Drives: 2010 Acura TL
Normal LTFT??
My LTFT is constantly between -5 to -2. After the engine is warmed and I give it some WOT, it will flatline at 0.00 and MAYBE go up to 2.67ish. Just wondering if this is normal before going to OFT E85. Currently running stage one OFT. Car is bone stock besides OFT.
Thanks ![]() Sent from my iPhone using Tapatalk |
#2 | |
Drives: UK GT86
.: Stealth 86 :.
#3 |
#4 |
Drives: WRB Subaru BRZ Limited 6MT
Generally speaking, your car is fine. LTFTs between -5% and +5% indicate relatively balanced fuel trims all things considered. Since you are hovering around -5% at idle, your car is running slightly rich (pulling fuel, hence the -%). At WOT, all fuel trims (STFT and LTFT) peg at 0% as the car switches from closed loop to open loop, so your observation is exactly as expected.
To be 100% sure of everything, we would need to know your STFTs as well. If they are wildly off, it could indicate a problem depending on the direction. Also good to know if you have any mods that affect air or fuel flow/metering or exhaust gas travel paths. |
#5 | |
STFT levels are constant around -1 to +5. Nothing too crazy. Sent from my iPhone using Tapatalk |
#6 | |
Drives: UK GT86
.: Stealth 86 :.
#7 |
Ah, sorry, didn't see your mod list. OFT maps generally cause a slight rich condition as they want to be safe to mitigate differences in fuel quality. Assuming your STFTs are +/-5%, everything is perfectly fine.
#8 |
Help needed! Check engine light after weird traction lights.
https://r.tapatalk.com/shareLink?url...1&share_type=t Can u guys check that? I posted last night about the same issue but out the wrong title and go 1 reply. Sent from my iPhone using Tapatalk |
#9 |
Yes, I agree that this is true assuming the STFTs are fluctuating in a reproducible manner based on throttle input and load. However, my understanding is that if there is a variable issue causing the STFT values to swing, the LTFTs may not reflect STFTs accurately. Maybe I'm wrong...
#10 | |
#11 |
#12 |
Anti stance.
Generally speaking, anything below +/-8% is considered nothing to worry about.
#13 |
Huge E85 fan!
Drives: 2016 Scion FRS
Check your fuel trims at idle and 2500 RPM. You want them less than -/+10%. LTFT + STFT is your total fuel trim and that's what you want under 10.
#14 |
Drives: BRZ 2017
MY Stft trim hovers arund -3%, which i think is fine.... myltft on the other hand hovers around -19% on idle and -15% while driving. I do believe its bc i got an injen intake on there. SHould i be worried? I really dont wanna take off injen intake but will do so if needed. What can happen if I continue to run my car at these readings? Thank you!
| Where are LTFT data stored? | RustySocket | Software Tuning | 17 | 03-21-2026 11:53 AM |
| Diagnosing high positive LTFT | Tectoniic | Software Tuning | 22 | 05-03-2022 02:24 AM |
| strange LTFT | bee_are_zee | Software Tuning | 11 | 05-17-2016 07:28 PM |
| LTFT reading oft | mike7792 | Software Tuning | 1 | 02-01-2016 09:21 PM |
| high ltft at idle, my how to fix it(not fixed yet) | trdric | Software Tuning | 16 | 06-18-2015 10:27 PM |
