Old 11-29-2016, 05:45 PM   #1
Phantom_9192
Racer_X
Phantom_9192's Avatar
Quick tire question
Ok folks, I'm heading to CoTA with my FR-S for the first time. My PZeros got pretty mangled at TWS on the outside edges so I just bought a set of RE71's to put on my 17x7.5 wheels for the trip (225/45/17 like the PZeros).
I added negative camber to the front (from 1.3 to maxed at 1.9 using the camber bolts that were on it) and re-set the toe to a touch out both sides. I'm hoping this is enough to make the tires last longer.
I spoke with several people who recommended the RE71's highly so that was my choice.
Now to my question.
What pressures should I be shooting for? 37-38 hot?
I will push the car 10/10ths. 1.9 negative still doesn't seem like much camber to me but here's hoping.
Let me know ASAP on pressures please!
TIA!
(btw see below for evidence that I will be pushing the car 10/10ths... this car is too amazing to not push to the very limit).
[ame="https://www.youtube.com/watch?v=YDl0bydlsAs"]Scion FR-S Texas World Speedway 1:59.1 - YouTube[/ame]
Phantom_9192 is offline   Reply With Quote
Old 11-30-2016, 02:11 AM   #2
CSG Mike
CSG Mike's Avatar
I would recommend you set your pressure by pyrometer, and get yourself more camber before you go.
zdr93523 (11-30-2016)
Old 12-01-2016, 11:41 PM   #3
Phantom_9192
Racer_X
I'll be alone so pyrometer isn't a viable option unfortunately (plus I'm not a big believer in the value of pyrometer readings even on my racecar).
I'll try low 30's and see how that feels.
No way to get more camber without significant modification. 1.9 is where it is. I do worry that I'm going to continue to maul the outside edges of the fronts but we will see how quickly she runs. I'll post results.
Old 12-02-2016, 02:38 AM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Most people run re71rs at 30-34 'hot' for autocross, no idea where they would want to be for extended lapping, good luck.
ineedyourdiddly
Old 12-02-2016, 05:40 AM   #5
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I would look at starting around 28psi cold. About 3 laps in they should be closer to 32-34 or higher if you really push. After than its up to feal.
̶I̶f̶ ̶t̶h̶e̶ ̶c̶a̶r̶ ̶i̶s̶ ̶p̶u̶s̶h̶i̶n̶g̶ ̶a̶ ̶l̶o̶t̶ ̶t̶h̶e̶n̶ ̶s̶o̶f̶t̶e̶n̶ ̶t̶h̶e̶ ̶r̶e̶a̶r̶ ̶s̶w̶a̶y̶ ̶o̶r̶ ̶r̶e̶m̶o̶v̶e̶ ̶i̶t̶.̶ ̶F̶o̶r̶ ̶a̶u̶t̶o̶c̶r̶o̶s̶s̶ ̶i̶t̶s̶ ̶r̶e̶c̶o̶m̶m̶e̶n̶d̶e̶d̶ ̶t̶o̶ ̶j̶u̶s̶t̶ ̶r̶e̶m̶o̶v̶e̶ ̶t̶h̶e̶ ̶r̶e̶a̶r̶ ̶s̶w̶a̶y̶ ̶o̶n̶ ̶t̶h̶e̶s̶e̶ ̶c̶a̶r̶s̶ ̶w̶i̶t̶h̶ ̶s̶t̶o̶c̶k̶ ̶s̶h̶o̶c̶k̶s̶/̶s̶p̶r̶i̶n̶g̶s̶.̶ ̶Y̶o̶u̶r̶ ̶v̶i̶d̶e̶o̶ ̶m̶e̶n̶t̶i̶o̶n̶e̶d̶ ̶t̶h̶e̶ ̶c̶a̶r̶ ̶w̶a̶s̶ ̶p̶u̶s̶h̶i̶n̶g̶.̶
Stiffen the rear to help it rotate or soften the front to reduce understeer. Since you have whiteline sways it sounds like you could swap the stock sway back onto the front.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
G-Man (12-02-2016)
Old 12-02-2016, 08:54 PM   #6
wparsons
wparsons's Avatar
You're probably not going to want toe out up front if you're looking for tire life, 0 toe would also be less nervous feeling.
Originally Posted by Shneegle View Post
If the car is pushing a lot then soften the rear sway or remove it. For autocross its recommended to just remove the rear sway on these cars with stock shocks/springs. Your video mentioned the car was pushing.
If it's pushing and you soften the rear bar (or remove it) you're going to get even more understeer. You'd want to stiffen the rear or soften the front.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (12-03-2016), Shneegle (12-02-2016)
Old 12-02-2016, 09:20 PM   #7
Shneegle
Shneegle's Avatar
Absolutely right, that's what I get for posting at 3:40am was thinking oversteer. You would want the front to be softer or stiffen the rear to allow it to rotate more to get rid of the understeer.
The Following 2 Users Say Thank You to Shneegle For This Useful Post:
DarkSunrise (12-03-2016), wparsons (12-05-2016)
Quick question... Packofcrows Scion FR-S / Toyota 86 GT86 General Forum 20 09-19-2015 05:07 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 02:44 PM
Quick question?!?! tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-18-2014 03:55 PM
Quick Question akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-04-2013 10:29 PM
Quick Tire Swaps and Rotations | Guide | DIY Dezoris Tracking / Autocross / HPDE / Drifting 23 01-22-2013 10:54 AM
