Old 06-26-2012, 04:58 PM   #15
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I'm 300+ lbs and I didn't think i would even fit in the seat let alone comfortably. I had a little back discomfort the first night I drove it 100+ miles home from the dealer but I ended up adjusting the seating position to a more reclined position and moved the steering wheel back a bit and its fine.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 06-26-2012, 05:05 PM   #16
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
Originally Posted by sieeegel View Post
a wise man from this forum gave me some wise advice when I complained about the same lower back pain a month ago. He suggested reclining the seat back slightly and moving the seat forward slighly to maintain (more or less) the same driving position. I did that and now no more problems.
just chiming in, Im 6'1'' 200lbs and I had to do the same thing, a bit of lean back + scoot up one click upped the comfort level noticeably. Havent driven for more than 2hrs straight though.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 06-26-2012, 05:22 PM   #17
helloimgil
helloimgil's Avatar
Drives: 13 Whiteout / 09 R6 [BRZ is gone!]
Originally Posted by velocity View Post
It's an acute muscle strain and will go away. People often get this when changing office chairs, etc. Your body will adjust. Using lumbar pillows is not a long-term solution and may prolong the pain. Yes, I actually am a doctor.
I agree with velocity, after the first days, my back adjusted to the seat. I am not a doctor, but I did stay in a Holiday Inn Express.
helloimgil is offline   Reply With Quote
The Following 3 Users Say Thank You to helloimgil For This Useful Post:
azngolfur (09-26-2012), DEC1 (06-26-2012), Dusky (09-10-2012)
Old 06-26-2012, 07:31 PM   #18
BRZranger
I've discussed this in another thread, but I had the same problem, and the bolsters were digging on my lats. I took it to an upholsterer and he added lumbar support, reinforced the lumbar stiffness, and replaced some hard foam with memory foam. Paid about $250, fits perfect for long drives now. FYI, I have a fractured spine L-1. These seats are made for the average person with no back pain. When the upholster took the seat apart, there is zero lumbar support, it just gives.
BRZranger is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZranger For This Useful Post:
denkigrve (06-26-2012), immortal_suby (06-26-2012)
Old 06-26-2012, 07:32 PM   #19
BRZranger
Only issue now is it looks like my seat is two months or three months pregnant! You. Ant really notice it until you compare the two, and it is reversible.
Old 06-26-2012, 07:51 PM   #20
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
+1. I was uncomfortable at first until I reclined the seat back a few clicks, then it was perfect. I think I'm just used to setting my seat for a higher seating position, the lower seat requires a more reclined position to be comfortable.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-26-2012, 09:02 PM   #21
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Interesting. Most people are talking about pain for the first few hundred miles. I've gone over a thousand and have had back problems in the past. If this isn't resolved this will be my next course of action.
Indestruct is offline   Reply With Quote
Old 06-26-2012, 09:08 PM   #22
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
I thought I was the only one. What makes it worse? Switching between this car, my WRX, and my GF's Mini. Ugh. My back hates me some days. Others I'm fine.
Nice. Thanks for this post. This is really helpful for those people that might not adjust as well as other, or that might find this unacceptable to them.
denkigrve is offline   Reply With Quote
Old 06-26-2012, 09:39 PM   #23
FT_Monk
Drives: Over the hill WRX
I have the same problem when I first got my WRX years ago. I used some over sized zip tides, add a piece of foam, adjusted the zip tide to have more support (I needed more shoulder support) and no more back pain.
FT_Monk is offline   Reply With Quote
Old 06-26-2012, 10:14 PM   #24
BRZranger
My upholsterer is in Kirkland, WA and he also said he would do adjustments free of charge! O the side bolsters he shaved off about an inch of hard foam and replaced it with memory foam so that it appears the same, but is much more comfortable. Only downside, is that the bolsters aren't as bolster-y. Before the adjustment, I could barely drive half an hour. Other day I'd drove it for three hours, total comfort!
The Following User Says Thank You to BRZranger For This Useful Post:
SeattleJeremy (07-20-2012)
Old 06-27-2012, 10:01 AM   #25
sdiver68
sdiver68's Avatar
Drives: 2013 BRZ Limited
Seats are perfect for me once I got them properly positioned. I drove 340 miles home immediately after delivery. Of course I rode about 300 miles of mostly backroads on my ZX10R on Sunday and 12 Miles of off road mountain biking yesterday thus I may not be the best judge of seat comfort
sdiver68 is offline   Reply With Quote
Old 06-27-2012, 11:05 AM   #26
Interesting. Maybe its because of my height (I'm 5'7" on a good day) or because I lucked out and got them "just right" but I've found them extremely comfortable. I drove 400 miles in one day, with two stops, and no issues.
Old 06-27-2012, 11:09 AM   #27
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
yeah everyone is going to fit them slightly different, my problem is up higher and I was lucky they support me well there, otherwise I would be having some adjustments made also.
Neziah is offline   Reply With Quote
Old 06-27-2012, 01:56 PM   #28
xwd
Same here, I was a little scared the first couple hundred miles with the lower back pain but it completely went away. I did a 200 mile drive on Sunday with no issues at all. I do wish it had at least some level of lumbar support, it's very good in my Forester XT (actually has a lumbar lever for the driver seat).
Mobile support (iPhone/iPad/Android) now available through tapatalk FT-MH Site Announcements / Questions / Issues 21 10-06-2016 05:35 PM
Your BRZ's first boo boo support thread Norcalmav23 BRZ First-Gen (2012+) — General Topics 131 10-24-2012 09:40 PM
OptionJDM wants your support guys! OptionJDM Announcements, Contests, Giveaways 16 05-30-2012 03:33 PM
Difference in aftermarket support for FRS and the BRZ. Eureka Scion FR-S / Toyota 86 GT86 General Forum 39 04-16-2012 11:06 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
