift assembly is loose, and getting looser? I dunno... [ame="https://www.youtube.com/watch?v=qkoswloec2w"]Shifter Grind - YouTube[/ame] |
#2 |
I donno ...... does sound like something is lose.
Hopefully it will be apparent when you open it up to put on your new parts. humfrz ...... not being any help .....
| The Following User Says Thank You to humfrz For This Useful Post: | Stang70Fastback (12-24-2016) |
#3 |
A.K.A. Starlord
Sorry, I couldn't resist :P
#4 |
Are you absolutely sure it's not a worn syncro? You know we've had this discussion.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Stang70Fastback (12-24-2016) |
#5 | |
A.K.A. Starlord
I need to get a better video. This one was rushed. I can get much better audio of the sound and you'll see what I mean. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | Ultramaroon (12-24-2016) |
#6 |
#7 |
Well, ok!
...but srsly, what does it feel like when you shift gently? Is there a difference in how it behaves upshifting versus downshifting?
#8 |
A.K.A. Starlord
I need to play with it more - one of the things I plan on doing now that I'm out of Chicago and in NJ for vacation. I have time, and more importantly, some open back roads to mess around on without bothering a million people.
Offhand, though, from what I can recall, it happens in either direction for 4th, and I *think* only when downshifting to 5th. I'll hopefully have more info and maybe a better video in another day or two. |
#9 | |
#10 |
A.K.A. Starlord
#11 |
LMAO
It's my special gift.
#12 |
#13 |
Well the problem is obvious to me. You are shifting with your left hand!
I totally disagree that there is an actual tranny issue involved there. Like said in the opening post the noise is coming from the shifter itself not the tranny. It sounds more like the mech is sliding across a gate.
#14 | |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 10:57 PM |
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 09:20 PM |
| Shifter springs/bushings/shifter performance | Darnold | Engine, Exhaust, Transmission | 10 | 10-23-2014 12:49 AM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
| Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing | swansons | Issues | Warranty | Recalls / TSB | 4 | 02-02-2014 03:27 PM |
