#43 |
Drives: UK GT86
Have you had an updated tune since you got the dongle? If you look in the logs or maybe the info screen you should be able to see what RaceROM revision you have, perhaps if you look at the tune on your laptop it might show it too. The v9.1 has a SVN number of 24256, these were developed for use with the EVi.
.: Stealth 86 :.
#44 | |
Drives: 2015 BRZ CWP
Yea, tuner confirmed not on the latest version or RR. I'm currently on 20479 Sent from my iPhone using Tapatalk |
#45 |
Drives: UK GT86
I'll suggest there's the reason, so you won't get any of the ECUtek logging parameters until the tune is updated.
.: Stealth 86 :.
#46 |
#47 |
Drives: UK GT86
There are quite a few parameters that come under ECUtek parameters, so it's worthwhile to have the update.
.: Stealth 86 :.
#48 |
#49 |
Drives: '13 BRZ
Are the RaceROM features not available to retail upgraded RaceROM licenses (DIY tuning)? I've updated but am not seeing the RaceROM 9.1 feature files.
#50 |
Drives: UK GT86
If they dont download when you run an update then they aren't available yet.
.: Stealth 86 :.
#51 | |
Drives: '13 BRZ
Guess I'm stuck waiting again. |
#52 |
Drives: UK GT86
I can understand beta maps so only tuners get access and are more likely to be able to test and verify. However it seems that proven tables don't get moved that often. The compare feature also isn't all that at the moment, you need the same ROM type and RR version for it to work. I would suggest if you didn't limit these features to paid tuners then what would stop people just going the cheap route and tuning others?
.: Stealth 86 :.
#53 | |
Drives: '13 BRZ
If stopping people from going the cheap route is the issue, just add the ROM compare to the retail RaceROM upgrade. No end-user is going to pay the extra $350 for features they can't use (locked tune from their tuners). I've actually never tested using my retail RaceROM upgrade features on someone else's car. They've always had their own kit, and I just use their license to correct small stuff such as MAF after intakes. If I can set up a ROM with RaceROM / custom maps on my end, and use their license to flash to their car and have everything work perfectly, I can see why they'd limit the features in that case. I always assumed the RaceROM features wouldn't work properly if flashed with a license that doesn't have the retail upgrade. Anyway, I'm way off topic now. Thanks for the input. I sent an email to EcuTek and they're forwarding me the 9.1 RaceROM files to play around with until they're put on the updater for retail users. |
#54 | |
Drives: UK GT86
.: Stealth 86 :.
#55 |
Drives: 2016 FRS Release Series 2.0
There is no programmatic limit to number of first flash / license installs a dongle can perform. If you've bought 10 licenses keyed to your dongle ID, you may install 10 licenses. Whether or not they will sell you that many is the question.
#56 | |
Drives: FT86
Most pro tuner supplied roms have race rom features added and they flash fine even with the basic ecutek kit with no racerom extension. So cannot see any difference if you have boughtvthe racerom extension then you can create and edit your own racerom enabled tunes andcflash them But yeah their might likely be a limit on the number of liciences they will associate with a non tuner dongle. But if the guys already have liciences in their ecus from other tuners it shgould not be a problem. Ive also puhased liciences from multiple tuners and that does not cause a problem either. |
| Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM | DeliciousTuning | Software Tuning | 331 | 06-17-2025 02:36 PM |
| My Bluetooth in my 2014 FRS so stay connect | Case1010 | Electronics | Audio | NAV | Infotainment | 3 | 02-24-2016 06:57 PM |
| Header/overpipe interface | misooscar | Engine, Exhaust, Transmission | 4 | 11-22-2014 11:21 PM |
| Garmin GPS Bluetooth Won't Connect | frssfo | Electronics | Audio | NAV | Infotainment | 0 | 08-20-2014 10:55 PM |
| Bluetooth connect mutes android NAV | Rob_g | Electronics | Audio | NAV | Infotainment | 6 | 07-04-2012 04:38 PM |
