Old 12-06-2016, 03:57 PM   #71
Yoda
Drives: Crystal Black BRZ(Sophia)
Originally Posted by 86 South Africa View Post
My bad... misunderstood that post then.
In that case I should start looking for a rotrex SC!!
Or you could save for the Supra... I can only hope it will be out in 2019.
Yoda is offline   Reply With Quote
Old 12-17-2016, 06:46 AM   #72
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
I'd love to, but we get nailed so much with import taxes etc that make our cars so much more expensive. For e.g. Before buying this I looked at a VW Scirocco... it was around 350,000 here but only 220,000 or so in the US.
Ergo.. the Supra is likely gonna cost more than I'd be prepared (or able!?) to spend!
I like driving!
86 South Africa is offline   Reply With Quote
Old 12-22-2016, 01:48 PM   #73
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Originally Posted by Icecreamtruk View Post
Dude, you got all of that backwards. The Edelbrock/tvs route is the hotter route. The rotrex (Jackson Racing SC) is the one that has better cooling and generates less heat.
I've heard the opposite from many people in my community. A lot of people (including my mechanic) tell me the Edelbrock runs cooler than the Jackson. But then again i think a lot of this is based on context. It's possible that overall the Edelbrock might run hotter all around. But the Jackson runs hotter after 5k RPM. *shrug*
Again all based on context and how you will drive the car honestly. I personally went with the Edelbrock due to more low end torque and "fun" at lower speeds. From what i keep hearing is that the Jackson basically drives like stock until 5k RPM and then it's like a rocket.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 12-22-2016, 01:55 PM   #74
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Hearing and experiencing are two different aspects. Edelbrock and Jackson Racing kits both have heat exchangers to keep these temperatures in check. Both kits are designed exactly for its intended purpose and work great in that aspect, hence why we have supported both companies since the beginning (before release and after). If you have any questions, do not hesitate to contact us via PM.
CounterSpace Garage is offline   Reply With Quote
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
AJPG (12-22-2016), mrg666 (12-22-2016)
Old 12-22-2016, 02:26 PM   #75
Xxyion
Lowly Cartuber
Xxyion's Avatar
Yeah. My point was that it's all based on context. Technically you could say a stock NA engine runs hotter than an edelbrock kit but without context that statement is irrelevant.
Old 12-22-2016, 02:52 PM   #76
AJPG
Drives: 22RE, FA20, 4G63
The good/bad old issue with intake temp. You could set a centrifugal supercharger hotter than a positive displacement supercharger or it could be made the complete opposite but you should have a goal before the build.
Everyone knows that heat increase with pressure and that it apply to compressing air, so that been said the PD and centri SC differ on how they generate heat and how they dissipate heat. The PD should be big enough (enough for what? Put your goal in here _____. So it could be use at the low-mid range of recommended rpms of the SC (to avoid heat soak). The centri in the other hand should be use at the mid-high rpms (to get good use of the compressor).
AJPG is offline   Reply With Quote
Forced Induction Comparison (twin-scroll/centrifugal/turbo) SillySaxon Forced Induction 6 09-22-2014 11:59 AM
Centrifugal or Twin-scroll? What Ever You Choose FR SPORT Has it for Your ZN6 Car! FRSport.com Forced Induction 0 09-27-2013 08:15 PM
Most reliable F/I kit? official_george Forced Induction 103 05-14-2013 12:00 PM
roots vs centrifugal superchargers slaxx Forced Induction 15 04-09-2013 11:04 AM
Centrifugal vs Positive Displacement SC EN2_Squirrel Forced Induction 38 11-01-2012 11:58 AM
