, dpfarr
Old 11-29-2016, 06:39 PM   #1905
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by X Factor View Post
Anybody running this SC with an ACE Header?
@MicheleAbbate
The Following User Says Thank You to ATL BRZ For This Useful Post:
MicheleAbbate (12-19-2016)
Old 11-29-2016, 07:20 PM   #1906
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I'm running the ACE CS-400 with my edelbrock. What did you want to know ?
Silverfox is offline   Reply With Quote
Old 11-29-2016, 07:56 PM   #1907
X Factor
Drives: 2013 Red BRZ Limited
Curious what the torque curve looks like combining the two.
X Factor is offline   Reply With Quote
Old 11-29-2016, 08:21 PM   #1908
Silverfox
Silverfox's Avatar
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
205 ft/lbs
91 oct
Stock injectors and pump
I love the low end tq the CS-400 provides, but depending on your intent you may also want to consider the anaconda for tq in high Rpms.
As far as quality I can't speak highly enough.
The Following User Says Thank You to Silverfox For This Useful Post:
CounterSpace Garage (11-29-2016)
Old 11-29-2016, 11:24 PM   #1909
VeganGirl
Drives: Scion FR-S 2013
Originally Posted by GT86Asia View Post
Hi,
Depending on the type of phone u have, iphone or android, you will need to find a bluetooth OBDII which is either compatible with both operating systems (The more expensive ones $100+ usd) or one specific for android or apple. Usually the apple specific are more expensive than the ones for android because of the licensee fee that the OBD manufacturer has to pay to apple, unlike android which is free and doesn't need a license.
Anyway, you also have to carefully check what the manufacturer of that OBD says it can read. Some OBD are very simple, and to some of us useless, while some other OBD have better code and can read more things. Remember there is nothing mechanical about OBD, it's all 100% software. So if the OBD doesn't have the code to read a certain sensor, then you will not be able to read it.
I made a lot of reasearch, yet I was not able to find a bluetooth OBD for apple phone which included the engine oil pressure......I'm pissed off about it, cuz the damn thing cost me 80 bucks. The manufacturer said that it was because they have to license the code for each individual sensor from apple......and that maybe in the future they will license that sensor....So I guide myself with oil temp, which is inversely coorelated with oil pressure.
So these are just some pitfalls to keep in mind, as not every $12 buck OBD is created equal.
Cheers
Thanks I think I'll get an android tablet
VeganGirl is offline   Reply With Quote
Old 11-30-2016, 01:37 AM   #1910
GT86Asia
Drives: 2016 BRZ
I believe that most of the people that have changed headers with the edelbrock, are actually using ACE headers, so there should be plenty around. It was an option for me too after I realized my long tube headers werent a straight forward install, but I decided to keep the long tube ones as I didn't want to buy another set of headers.
From what I've heard, header performance dimishes a bit after installing forced induction. Like you wont notice such a big difference as you would on a naturally aspirated car, between the stock and aftermarket headers.
But my headers are loud, louder than the ACE, so that's why I also kept them, haha.
GT86Asia is offline   Reply With Quote
Old 11-30-2016, 10:39 AM   #1911
trd87t
Drives: Supra, BRZ
I have the ACE/250 installed on mine and the E-SC. The car is amazing, imo, as there is low end torque on tap (which was my goal).
I don't have a dyno chart yet but my clutch is slipping :/ I run E85 with a DT tune... couldn't be happier with the setup!
Once I find time to get this clutch I have installed I will put her on the dyno and get some numbers.
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
The Following User Says Thank You to trd87t For This Useful Post:
paiceyfan (11-30-2016)
Old 11-30-2016, 11:20 AM   #1912
OkieSnuffBox
Drives: '23 BRZ Limited
It's actually the opposite.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
CSG Mike (11-30-2016), Silverfox (11-30-2016)
Old 11-30-2016, 01:48 PM   #1913
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
What clutch were you considering? ACT? South bend? OSG?
Old 11-30-2016, 04:04 PM   #1914
GT86Asia
Drives: 2016 BRZ
I'm running southbend, it feels basically like the stock one, and it will not slip.
there is no point in trying to get a clutch that is super hard, if this is your daily driver and you also track the car a couple of times a month.
Very good choice, I'm 100% satisfied with it.
Old 11-30-2016, 05:25 PM   #1915
Colin86
Drives: 86
Which soundbend clutch are you running and how much torque are you putting to the wheels?
I'm thinking of running e85 (anticipating I'll be close to 250 ft/lbs to the wheels) and am curious what my best options are... I'm leaning towards the ACT HD pressure plate with the full face disk, although with a torque rating of 270 ft/lbs I'm afraid it might not hold the power.
What clutches are those on e85 using?
Colin86 is offline   Reply With Quote
Old 11-30-2016, 06:00 PM   #1916
trd87t
Drives: Supra, BRZ
I bought a used ClutchMasters FX350. Probably overkill for DD use but I got a deal on it and plan to upgrade the clutch fork and pivot ball as well. Hoping this won't be too pedal hard of a setup.
Though, I can't imagine that this setup will be harder than the RSP PP that I have in my Supra... that PP is a beast and I can DD it no problem.
Old 11-30-2016, 07:50 PM   #1917
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
My e-85 tune is 249 ft/lbs so your right on.
Lunatic is offline   Reply With Quote
Old 11-30-2016, 08:24 PM   #1918
Colin86
Drives: 86
What clutch are you running?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
