#15 |
Drives:
So if I understand correctly, the new 2015 Subaru struts are softer than the 2013 Subaru situation, which are softer than the Scion struts, and they are all interchangeable.
It's as if Toyobaru is giving us OEM aftermarket options. |
| The Following User Says Thank You to N234 For This Useful Post: | why? (12-14-2016) |
#16 |
Drives: '15 BRZ RA
I wouldn't say softer, because they didn't change the springs. They just have better damping properties by using revised internals and thinner oil. There were a lot of complains that the earlier struts were giving a harsh ride.
#17 |
A few shops tested the shocks from FRS' and BRZ's (2013 models at least) and found no difference in the shocks between brands.
#18 | |
Drives: 02 Mitsubishi Mirage
#19 |
Drives: '13 FR-S
#20 | |
Drives: Whiteout
Because for my situation I currently have the 2013 model with TRD springs. I wanted to keep using the TRD springs but use the 2015 dampers that I can buy used. I've been reading around and some people are saying that it was the springs that were retuned and some say it was the dampers and some say it was both. |
#21 | |
Drives: '15 BRZ RA
#22 | |
Drives: FR-S Whiteout
Also, anecdotally a local BRZ owner who's tested MY15 and MY16 dampers on the same car reports an improvement in the MY16 coilovers off a BRZ over a the MY15 on the same car. But that just from subjective on track butt dyno analysis. Changes to MY15's rebound top, compression bottom. Front struts left, rear shocks right.:
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 12-14-2016 at 09:53 PM. |
| The Following User Says Thank You to solidONE For This Useful Post: | Yoniyama (12-21-2016) |
#23 | |
Drives: 2014 Ultramarine FR-S
#24 | |
Alexandrino_Auto
Drives: series.Blue
The Shadetree Project: I turn wrenches
| The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post: | Racecomp Engineering (12-15-2016), solidONE (12-15-2016) |
#25 | |
Intent > Content
cowardice is the mother of cruelty. |
#26 | |
Alexandrino_Auto
Drives: series.Blue
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | solidONE (12-27-2016) |
#27 |
I recall when I was running Swift sport BRZ spec spring on my stock '13 dampers, the front felt a bit under damped while rears were pretty on point right off the bat as well. But later on the rears started to feel a bit under damped as well. It was noticeably different after a few thousand miles and a couple of trackdays, but not horrible.
Intent > Content
#28 |
Drives: Whiteout
So I did the switch as well, switched out my MY13 dampers for MY15 ones (but I kept using my TRD springs) and it is quite different. After an alignment I noticed that the car was less "tail happy" in turns. It felt more balanced in the corner and it didn't feel like I was about to start drifting at every turn like it did with the MY13 dampers. The MY13 dampers felt soft in the front and stiff in the rear. The MY15 dampers almost feel like the opposite IMO; the front is stiff and the rear is soft. It does understeer a bit more now compared to the MY13 dampers but not too much. In terms of ride quality it feels a bit less harsh on the road, bumps are soaked up better and is a more comfortable ride. Although it is a more comfortable ride, somehow there's less body roll in corners compared to the old ones. Overall I think it's worth it if you can find a used set for cheap.
| The Following User Says Thank You to KHANrad_SIN For This Useful Post: | nikitopo (03-30-2017) |
| GrimmSpeed Cold Air Intake BRZ 2013-2015 / Scion FR-S 2013-2015 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 22 | 03-25-2015 01:12 PM |
| Beatrush Over Pipe Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 17 | 03-16-2015 11:29 AM |
| 2015 models suspension different ??? | Sugi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-25-2014 11:15 PM |
| Review of 2015 BRZ suspension changes? | thismock | BRZ First-Gen (2012+) — General Topics | 10 | 09-26-2014 09:38 AM |
| 2015 Model FRS suspension changes | SeanRTR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 05-21-2014 12:21 PM |
