Old 09-12-2015, 09:26 PM   #29
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
I've tracked and autocrossed with these rims and there is no loss of precissness. You could fit a 215 tire on them. If you want a narrow tire although 245s give maximum grip. Won my regional autocross series with these last year with BFG rivals on them and had no problem hugging cones.
Great rims enjoy them allot
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 09-12-2015, 09:40 PM   #30
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
@UMB FR-S nice! What's your total setup? Tires, suspension, etc?
yamsta is offline   Reply With Quote
Old 09-12-2015, 09:46 PM   #31
UMB FR-S
UMB FR-S's Avatar
Umm back then suspension was stock and had 245/40/17 BFG rival tires on it. Couple exhaust mods and other minor stuff done at the time also.
-- Kenny
Old 06-29-2016, 12:54 PM   #32
ML
ML's Avatar
Drives: 13 White MT FR-S
Powder coated black.
The Following User Says Thank You to ML For This Useful Post:
Bimble Bamble (11-18-2016)
Old 12-08-2016, 01:32 PM   #33
novice
novice's Avatar
Drives: Fr-S 2.0 Release
I just installed some of these last night. I wasn't going to buy wheels and tires for a while since my 2.0 has low mileage but couldn't resist $169 per wheel.
TRD Springs, K4R 17x8 +36 225/45/17 MPSS Almost perfect. Front could use some camber adjustment to match the back perfectly but could do without it.
novice is offline   Reply With Quote
The Following 2 Users Say Thank You to novice For This Useful Post:
Bimble Bamble (12-23-2016), Vracer111 (12-08-2016)
Old 12-09-2016, 01:43 PM   #34
mbrs1.0
Drives: 2015 FRS RS 1.0
Do you have any more pictures? I am looking into getting this for my RS 1.
mbrs1.0 is offline   Reply With Quote
Old 12-09-2016, 02:32 PM   #35
novice
novice's Avatar
here you go
Old 12-09-2016, 04:40 PM   #36
mbrs1.0
Originally Posted by novice View Post
here you go
Thank you. Seeing it on your car makes me want to get the wheels and tires. Since you've had it for some time now, any suggestions or thoughts?
Old 12-09-2016, 06:04 PM   #37
novice
novice's Avatar
no prob. do you mean my car in general or the new wheels and tires?
Here are some more...
Old 12-12-2016, 02:37 AM   #38
rraicu
Drives: BRZzz
What a great looking setup! Absolutely beautiful.
rraicu is offline   Reply With Quote
Old 12-12-2016, 09:05 PM   #39
mbrs1.0
Thank you. I meant the wheels, but then realized you just got them. How do you like it so far?
Sent from my SM-G928V using Tapatalk
Old 12-13-2016, 08:57 AM   #40
novice
novice's Avatar
I like them a lot. I can feel a big difference with the tires and the added width. Feel more locked in.
Old 12-13-2016, 09:02 AM   #41
mbrs1.0
Good to hear. I will more than likely get the same setup.
Old 12-22-2016, 01:42 PM   #42
ML
ML's Avatar
FYI be really careful with light wheels like these if you daily them. My set has seen a lot of use and been welded once before, now needs to be welded again.
Wheel Directory: XXR 527 17x8.25 +35 MF_DEUCE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-25-2019 07:37 PM
Wheel Directory: XXR 535 17x8.25 +35 PineappleFriedRice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 10-24-2014 09:27 PM
Wheel Directory: OEM VW Corrado (BBS RSM) 17x8.0 +35 koevasi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-02-2014 02:08 AM
Wheel Directory: Advan TC II 17x8.5 +45 driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-08-2013 03:45 PM
Wheel Directory: XXR 522 17x8.0 +48 STEVEOSTI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-13-2012 01:39 AM
